Results 1 to 6 of 6
Thread: Sun roof won't retract
    Townsville, Queensland, Austalia
    1995 e34 525I
    Question Sun roof won't retract
    Just wondering if anyone can shed some light on my problem, My sunroof will tilt up and will lower down in the roof but will not retract back into the roof, It seems to get jammed on the left hand side and twists. As far as i can see the linkages are all still connected and there is nothing stuck in the track. Any help would be greatly appreciated. Thanks.
    Westchester, NY
    2002 M3
    Don't force it, If it's anything like the one on the e36 break it apart and lube it, maybe it's just dry. And make sure both lever are at the same exact position. One of them being a couple mm off can make them get stuck.
    (northeast) Indiana
    97 740iL & 06 X5 4.4i
    Does the e34 sedans have a sunroof reset/re-initialize procedure? If it's like the e39/e38 series...turn ignition on to position II...then push upward & hold the sunroof button for approx 15 sec. The panel in the e39/e38 will reset/reinitialize by moving further upward and the motor makes some noise...then everything will work as normal again.
    But I'm not sure if this works the same on the e34 5 series sedan...my Touring's dual panel sunroof works so differently that I can't go off of that.
    Good luck.
    (instruction below are from the e38 owners manual...wont' hurt to give it a try:
    (if my grammar, spelling, or sentence structure is screwed up....don't blame me...it's my dang bluetooth keyboard...I try to catch & correct the mistakes...but I may not catch all of them.)
    Q {BMW CCA Member #191509}
    1997 740iL (Arctic Silver) 3/97 mfg date <<~>> 2006 X5 4.4i (Sterling Gray) 12/05 mfg date
    (SOLD)
    1999 540iT (Orient Blue) <<~>> 1995 525iT (Alpine White)
    1991 735iL (Schwarz) <<~>> 1985 325e (Bronzit)
    1995 e34 525I
    Thanks for the suggestions, Unfortunantly no luck as yet
    Albuquerque, NM
    way too many
    Have you tried Max Fretter's fix yet? Sorry for the cryptic link, don't have html privilege yet -- damn newbies might abuse the site:
    h t t p : slash slash bmwe32 dot masscom dot net slash maxf_website slash freeyellow dot com dot html
    gale
    92 735i 5-spd
    ps Hi Q, I wondered where everyone went.
    insomnia
    00 528 sport;e34 540-RIP
    "Never let the bastards wear you down!"
