I just wanted to update everyone. I just looked up these tools and the shim kit on the updated etk. They are the same part numbers for the s14/s38 and the s50b30/b32. They tappet depressor and the shim kit are Identical, and DO work. I just tried this last night on my car.
FYI, the s50b30/32 part HAS been superceeded to the s14/38 tool.
The Original GoldMember!!
Ill post them tomorrow
The B30 shims are in the thicker range, where the B32 shims are typically thinner than what come in the S14/S38 shim kit. For the B32 owners, you'll have to either order a handful of shims in each thickness in the high 2,--mm range, or check clearance, measure shims, and order the correct shims for your car. They are around $8-9 each from the dealer, so ordering half a dozen shims of each size (0,05mm increments) from 2,50mm to 3,20mm gets expensive very quickly! I think with all the B32 engines I have around here, I may just have to suck it up and do that.
James Muskopf
RRT Racing
DC Metro's premier BMW service and racing facility
I needed a bunch of shims between 2.70 and 2.90 and all of the dealers around here and in Seattle only had shims over 3.00 in their kits. I ended up ordering some from Germany.
part number for the tappet depressor is: last 7 is, 11 3 170
I need to bow out of the gb. Already have an s14 tool. (for which there are aftermarket suppliers).
-MJ
I think the GB is dead.
I bought an s14 tool from Samstag.
Regards Philip A
Interesting info in here, missed this up until now
It's almost impossible to get tools here as well, but if S14 works then it should be easy
E36 M3 S50B32 daily - E36 M3 S54 trackcar
They Say Money Talks, All Mine Ever Says Is Goodbye
I know this is an old thread. and I think the answer is already here. I would just like to get some clarification if it is possible. Can the BMW tool 113170 valve depressor for the s14/s38 be used successfully on the s50b30 euro engine? Does anyone have any real experience with this, so I can be sure before dropping 125$ on the tool.
yes.
The S50B3X valve tappet tool is now available for special order from your BMW dealership with an active part number of 83300491053.
It is definitely the exact same tool with the original tool part number printed on it:
https://www.turnermotorsport.com/p-1...uine-bmw-part/
As an added bonus it's less than half the cost of the S14/S38 tool as of this post, though I ordered both tools to service all of my cars. Get yours while you can!
Just tried to order this item 2 weeks ago, but NLA since August. No new # know at this moment.
1998 BMW M3 3.2 Cabrio Alpinweiί III on Schwarz German spec 1 of 12
SMG SRA PDC AUC OBC GSM HK UURS IHKA FGR MFL
IG: https://www.instagram.com/iflok/
