My experience is very much the same as what Terry has relayed.
TC535i, I don't think the rear sways will help once you're out much over 200-210 RWHP. The problem comes from power application moving the rear wheels to toe-out. The rear sway bar will definitely help with rear camber, as will stiffer rear springs. People need to remember though to just go as stiff as needed on spring rates, anything more and you also lose traction.
Neil, I'd suggest 1/8" rear toe-in (total) as a starting point for any from stock to 220 RWHP. If you've got much more than stock and are finding the back-end too tail-happy on corner exit, but fine everywhere else, than try moving closer to 1/4" rear toe-in (total). If your over 230 RWHP than 3/8" might even be good. I like it anyway.
Although I'm not able to get as much negative camber as I'd like (Terry, I've been extremely busy but we'll need to talk and "put our heads together" to see if there's something further that can be done). Like Danny318, I'm not getting all the front camber I'm after. Only getting -3.5° front camber all the way in. That's OK, but I'd really prefer about -4.0° with my 265/35/18s (BFGoodrich g-Force R1), although the pyrometer is so far saying we're close to where we should be, there is more to be had.
I approached things only slightly different in that my initial
alignment settings were my track setup (then my street setup - if I'm going to compromise the street is where I'll do it
First - I do my
alignment setting with me in the driver's seat as the E36/E46 suspension geometry is such that you loose camber on compression and me being at 200 lbs, even with 550lb front springs, the car looses approximately 0.2° front left camber when I'm there versus when the car is empty. To compensate for this and not have to run different positions left to right, I shim my left front strut (at the hub mounting - only a little if using OE length bolts) to match the right with me in the car and the plates set to the same position. No need to get overly fussy, just close, as all these setting change slightly once you drive/run the car.
- Track
- Camber
- Front: -3.5° (this is with the camber plates moved in to max travel. At the moment, my car gives slightly less camber than the -4.0° I'm looking for)
- Rear: - 2.5°
- Toe
- Front: 0" (will be switching to 1/8" out)
- Rear: 3/8" toe-in
- Caster: maximum. Don't recall the figure but think it's around 6.5° (had to reduce it slightly to maximize front camber)
- Street
- Camber
- Front: -1.95° (second mark in on driver's camber plate for my car. We then set the passenger's side to match and scribed & sharpied it)
- Rear: - 2.5° (untouched from track setup)
- Toe
- Front: 1/4" toe-in (the switch to 1/8" toe-out for my track setting will adjust this to a tire friendlier 1/8" toe-in)
- Rear: 3/8" toe in (untouched from track setup)
This setup woks well for me running RD sways full stiff front and 3/4 soft rear, springs 550lbs-F and 650lbs-R, bushings, etc., etc.
I run the 3/8" toe-in on the rear to keep the tail-end planted on corner exit. Currently have a problem with my piston rings not seating so we've not been able to tune the engine, but even with that, I expect we're around 240RWHP so that's why the 3/8". The 265's are still breaking loose around 4,000 rpm in second gear in a straight line on most courses,
so I figure we're in that range. (New pistons and rings
during our 3 week break in July will fix the ring seating and tuning will bring more power)
BTW Terry, we are now 3 for 3 in class wins (B/SP) with 2 FTDs for 2008. Running the AST 4100, Mason Bar, Vorshlag motor mounts, etc.
Just did a Regional on Sunday. Number 3 of the three, and missed FTD to a full race C-Mod Porsche 914-6 on a choppy course that was nice but lacked flow and had several very constricted sections that allowed a C/SP Miata to get within 0.174 seconds and a C/SS Miata to get within 0.860 seconds of our time. We've got a real problem locally with people, mistakingly thinking they can build the PAX factor into the course design
Doesn't work as it misrepresents not only run times but destroys car classification.
That's my rant on Go-Kart course design.
Regards, Alan
