I think I know what you are saying. The design is just a nut with an edge that is crimped into the groves in the axle. It works I just didn't crimp them enough.
Replaced the wheel bearing and thought "while I'm at it" I'll replace the axle on that side. Advance auto had a new ones for a good price. Picture of the old vs new attached. Put it all together and the car made it to the end of my street and broke the axle. No I wasn't even on it. I think the axle was a little short and it pulled out of the joint or something. No idea. So I got to tow it home. The first time I had to tow my LS1E36 home and it was for a new replacement part. Bummer. Gave the neighbors a good show as I was towed backwards (flat towed with a tow rope in the neat little bumper hook) all the 1/4 mile or so back to the house (no place to easily turn around. Wasn't worth the bother).
Surprisingly it only took me a half hour to take the broken new axle out and put in the old one back in. I didn't even need to jack up the car or remove the tire. Oh well the car is back in business. I tell you I really crimped the nut on this time
very nice swap been wanting to do a ls-1 swap into my 325i e36 but moneys an issue at the moment with this so called "recession" thing going on, nice build tho
96' 325i 4 dr
WHY ARE THERE NO CUPHOLDERS IN THE FRONT OF MY BLOODY CAR
Going to NJ soon!
Truck - S10 flat black v8 swap
Hi guys im 19 and have owned my 323is for about a year..I love camaros but hate the mullets behind the wheels! so i have been easedropping on all of these fourms drooling over the pictures of ls1's or 2's inside of your bmw!!! Im doing research for future use and was wondering how the tach MAF OXY sensor and everything was hooked up...Is it as simple as snip and sodler?? im currently saving up and am looking at ls1s...what headers have you guys purchased? did you have to cut to clear steering linkage? what has to be done about the brake fluid master cylinder clearance?? all input is apprecieated! thank you
2010 - BMW 335i M-Sport - Lemans Blue Metallic
BMW PPK2, JB4 with NLS, Backend Flash, BMW PP Exhaust, Misc Appearance Mods, Boost Addictions Diff Brace, BMS DCIs, BMS Clutch Stop, VRSF Catless DPs
Previous:
1995 M3
1998 323is
What is generally done when swapping in a very different engine is to bring over all the sensors and electronics from the other car. In this case the Camaro/firebird. The computer o2 sensors, MAF etc all from the Camaro and are already connected to the engine. Some alteration in the lengths of the wires may be desired and for me yes I just cut and resoldered them at the length I wanted. (the tach you just wire to the BMW cluster and adjust the ECU for the right output). I suggest these websites for insight on how some others have done engine swaps.
http://www.ls1tech.com/forums/conversions-hybrids-28/
http://forums.hybridz.org/forumdisplay.php?f=84
http://www.v8rx7forum.com/v8-rx-7-forum/
oh and my thread www.ls1bmw.blogspot.com
Many of your other questions answers vary widely depending on how the builder decides to go at it. Check out peoples build threads and choose the method you like best. For me that is one of the funest parts of the project.
i have a 96 740il is the mounts you are using can they work on my car for the same motor u have an ls1 or lt1?
how can they work they are two very diff cars
