Brake weirdness in cold, wet weather
Ok, I'm thinking that my brakes are icing up or something, but just in case something else is wrong, I thought I'd ask here...
If it's warm or dry out, I don't see this any part of this problem at all. The car brakes normally and straight.
When it's cold (near freezing or below) out and either raining or snowing, my brakes have absolutely no bite when I first start driving. I step on the pedal normally, and I feel no friction (pedal resistance is normal) for a bit (a second or two? Feels like forever as I come up on the brakelights ahead of me), and then they bite in and I stop. If I step on the brakes somewhat harder than normal, the car pulls to the right. This also happens out on the highway when I don't use my brakes very much.
As one can well imagine, it's rather disconcerting to be out on the highway in cold, wet weather, see traffic slowing, and step on the brakes to (momentarily) nothing.
I have Brembo front and Zimmerman rear OEM-replacement rotors (not cross drilled or anything fancy) and PBR deluxe pads.
Is there anything I can do, or do I just continue to use greatly increased following distances in these conditions?
Thanks!
-c///m
1997 Estorilblau M3 2-door
Performance: JC euro intake, AA Gen III exhaust, Evosport UDP, fan delete, Schrick cams, OBD-I intake manifold, 540 HFM, ASC delete, 24# fuel injectors, DiffsOnline 3.46 40% LSD, Boston BMWCCA sticker
Suspension: TC Kline SA (Suck-A**) coilovers, ///M front strut brace, X-brace, TCK RSM, Powerflex RTAB, Turner sways, Motorforce camber plates, RRT reinforced rear LCAs
Lighting: ZKW w/ HID, Euro clears, Lamin-X foglight film
Other: Z3 steering rack, SS brake and clutch lines, Stygar SSK, UUC TME, VDO Gauges, MB Quart Discus components, MB Quart Discus 6x9 triaxials, Audio Art NA 4070 280W amp
