Can somebody help? The central locking on my 730i has just started playing up. The problem is when I lock the car either with the remote or the key all the doors lock except the drivers door. When you go to open the car, the locks on the doors that did lock unlock then immediatly lock again. To open the passenger door and the rear doors once you have locked them you have to unlock the car allow the locks to unlock then immediately lock themselves then unlock the car for a second time.
Yes this has happened to me when my e32 was in storage. all the doors locked but the passengers. put your key in the door that wont lock and in the locking motion, force the lock mechanism to go down. this usually takes a little force but keep going. Remember turn the key towards the lock position in the door but far enough to force it down
That is very clear. The door locks unlocks again because the general module gets a signal that one door is not locked. That could be a microswitch on the doorlock or something else.
Microswitch has to give a feedback to the GM that the door is locked.
Could be a broken door bracket or just a out of position microswitch.
See here under body http://bmwe32.masscom.net/
The GM design has beem later changed to omit this function, so if you have a GM built after 09/1991, that function of unlocking a second time is no more.
Remove the door panel in any case, you cannot use the force every time, one day your door will be locked and maybe the key breaks.
repair it now.
Last by not least could be a broken wire in the cable loom into the door under the rubber sleeve. Remove the rubber and see for broken cables there where it goes from the A-pillar into the door. http://www.7-forum.com/forum/24/repa...me-114388.html
Another problem that the locking system is not working are the small grommets in the linkage system. Just fixed today the passenger door of my buddy's B12
08 Grommet 2 51211937233 black ones, a bit bigger than white ones
08 Grommet 2 52208238999 white
13 Grommet 4 52208238999 white
details here https://www.bimmerforums.com/forum/s...a-door-problem
