Hi Guys, can you help?
My front screen jets werent working well and i was getting dirty smear from the water that did come through.
The reservoir was full of gunge/filth so I took it out, cleaned it and emptied it. I then cleared through all the tubing and pushed a pin through the jet holes.
Now everything is reconnected and the reservoir has clean water in it but nothing is coming through at all. Not even the small squirt I had before.
I can here the motor/pump going and i checked the tubes and jet holes again.
Whats going on?
What should I do?
Thanks in advance
Gig
Get a paper clip to the holes is all I can think of. It sounds like they'e clogged with crud.
At least your motor works... Mine isn't right now. It may be a fuse, I dunno yet.
