Do you run out of hands when changing your wheels, trying to hold the wheel in place, align the holes, and thread in the lug bolts? Here's a high quality solution.
Simply thread this pin into hub, lift the wheel into place aligning a lug hole with the wheel pin. It will easily support the weight of your wheel while you begin threading the lug bolts into place. When you're done, remove the pin, torque your wheel, and move on.
Precision machined from 304 stainless steel, these pins are 4.5 inches in length with M12x1.5 threads w/ tapered end, and feature a rounded tip. Unlike plastic pins available from other sources, these will stand up to practically any abuse you can throw its way.
Our stainless steel wheel pins sell for just $19.95 each.
Keep one in the glove box or trunk-mounted tool kit of each of your cars.
Click the photo for details:
Thanks for looking!
Ken
It's been reported that people were having trouble adding this item to their shopping cart on the site. We found a strange little syntax error that seems to have been the cause for these random problems.
It's been repaired.
We apologize if you were inconvenienced at all by this glitch.
Thanks for your support!
Ken
