keep coming on, flashing and staying on?????????
I have a 93 325i, this has happen twice so far. For no reason, all the interior lights (the ones that turn on when you open the door) come on while driving, stay on,
flash couple of times, then turn on or stay on?? I turn off the car, turn it back on and they turn off?? I'm confused, I know all the doors have been closed every time, I
got out and checked them. Is this some kind of OBC warning or something?
thanks,
I had that happen to me once because a friend of mine didn't shut the trunk all the way, so when I went over a bump, the truck opened a little and turned on the lights. FREAKED ME OUT until I figured it out. If that isn't the problem, check all your switches.
Aaron
Sounds like the switch or wire from the switch is shorting somewhere along the way...
It also happens if the auto-seal function of your windows or the door pin has a short or dirty contact. It will keep sensing the door is open, even when closed.
