Results 1 to 11 of 11
Thread: Is this also the correct way to remove our Vert rear Headrests?
    DC Metro Area
    Old, Slow Vert.
    From the E36 section..
    Quote Originally Posted by Eric98Sedan View Post
    yes, pulling very hard may work. Or you can pry them out with something long and stiff
    The correct way, however, is to remove the little metal clips that hold them in. To do this you must fold down the seats, remove the side bolsters, remove parcel shelf retaining trim and remove clips.
    Installation is the reverse of removal.
    The Netherlands
    DE-spec E36 328i/M3 cab
    Lol of course not.
    You need to get the headrests out before the rear backrest goes anywhere. If you would need to take it out first to gain access to some clips....
    IG:
    Mar 2001
    Ma/Ri
    95 318ic/sc +11 tsx
    the correct way to remove the rear headreat on a vert is basically push down a little on the headrest then pull them up real fast
    use one hand under and one hand over
    Aug 2003
    Louisiana
    1999 323i Vert
    When I got mine out it was pretty damn funny. They launched about 6 feet in the air as I'm madly swinging my arms to grab them.
    Seattle (Eastside), WA
    2001 325Ci cabriolet
    I couldn't get mine out for the life of me. I pulled and pryed and kicked and screamed and they wouldn't budge.
    I squirted a little bit of WD-40 down each of the stems and *POP* they came out effortlessly.
    - Chris
    New Haven, CT
    '95 325ic, 2000 A8
    If you have the rollover package....
    pop off the plastic cover off of the rollover hoops and use a prybar against it to remove the headrests.
    The Netherlands
    Quote Originally Posted by BobCT View Post
    IG:
    Dec 2005
    stranger in a stange land
    1999 328ic, manual tranny
    If your careful in not damaging RPS or headrests, sounds like a pretty slick way to get some leverage.
    The Netherlands
    Even if someone is stupid enough to try this butcher method, I'd say the fulcrum is located too close to the headrest.
    IG:
    Florence, Alabama
    1994 BMW 325ic, 2003 EB Expedition, 2004 Corvette
    Quote Originally Posted by kosta View Post
    That is how mine came out also!!
    (Stowmarket)Suffolk
    E36 1998 318 Convertible
    I had a go at the weekend, just to see if it was real hard (and to clean behind them) and mine came off ok, roof down, stood in back over headrests, wiggled them and pulled up slowly, clicked once, then click again and theyre off, wasnt easy but not too challenging
