Oh, well I like teh amount of castor, so I'll just be happy with -3.0ish
Thanks guys.
'95 318i - DASC Supercharged - 269° Camshafts - 30lb injectors - Ostrich 2.0 tuning - Coil On Plug conversion - 11lb flywheel 228mm clutch - AST 4100's,
Terry, does it sound about right that you gain about a degree of camber for every 2 marks on the plate?
I just picked up a set of K1s - 17x8.5s all around. ET40. (I think, could be 44)
My 10mm spacers are not enough to clear my coilovers. Is anyone else running these wheels with this suspension? Are you using a 15mm spacer? Also, please specify if you're running camber plates as I am not.
I see you have 4100s. I'm running the sportlines (Is there a difference as far as fitment is concerned?)
My RCs are 8s in the front with an offset of 38 and they BARELY fit with a 10mm.
K1s won't work with my 10. I'm sure it'll clear with a 15 but I'm worried about rubbing on the outside fender since I'm not running a lot of negative camber.
Yea big difference - I could be wrong, but the sportlines have a helper spring correct? The 4100's are pretty much the same except no helper, so my height adjuster is at the top of the threaded part. I'll get a few pics when the wheels come (hopefully friday) if it fits. I'm 99% sure I'll be fine though.
^^ Good luck to you. Hopefully others will chime in.
I'm also running 17x8.5 Kosei K1s. Because of my front brakes though I already run a 10mm spacer up front. 235/40-17 RA1s for track days and 245/40-17 Pilot Sports on stock 8.5" wheels (w/15mm spacer). I do use camber plates. To me if you go with coilovers you should also go with camber plates otherwise what is the point? It's like getting big brakes for street driving.
My adjusters are at the very top as well ~13" from ctr of wheel to top edge of front fender for ride height. Next set of springs will be longer so I have some ability to go higher if I wish.
Carlos.
I am running 4100 w/camber plates, 17x8.5 k1s with 235/40 Hankooks and no rubbing I think . I noticed that when the wheel is completely lifted in the air (using a jack) and I try to spin it by hand, it slightly rubs against the adjustable sway bar link mounting bracket in certain wheel positions. This happens on both fronts. When the car is lowered to the ground though I don't believe it happens anymore, at least I couldn't hear it. I tried pushing the car with the engine off to test that. I haven't tried adding camber yet, don't know what that would do to that situation. Should I be running a spacer up front?
BTW, my sway bar adjusters (with stock links) are currently sitting 5 threads higher than what M13 has his set at in the picture, is that ok? (12.75" f height)
I have Sportlines. From the previous reply, apparently, there is a major difference in design.
You might try running at least a 5mm spacer if you are rubbing. What you could also do is apply some painters tape on the inside of your wheels, drive around and see if any of the tape has been sheared off to determine if there is contact.
Yeah, but the view is so nice. You can almost see the whole course layout from the up there, and I don't have to PhotoShop my pics to ride over cones.
As mentioned above, in a previous post, I felt that was part of the problem.
That may be part 2 of the problem. My car is a 95 (96 3.2L OBDI conv). I'm running the TC Kline Delrin Offset bushings. They don't make a centered Delrin bushing. Also not sure where going to the centered bushing would locate the wheel as I think the dimensions on the 95 vs 96-99 arms are different, they've got different part #s at least. Do you know if that's the case?
I went to the TC Kline bushing as only their's and CG's have a lip to keep the bushing from pushing out the back under braking, etc. Ran into this problem a few years ago and had to jack the car up and push the bushing back into place between every run, as it would pop out after about 1 1/4 runs.
That's the plan for this weekend. We've decided to not instruct at this weekends BMW School to allow some time for rolling and dropping. Just no other time available. Won't be using the Saws All though. I really don't want to cut up the car.
2008 Canadian National AutoSlalom Champion - BSP
2009 Canadian National SoloSprint Champion - SGT2
(the car and my co-driver, not me)
95 M3 3.2L OBDI (M-Perfect ) http://www.cardomain.com/ride/2078238
was 3.0L (236 RWHP) now 3.2L, well modded - Arrest Me Red
Sponsors: Amsoil, BFGoodrich, BimmerSpecialist.com, Corbeau, Dr. Vanos, StopTech VAC Motorsports, Vorshlag/AST, Zeckhausen Racing, 3M-TrimLine
When only the best will do!
This may not be the proper way to set them, but I adjusted my sway mount bracket so that the sway bar (the mount points on both sides) are parallel to the ground. Remember, I think the threaded part on a sportline is not the same as the threaded part on the 4100's but again, could be wrong.
I set mine to be the same distance up from the bottom of the strut as the stock parts, as a starting point.
Ideally the swaybar arms will be parallel to the ground when the car is sitting on the ground, to give the best range of motion and linear leverage.
Chris
97 M3
94 325is
12 Jeep SRT8
Yea - I pretty much mounted them, and guessed at how far they had to go up. I measured from bottom of the strut to the top of the hole for the sway link and made sure both sides were even. So far it seems to be in the perfect spot.
The problem with setting it the same as stock is that the car's chassis is lower relative to the entire strut assmebly - I thought of doing this, but would have ended up with the tab way too high.
Thanks for the idea Mr. Watts. As usual, you're a good source of common-sense.
Perhaps,that's why they say 2 heads are better than one.
Dahhh! Hadn't thought about making them. Through my co-driver, I have access to all the equipment needed (even hydro jet cutter, CNC, etc.) including the delrin, so that's not a problem, we can fabricate most anything stainless, aluminum, etc. Just got off the phone with him about an hour ago when we decided to fab up some derlin steering rack travel stops to stop rubbing on the fender liner.
I just need to figure out if there is actually a difference in the dimensions on the 95 vs 96-99 arms that the bushing affects, and if it's significant enough to create a problem. Anyone know for sure?
Regards, Alan
Alan, bimmerworld makes a Delrin centered FCAB.
#71 SM
04 Silver Grey M3
95 Arctic Silver M3
03 X5 3.0L Titanium Silver
07 GX470- Silver
Molon Labe...
Excellence is a habit, not an act.
Geometry wise if you put an offset bushing on a car that was meant for a centered one then the wheel is pushed forward in the wheel well. So if you run big tires they may end up rubbing. On a buddy's race car running 18" slicks it was enough to make contact with the rear edge of the bumper cover.
I hung onto a set of centered delrin ones from BW but I believe they are NLA. They had a piece of cf as a backing plate to keep them in place. Another thing folks do is drill and tap the stock bracket and insert a set screw to keep the bushing in place (mostly from rotating). I didn't find it necessary to do that on mine.
Carlos.
Thanks. I'd missed that, it defaults to the offset bushing but they do show the centered one in the pull-down listing/pricing.
Thanks Carlos. It appears as though I have some room to have the wheel move back (going from 95 car/arm/bushing to 95 car/arm with a 96-99 bushing) but don't know if there is enough.
This one below is with different suspension my street rims and my old street tires (225/40/18 vs current 245/35/18 street and 265/35/18 track) so there's a little less room now but it does show that the wheel is well centered in the wheelwell with the offset bushings so one would presume going to centered will move the wheel back toward the doors and away from the front bumpers, just wondering if anyone knows if there'll still be enough room.
Still listed, but that doesn't necessarily mean still available, sometimes it can take awhile for internet stores to get updated.
