Page 24 of 24 FirstFirst ... 1415161718192021222324
Results 576 to 578 of 578
Thread: Settings in GT1/DIS to use the INPA Interface ?
  1. #576
    Dec 2007
    Queensland, Australia
    E70 3.0sd E21 323i
    All the settings are as per post #800 on page 32 of the DIS Success thread and the READ THIS FIRST.pdf. Configuration of DIS should be Fister as translator, vm set to not run, dsm and nsw set to run and restart EDIABAS from inside DIS to confirm the settings. What makes matters confusing is all of the "how to" videos on Youtube promoting use of Diaghead emulators etc., which are just blatantly incorrect and serve only to slow DIS down to a crawl and promote confusion. Setting up DIS on VMWare is not hard - it just takes a long time and often taking shortcuts by installing pre-configured machines with unknown settings causes more extra work than it saves. If you want to do some memory management on your virtual machine to ensure that you are not running shy on resources, it is worth defragging the virtual machine drive as this also speeds up operation of the virtual machine.
  2. #577
    Mar 2011
    CA
    not a bmw
    Its pretty easy once you follow everything
  3. #578
    Jul 2004
    Houston, TX
    36 Cylinders
    Boosting that post count, huh.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
