hi new on here and newbie got a few questions for the massive
1- fuel consumption ? what should i be getting?
2-idle speed of revs? it idles at about 790 rpm ...is that good or bad?
3-temp guage - raises up to halfway in a minute or so and never goes up past it and rarely goes down past it unless i turn the engine off...is it faulty or has it been set not to go past halfway?
by the way top car and i love it so any tips or advice for me to improve the motor?
thanks all in advance
1 - 28 city 31-35 highway
2 - Sounds good
3 - Temp should stay in middle while engine is running or you have a problem.
2001 E53 X5 - 5.3 Procharged, 4L80E RWD, Brembo, 20" alloy, EBC race, Forge, A2W intercooled, Alcantara interior, 3.62 LSD and more!
2005 E53 X5 - 6.0TT, 4L80E RWD, 20" alloy, EBC race, Forge, A2W intercooled, Alcantara interior, 3.62 LSD and more!
1996 E36 335ti - N54b30, A2W intercooled, ZF 6speed rwd, 4.10Lsd, Speedline magnesium rims, Brembo, S55 exhaust, 245/40/17-295/30/18, idrive, Forge, logic 7
1999 E36 360ti - 6.0, ls6 springs, ls6 cam, hardened pushrods, trunion, racing baffle, t56, ls7 clutch, m3 brakes, 4.10lsd
temp guage just goes up to halfway and doesnt move though ...is that right?
even in traffic jams it doesnt go up?
It shouldnt go above the half way mark, it should stay there.
anything else i should look out for on the car?
Check your vacuum lines for cracks, wear, and tears. Doing a tune-up can also improve your gas mileage. I replaced all my vacuum lines, fuel filter, oil change, spark plugs, and air filter and gained about 3-5 more miles per gallon.
thanks for all the advice i am taking it all in
Many many things i dont know. I like to offer my opinions/knowledge to those in need or want of it, i also love learning too.
thanks bluebimma
also horn has worked a couple of times and now not at all ...any ideas?
Not hardly a genius here.
Im actually waiting to here back from some people down south, there is a 328ic for sale that i want, but i want to have a compression test done first before i jump on the deal. If i do jump on it, the project should be about 95% complete by the end of the month.
bootscratch - Check the connections to your horns, the wires to them, and the fuse as well. Not too sure if it uses its own fuse, but it doesnt hurt to check. The fuse box is located in the engine bay at the windshield on the drivers side. The lid should have a diagram of the fuse box layout and what fuse does what. Just make sure its all good.
cheers
