So 13 years, 8 months, and 18 days later, I finally repaired my OWN floppy windscreen using this method. The Grainger link red97tj pasted in post #31 above is STILL good! I cut a centimeter plug off a random bolt that fit into the well where the original detent spring used to be, to prevent the new Spring Plungers from Grainger from sinking into the hole through the JB Weld, and used packing tape to create a 'form' around the open side to prevent the JB Weld from flowing out. I positioned the shoulder of the Spring Plunger nearly flush with the top of the original plastic, but protruding very slightly to ensure the captured ball bearing in the Spring Plunger had the maximum opportunity to create interference when being depressed. Everything went back together easily after the JB Weld cured, and the windscreen is now very firmly held in place, with excellent resistance to folding. Just in time for summer! Thanks goestoeleven!
'98 328 Alpinweiss Cabriolet, 150K, CD43, CHA-S634 MP3 Changer, Chromeline Interior Trim, 'Redlined' Gears & Diff, Z3 Chromed 16" Rims, Billet Front Stress Bar, aFe CAI, 'Golf Tee' Exhaust Mod, Powerdiscs, SS Brake Lines, CDV delete, JTD Underpanel, BAV Lowering Springs, Bilstien Sports, Bimmerworld Rear Lower Control Arms and Front Camber Plates, E46 RSM's with reinforcing plates, Electric Rad Fan, Alum. T-Stat Housing, Mishimoto Hi-Capacity Aluminum Radiator, Hi-Performance Water pump, 3.23 LSD, Sharked.
Sometime to come: New Clutch with LWFW, Clutch Stop, M50 Manifold, M3 Cams, Supercharger (I can dream).
