Alright, so I've got the old UUC BBK on my supercharged 328i that I will be using for an upcoming time attack in street class on Bridgestone RE01R tires with TC Kline coilovers(450/500). The issue is that the pad FMSI # is a D531, stock 3000GT VR4 pad, it's a pretty beefy pad but there aren't many street/track pads available for it from what I've found. The choices that I am aware of are:
Carbotech AX6
Carbotech XP8
Cobalt Friction XR3
Cobalt Friction XR4
Hawk HP+
Hawk Blue
PFC Z-Rated
PFC 01
Porterfield R4S
Porterfield R4
EBC Yellow
So any recommendations between these?
Dont go with the HP+, I have them on my car now. They are a squeaky, dusty, over glorified autocross pad.
Pfc
Ashley
I have limited experience but the PFC Z-Rated pads have performed flawlessly for me. I've done 6 DE's and about 1000 miles of street driving with them over the last 4-5 months and they've been excellent.
Again, I don't have a lot of experience with the other choices but I'm very impressed with the Z-Rated pads.
Don
Which track are you going to be running at?
Skip the R4S as that is a street compound. same w/ the PFC-Z
HP+ is ok, but for heavy track use they wont be very good. This is a TimeAttack so you should be ok. You can also consider Carbotech as well.
Will you be swapping pads out for the event? If so, Id leave whatever you have for the street, then get a more aggressive track compound for the event.
Here are some other options and their associated retail prices:
HP+: $100
Hawk Blue: $140
PFC Z: $92ish
PFC01s: $200
R4S: $107
R4: $167
Carbotech XP8: $159
Carbotech AX6: $148
You running street pads in the rear? Stock E36 fitment?
Sup Eric,
Are those pads you listed all available in the D531 fitment? Right now I have no pads at all for the front. The calipers are out being rebuilt but the rotors are still alright. My plan was to keep the same pads for the track as I do for the street. As far the the rear pads go I believe they are stock, but I'm actually really not sure but they are definitely stock fitment. Front pads are easy enough to change with this brake kit so I'm not opposed to swapping pads in the front but I'd like to keep the same pads in the rear at all times. This car is my daily driver but I also use it for DE's and Time Attacks. My track of choice is the Shenandoah Circuit at Summit Point but will most likely make a few more visits to VIR.
Those Carbotech AX6's don't sound too bad...
I just ran Corbo XP10s and really liked them. Im going to run Cobalt XR3 pads next.
I have a lightly used set of Hawk Blues if you want to give them a try $75 shipped
Doug (BMWCCA HPDE Instructor, Respect My Authoritay!)
1999 Titanium Silver M3 track Rat
2017 F250 Powerstroke
2004 M3 Widebody, LS
Eric- Are you saying I could drive around daily with XP8's?
CAbimmer- Do you have this same brake kit?
Do you have the XP8's in stock? Could I get a set by Saturday morning? Selling my Z on Friday so the BMW will be my only car. Assuming the calipers get shipped back to me by then the only thing missing would be the pads.
Yes, I have the same kit. Have used XP10s on the steet for over a year full auto-x season and 5 track days. they have about 25% left. Noise is not that bad but they dust alot. Car only gets driven to and from the track. with a few runs to the store to keep my battery charged
Hi. I have nothing to add to the discussion, but I was wondering: would you please let us know what your suppliers are for these pads? I did an extensive search for just the same thing last night, and I could only find the Hawks you mention and the EBC pads. Thanks!
AX6's won't handle your power level on track. My Nissan was destroying those pads once they got a little wear on them.
I'm on street tires and with about 260-270rwhp on track they lasted about 2 laps before transferring horrible amounts of pad material. I have 300ZX brakes on my Nissan, so stock brakes on a 320bhp 3600 lb car on a 320-330bhp 2500 lb car.
After wearing about 10-20% of the pad off, they never withstood track abuse after that - just transferred pad material. New rotors, ducting, letting other people drive the car - nothing helped. They were just not up to the task of that much power.
Put on the XR3s last night. Running them at a BMW CCA race school at the end of the month. I will post findings. The quality on the Cobalts is smoken. They look great. I did have to run a drill through the pin holes for mounting the pads because the coating was a little thick.
Got them from
www.vtmotorsport.com
So, I can't be the only one having this problem.... (sorta OT, but related).
I have these on my E46 M3, and it seems I go through cotter pins and the long pins that hold the pads in like crazy. It is a bit scary, I check them before each session, but there has to be a better way...
What are you guys doing? Buying 200 cotter pins from SSBC and call it a day? I have not found a good replacement at Lowes or Home Depot - they have some that are much thinner, and last about as long as it takes to put them on...
Or am I the only one with this issue?
EX-NASA SpecE30 Racer---NASA Florida Certified Instructor
Does that kit use a standard Wilwood caliper? If so, I would stick with Wilwood pads. I'm very happy with the Q-Compound for street and light track use. It would make a good time-attack pad.
If you want something more aggressive, there are plenty of other compounds available. Just talk with a Wilwood rep and figure out what's best for your needs.
Among the pads you've listed, I have personal experience with around 50% of them. I would choose Carbotech XP-9's if you're running street tires.
Emre
Emre (OO=[][]=OO) 318is
sorry to bump this thread, but I installed my ssbc kit about a month ago, but it came with racing pads, and I want to buy street pads before I start "destroying" the rotors with the racing pads and I need to get rid of the squeakiness
which pads would any of you recommend for only street purpose? and where can I buy them?
this is for a 332mm ssbc kit
R.I.P. Louie: TehPandaShow gone but not forgotten
