I had a GC Track Kit on my E36 M3 with 500lbs springs all around. I had that for about 6 months. I liked the kit because i have never driven on any other setup than stock. It was stiff and rough the street. I had one track day on it and it performed well. But when the deal came out on the AST Sportline 1s i sold my GC setup and went for the AST sportlines w/ Vorschlag camber plates and 400lb springs all around. Off the bat i felt the difference. On the street it was so much smoother over bumps and other imperfections and thats thanks to the "helper" spring on the setup. I took this out to the track and i felt a lot more comfortable at the limit everything was smoother and mor balanced. Hopefully thats helps but i am very happy with the change.
Thank you for that GREAT feedback. The set up I'm considering is 350/400 so I might just upgrade the front to a 400 and call it a day.
Do you still have this current setup? Does it make any weird noises like some of the TCK products?
*Edit*
Have you ever driven a car with TCK s/as or d/as equipped and how does it compare to the Sportline 1 setup?
Brian Hanchey
www.ast-usa.com
AST Suspension - USA
For 2012, AST Suspension - USA is a proud to support the following series:
Official supplier to the GRAND-AM Continental Tire Sports Car Challenge
Official sponsor of the Pirelli World Challenge Series
Contingency sponsor to SCCA and NASA amateur racing
After a test drive, I'm very impressed with the Sportline 1s. Great kit. Looking forward to putting it in my car.
Here's a question:
The used set up I'm buying is 350/400. My friend has some Eibach springs 600/250/450.
6" tall 2.5: wide and spring rate of 450.
Will I be able to run these on the Sportline 1 set up? Are the rear and front springs interchangable? In a perfect world, I would put the 400 rears up front and run the Eibach 450s and have a 400/450 set up.
Feel free to flame away as this is a very noob question, I know. Thanks in advance.
i think AST's are 60mm
Sean
Yea they are 60mm.
2.5 inch = 63.5 mm so they should fit the spring seat on the height adjusters.
Yes. They are 60mm, but you can always run 2.5" springs. We have some plastic 60mm-2.5" adapters that you can run to take up the slack on the bottom perch if you end up having any noise. Probably not a big deal.
For Sportline 1s, The fronts could be run on the back, but the backs don't work on the front. The fronts for SP1 are probably too long for the rear, but that might be personal preference. You might be OK with where it sits.
Brian Hanchey
www.ast-usa.com
Any more comments from people that have changed from TCK's DA's to the AST 4200's?
I'm at the point now where I need to make the plunge and both are looking very good for some different reasons.
I'm building a car for regional and national tour level autocross as well as track days and the ever popular 'I just need to get away'.
Thanks.
If you are on the fence, one more thing to consider is the customer service you will recieve when dealing with Vorshlag (AST dealer). I always got a very quick answers to my questions. I needed suspension advice and they went above and beyond to help me with everything. In my book that accounts for a lot.
Can anyone speak about the springs that come with these kits?
I have done quite a bit of research and I like what I see about the shocks, I just haven't heard much about the springs they come with, other than that you can choose the rates. Does AST outsource them or do they build them? Any user and or dist. input? Is there a link I am missing?
Thanks,
Eric
They are built in Europe for AST. It is a common manufacturer for many companies out of Europe. Things I do know from testing and discussions:
1. They actually are their labeled rate with very little variance. Many springs are +/- 3-5%.
2. RRT put them on their spring rater and found them to be similar to the popular brands on the market as far as travel and holding their rate through the travel range.
Those are the key factors with a spring. Does it have the rate it says it has and does it keep that rate through the travel? Weights are similar as well.
Brian Hanchey
www.ast-usa.com
I can concur that Vorshlag's customer service is top notch. I get emails at hours no one should be working. They are always willing to talk setup and allow you to utilize their technical knowledge. Brian and Terry are really working hard to make their customer's happy all while having kids and trying to race all year around.
Rob
'08 MCS R56
'06 STi #92 STU
'99 M3 Coupe STU - Sold.
For Sale:
Pair 12mm Rogue Spacers 5x120
you can use any brand 60mm spring.
Brian Hanchey
www.ast-usa.com
The rear ride height adjuster for an AST kit is designed for a 60mm spring. It is about 2.36". I'd be surprised if you had 2.25" springs on our perches because they don't fit when installed as designed. However, if you unscrew the threaded piece of the perch off the platform, turn it over and reinstall, you can run a 2.25" spring.
Brian Hanchey
www.ast-usa.com
Interesting...
... I've got 2.25" springs on my rear adjusters. They slid right on.
Chris
97 M3
94 325is
12 Jeep SRT8
75 degrees here today.
Each 2.25" spring is different. I took the safe answer and said they don't fit without turning them over. For instance, Swift calls their spring a 2.25" and it is exactly 60mm, pretty different. The AST adjuster is 58 mm OD so if your spring is actually larger than 57mm (2.25") then it will work. I tried our tender/main spring adapter on the 2.25" spring I have and it didn't work. Not close enough. Some springs will vary though.
Brian Hanchey
www.ast-usa.com
Don't get me started on this weather stuff, I've had it with the fluffy white stuff that keeps coming down every couple of days and makes my commute rather annoying. I'm just glad we have a 40+ degree day finally. I may break out the bbq and wear a t-shirt to celebrate.
Carlos.
FMJ Motorsports
"not everyone is a princess like riley"
[16:04] spg383: my vagina gets cold below 40
100 pound spring rate change is nothing especially on the rears. Most people will feel this change going from a twin tube shock to a monotube like AST. Even with the same forces on a dyno plot, they do feel different in the real world.
Of course there are monotubes out there that have chosen high compression valving and nitrogen pressure. Those do feel harsh. You should see some independent reports possibly next week about a particular twin tube, stock spring'd car that went with ASTs and felt it rode better as well. Comfort and performance can be accomplished.
Brian Hanchey
www.ast-usa.com
