Page 4 of 117 FirstFirst 12345678910111213142954104 ... LastLast
Results 76 to 100 of 2916
Thread: The Official Auto-to-Manual Transmission Swap Thread
  1. #76
    Mar 2003
    Portland OR, Winona MN
    88 M3, 90 M3, 91 318is
    They are interchangable! You will need to get an M3 slave cylinder though.
    Dets, send me an IM when you get a chance...
    Joe
  2. #77
    Mar 2002
    Kansas
    Estoril 1999 M3 Vert
    Quote Originally Posted by funkmasta
    Joe
    Thanks for your help funk! I have ZA cdrom and it doesn't talk anything about cruise control? If I remember right you have done the swap. Have you or anyone who has done the swap had issues with the cruise control not working?
    Thanks again for your help!!
  3. #78
    Mar 2003
    Mine was non functional, as was all the others I helped with. I dont really know what it is controlled by... I would assume the clutch sensor, or?
  4. #79
    Aug 2001
    S.CAL
    98M3 4d
    My mechanic couldnt get it work either....we r wonderin about it too
  5. #80
    Oct 2002
    Chicagoland
    '00 528iA, '01 325iA
    Lightbulb Cruise wiring
    I find it hard to believe the ZA CD-ROM doesn't address this...
    Don't people like their cruise control?
    Read post 154, find an auto (might you have one?), measure the mentioned pins on the CCM and tell me (us). I'll be the guinea pig...
  6. #81
    Mar 2002
    Kansas
    Quote Originally Posted by al_r
    Well, I did a search on the program for the word "cruise". There were no results. So I don't know what the key is... I have an auto al_r, what do you want me to do? I am afraid I am not sure what you want me to do from your post.
  7. #82
    Oct 2002
    Chicagoland
    jimmyjoe - Thx for the offer - do you have a meter and a Bentley? Let me get my thoughts together and I'll PM you. Maybe we can sell the info to ZA...
  8. #83
    Mar 2002
    Kansas
    By meter do you mean multimeter? if so yes, and yes. Lemme know what you figure out..
  9. #84
    Nov 2003
    Bethlehem,Pa
    1994 325ic 1992 a2 vr6
    Drive shaft ??
    If using a ZF trans do you need a drive shaft from a zf trans car OR can any 5 spd driveshaft from an e36 be used?
    Mar 2003
    Quote Originally Posted by str8 gone
    Yes, the ZF trans use a different driveshaft than the Getrag trans!
  11. #86
    Nov 2003
    Bethlehem,Pa
    Thanks for the reply
  12. #87
    nyc
    98AMG C55,99M3,412whp 95 AWD Eagle Talon Tsi
    Is the 4bolt drive shaft from an auto M3 different than the DS on a manual M3?
  13. #88
    Aug 2001
    S.CAL
    98M3 4d
    Help guys! I couldnt pass the test only smog check because the tranny error were all over the computer since it cant detect any automatic transmisson on the car. Did anyone face this problem yet? What is the solution?? My registration is over due now please inform me if anyone know about this problem. Thanks in advance!
    aaron
    98M3
  14. #89
    Nov 2002
    Nashville/Atlanta
    '98 328i/4
    You have to get the computer reset.
    1998 328i/4 Boston Green
    X-Brace, Eibach Pro Kit/Bilstein Sport, M3 Rear Sway
    BMW Traffic Pro - a/d/s P650.2 & 3.45is - JL Audio Stealthboxes[/size]
  15. #90
    Aug 2001
    S.CAL
    98M3 4d
    My mechanic couldnt get it reset for some reason. Is there a way to do it or a trick? my is a OBCII tho..does it make any difference? i dont know.....
  16. #91
    Jan 2002
    Los Angeles County
    RIP:'93 325i ; '07 e61 x
    Quote Originally Posted by actp16
    aaron
    98M3
    This is my greatest fear with performing the conversion - software.
    Also, the VIN indicates whether the car is auto or manual, right? Would the DMV need to be notified? How about the insurance company?
    FYI, when I spoke w/ someone from Bavarian Auto Recycling, they said that the Getrag is for non-M3 cars.
    3rd Infantry Division, United States Army
    "Rock of the Marne!"
  17. #92
    Jan 2002
    Los Angeles County
    Would a conversion also warrant a new ECU?
  18. #93
    Dec 2002
    San Francisco, CA
    M4 + CT200h
    does anyone know the LSD on a 95M3 auto? would like to know what gearing im running...thanks.
    -frKENm3 | 2016 M4 ZCP | "Your not Alive unless your Living" | Ownership: 08/31/2016 - Current
    Instagram: m.4play
    Other Cars: ct200h(daily) | E39 540i-6(sold:12-4/19/16) | AP2 S2k(sold:09-13) | E36 ///M3(sold:99-07)
  19. #94
    Mar 2003
    Quote Originally Posted by RacermeX
    No... but to do it "right" you will need to remove the AT wiring harness (which i believe is intertwined with the engine harness).
    the diff ratio for a 95 M3 auto should be 3.38
  20. #95
    Mar 2003
    Birmingham, Alabama
    1995 M3 LTW
    95 M3 Manual - 3.15
    95 M3 Auto - 3.23
    96+ M3 Manual - 3.23
    96+ M3 Auto - 3.38
  21. #96
    Dec 2002
    San Francisco, CA
    M4 + CT200h
    diff
    is there any other way to find out if a differential is a 3.38 or 3.23 other then the bar code& the last three #s?
    i know i for sure have a 3.38 diff in my garage because i helped uninstalled it out of a 974dr auto yellow M3. but the serial number on the bar fades out to white for like the last 4-6 #s...i would like to take a picture of something to help me with the sale, but do not know what to take a picture of for proof of being a 3.38
    any help?
    ken
    Instagram: m.4play
  22. #97
    Chicago Area
    95 325i,92 325is race
    Heres how to fix the cruise...
    Did this swap about 6 months ago on a 95 325i. when i bought the car, it didnt run, ( bad motor ), had no dme, and was auto. so when i did it all and the cruise didnt work, i just figured it was broke ahead of time.
    then i got to researching and thinking...
    when you ground out the park safety switch from the old AT shifter under the center console, you are essentially telling the system that the car is in park to allow the starter to turn and start the car. well, evidently, the CC ecu looks at this circuit. if you just hard wire the jump of the ground to the park sensor, the CC ecu thinks you hit the brake, and wont engage it. if you undo that jumper after the car is started, cruise works great. my gut tells me that this is essentially the clutch safety switch circuitry from a MT car. so, i just threw a temp toggle switch in that i turn on ( completing the circuit ) when i need to start the car, once running, i turn it off and cruise works. i am planning on permanantly mounting to the clutch switch which will work like oem... makeing you push in the clutch to start the car, and making the cruise dissengage when you hit the clutch, and otherwise it works fine.
    hope this helps you all out.
    wade
    wade@bimmerpower.com
    95 325i
    87 325is ITS race car
  23. #98
    Jul 2004
    mt.prospect-IL.
    m3
    What about the tranny light and the cel?
  24. #99
    Chicago Area
    97M3John - What do you mean what about the tranny light and the cel? I am not following.
  25. #100
    Oct 2002
    Chicagoland
    Wade,
    I'll chime in here, since I'm in the same boat (car) as 97m3john (we're all in IL, BTW).
    On OBD II cars, removing/disconnecting the auto trans throws OBD II codes - 'Shift Solenoid A", "Torque Converter", etc.
    On my '96, the codes do not get read by my Peake FCX, but will throw a CEL and OBD II codes like P0753, 0758, 0743 and a couple others I can't recall. The auto trans light got removed early on, but the CEL still bothers me.
    I'll try the clutch switch wiring this weekend to fix the cruise - gotta pull the console and find 'em...
    Thx for your input!
    Al
