Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 64
Thread: I can PROBABLY get the S50 B30/32 VALVE TAPPET DEPRESSOR (115-070): Who wants one??
  1. #26
    Dec 2005
    Berkley, MI
    2000 E39 M5
    Quote Originally Posted by JamesM3M5 View Post
    Yes, BMW calls for a valve check/adjustment every 15k miles or Inspection 1. Typically, only a few valves actually need a shim change, whether you're talking about an S14, S38, S50, or S54. Sure as hell costs a lot to get done, though.
    The S14/S38 tool has 2 different width depressors, since those engines have different spacing between the lifter buckets on the intake and exhaust valves. The exhaust side of my tool seems to work great on the S50B32 engine we have under the hood of our car right now. I have not pulled my own valve cover off of my B32 (way overdue!), and I also have not opened a B30 cover to check clearances, so technically I have only one engine I've used the S14/S38 tool on so far.
    What about the S52?
  2. #27
    Mar 2001
    Dallas
    98 M3
    Quote Originally Posted by ///M3Augy View Post
    What about the S52?
    you don't have to shim the valves, they are hydraulic.
    Sean
  3. #28
    Dec 2002
    Lake Tyler, TX
    88 E30 M3 S65
    Quote Originally Posted by SG_M3 View Post
    I think he meant the B32.
    It's not speed that kills, it's the speed difference that does. Obviously you aren't going fast enough.
    Turning Benjamins into noise since 1997
    I read a list of the 100 things you MUST do before you die. Funny, "Yelling 'HELP'" didn't make the list!
  4. #29
    Arlington Heights, IL
    Z1, M3 LTW, 228
    Trivia
    I believe that Volvo shims are the same diameter. I do not have any idea what range of sizes (thickness) they come in. This might be a good low cost alternative.
    YES...by all means, they are re-useable from bucket to bucket.
    I was blown away by the guy's shop that does the grinding. He's got some insane machinery there. Makes parts ranging from locomotive parts, Boeing parts, all the spark plug tips for a major oem, surgical instruments that are very tiny.... quite an array.
    What was pretty neat was watching him use the instruments he uses to measure thickness precisely....he was actually able to show me the wear on the contact side of an old thick shim, one we had brought as a core to him to grind down....he could measure the "dip" in the surface in the middle from contact with the cam. The shims float and rotate in the head, so the wear pattern is circular on the surface, and very hard to detect visually, but it is there.... and sure enough, it was measureable by this guy.
    In medicine I think we would say "measureable, but of no clinical significance" about the "dip" or wear on the one side.... but, since both sides are hardened, and the flip side is usually virginal, we grind down the "dip" side.
    Huge electro magnetic trays hold the shims down, and enormous grinding wheels make multiple precise passes as water sprays the whole thing down. Cool stuff. Completely computer controlled stuff....
    If anyone has Volvo connections, please report back what thickness shims they sell new! It would be very good to have that in the thread.
    Alex Lipowich
    xyobgyn on AOL
    Trying to make the world a better place with 5 extra throttle bodies at a time.
  5. #30
    Dec 2002
    Lake Tyler, TX
    88 E30 M3 S65
    Are the S50 shims the same size as the S14 shims? It is common for people to use Volvo shims on S14. BMW purists say the BMW shims are better b/c they are chamfered on the edges making them easier to get out (that is the only difference AFAIK besides being half the price on the BMW shim). OTOH, I know somebody that kicked out a BMW shim and destroyed a 25k race S14. Maybe shims that stay in are better? Besides valvetrain weight, that is a good reason to go to a shim under setup (but really makes valve adjustments a bitch).
  6. #31
    Jun 2001
    Reston, VA
    88 M5 FOR SALE, E92 335i
    Quote Originally Posted by gobuffs View Post
    Yes, same stuff, except for the thickness differences noted earlier. I did find that the Volvo shims are harder to get out, since they have much sharper edges.
    BTW - how does an engine kick out the shim?? Sounds like he may have had valve/piston contact to cause such a phenomenon. Those shims are stuck in the bucket with oil pretty hard sometimes.
    James Muskopf
    RRT Racing
    DC Metro's premier BMW service and racing facility
  7. #32
    Dec 2002
    Lake Tyler, TX
    88 E30 M3 S65
    That is what chamfered is...slight taper of the edge.
    Dunno...he was using 308 or 320 cams. From what I have heard it is rare but not uncommon to kick out shim. I think it stopped the cam from turning so then there was piston to valve contact. But then the question is...chicken or egg?
  8. #33
    Z1, M3 LTW, 228
    OK...don't label me a smart ass
    Did anyone notice the oddity here?
    Purists claim the BMW part better because its chamfered and easier to get out.
    Racers complain that BMW ones "shoot" out.
    Possible idea? Racers SHOULD use the Volvo parts... struggle to work with, but stay in better?
    Food for thought.
    It is tough for a gyn doc to think outside the box... but I try to.
    Pun intended.
    Alex Lipowich
    xyobgyn on AOL
  9. #34
    Australia
    1994 M3
    interesting....what model Volvos do these alternative shims come out of?
    cheers, Alan
    1/4 mile-12.92 @ 108.64mph-NA 3.0L m3 daily driver
  10. #35
    Dec 2002
    Lake Tyler, TX
    88 E30 M3 S65
    240 Iirc
  11. #36
    Jun 2002
    Exeter, UK
    94M3 95M3 94325is
    Quote Originally Posted by M3 Euro LTW View Post
    Pun intended.
  12. #37
    Canada
    E30 M3, E34 M5, E36 M3
    Arrow
    1. BSH
    2. Phillip A
    3. ixm3
    4. SG_M3
    5. morerevsm3 (Australia)
    6. Thewiseguy
    7. JamesM3M5
    8. Shock(/\)ave (Canada)
    Though I'm presently terrified of working on this engine myself with my complete lack of experience in doing so and no guides to work from, I plan on learning soon enough and will want one of these tools given how long I plan on keeping this car.
    Quote Originally Posted by BSH View Post
    (FYI - the S50 tool is still cheaper than the S14/38 tool.)
    Does anyone know if this tool would work on the S14 motor?
  13. #38
    Jun 2002
    Exeter, UK
    94M3 95M3 94325is
    Quote Originally Posted by Shock(/\)ave View Post
    Though I'm presently terrified of working on this engine myself with my complete lack of experience in doing so and no guides to work from, I plan on learning and will want one of these tools given how long I plan on keeping this car.
    I will get in touch with my source and tell him we are interested in 8 tools. I'll update this thread as soon as I hear from him.
    Paul,
    James mentioned above that he has successfully used the S14/38 tool on the S50 motor.
  14. #39
    Canada
    Question
    Right, so it's safe to assume it will work in the reverse with the S50 tool on the S14 motor? I would love to know what the difference between the tools is given the apparent price differential if that is the case.
  15. #40
    Mar 2001
    FL
    E36, E46
    I might want one
    '99 Estoril Blue + Dove Grey ///M3 coupe
    '04 Jet Black + Cinnamon ///
    M3 coupe
  16. #41
    Jun 2002
    Exeter, UK
    94M3 95M3 94325is
    1. BSH
    2. Phillip A
    3. ixm3
    4. SG_M3
    6. Thewiseguy
    7. JamesM3M5
    9. Vitolo
  17. #42
    Victoria, BC
    1999 M3 Evolution
    I need some shims
    We have got my engine open to adjust the valves and I need some shims. My dealer does not have any S50 shims in stock so I just want to confirm my options.
    S14 shims - are they the same?
    Volvo 240 Iirc - are similar and will work just fine?
    What about the S54 shims. Do they work?
    I need 2.80, 2.85, and 2.90 thick shims.
    Here is a post from my mechanic on my clearances.
    Attached Files Attached Files
  18. #43
    Canada
    Question
    Have you made any significant progress toward obtaining a number of these tools for those of us who are interested?
  19. #44
    Jun 2002
    Exeter, UK
    94M3 95M3 94325is
    I have bad news. The S50 tappet depressor tool is NLA. I was hoping to hear good news from another supplier and he also confirmed that the tool is NLA.
    I was interested in acquiring the list of tools for a cam or HG swap and almost every tool is NLA.
    Can someone please explain why BMW would discontinue tools for maintaining these engines? It's not like they won't require maintenance for years to come.
  20. #45
    Avoca Beach NSW Australia
    1995 EuroM3 92 Range Rover
    Has anyone got drawing and dimensions for one?
    It should not be too hard to machine a bit of steel strap, and weld a couple of channels to it.
    Regards Philip A
  21. #46
    Australia
    1994 M3
    if anyone has .DXF file of one, I will laser cut some out of spring steel
    cheers, Alan
  22. #47
    OR next time someone has an S50 apart for tappet check, measure
    A distance between the edges of the tappets O?O
    B Width of tappet rim ie between edge of tappet and shim.
    That should be enough to make a tool.
    I should have done it last time I checked them.
    Someone suggested in a British forum that an Alfa tool fitted. As Alfas were a flop in Australia, it is unlikely that the tools would be available here.
    Anyone own an Alfa?
    Regards Philip A
  23. #48
    Dec 2002
    Lake Tyler, TX
    88 E30 M3 S65
    I can borrow an S14 tool and try. I'll try to get it at Ofest.
  24. #49
    May 2005
    Melb,Australia
    3.0 Euro M3, 328is track
    Im interested too, if anyone finds another option...
    Vic, australia
    BLAKE AuST
  25. #50
    Canada
    Question
    The S14/38 tool is listed on eBay for a "buy it now" price of $94.50 - $119.95 plus shipping: CLICK
    Should we attempt to get a quote for group pricing on the S14/38 version of the tool?
