The cable that connects to the mass air flow sensor isn't getting any power. What could be the cause of this? Is there a fuse or relay for this that may fix the problem?
Car worked perfectly fine yesterday... I go to take it out today and the car won't turn over... it sounds like the car wants to start i hear the engine cranking but it won't turn over. Could this MAF problem be whats wrong?
Your car will run without a MAF. But the reference voltage that goes to the MAF is supplied by the DME. So you could have a problem with your DME or with your EWS or with your alarm. Ive seen all kinds of werid things go bad. Did you wash your car recently, or more specific under your hood. It is common for water to get into your DME after washing the engine bay and frying it.
It looks stock.
