Thanks to the mods for giving us our own forum! If someone could sticky this thread, it can serve as a list of Bimmerforums members who have Euro motors and anything else about their car, whether it be a US car with a swap or an factory built one. Hopefully it will help put basic some information out there to begin the forum with and avoid clutter spread across multiple threads.
Please reply ONLY with the following info, or any pertinent info you wish to add to the list!
Name:
Chassis:
Color
Mileage
Build Date/Swap Date:
Motor: S50B30 (3.0) or S50B32 (3.2)
Source:
Transmission: 5 speed or 6 speed
Differential Ratio:
Any Other Upgrades/Modifcations?:
'99 Estoril Blue + Dove Grey ///M3 coupe
'04 Jet Black + Cinnamon ///M3 coupe
Chassis: 3/98 build US-spec M3
Color:Cosmos Black
Mileage: 82k on chassis, 0 on motor (rebuilt by Chuck Stickley before swap)
Build Date/Swap Date: 2006, done by self
Motor: S50B32 (3.2)
Source: BMWCCA CMod racer, originally was a PTG crate motor purchased through TCKline
Transmission: 6 speed
Differential Ratio: 3:46LSD
Conforti Eurosport carbon fiber cold air intake
BMW Motorsport GrpN ECU
BMW Motorsport GrpA full exhaust system, header-back
Ceramic coated factory headers
Fan/emissions pump delete
E34 M5 clutch
M5 lightweight flywheel
Sachs Motorsport pressure plate
S54 crank pulley
all bearings and bolts were upgraded to heavy duty for race use
Chassis: 4/94 US-spec M3
Build Date/Swap Date: Swapped in 02 by the previous owner, i aquired it 2/1/07
Motor: S50B32 (3.2)
Source: Don't know
Differential Ratio: 3.15 (for now)
Conforti 3.5" Intake
SuperSprint Euro Race cat-back
AC Delete
Sean
Chassis: EA89XXX
Build Date: 9/97
Motor: S50B32 (3.2)
Source: Factory
Differential Ratio: standard LSD large case unit.
Any Other Upgrades/Modifcations?: None
Chassis: WBSBF92010EA68511
Colour: Avusblau
Interior: Light grey Nappa leather
Build Date/Swap Date: Built May 1995
Current mileage: 65.565 kilometres as at 11/2007
Motor: S50B30 (3.0)
Differential Ratio: 3.15 LSD
Any Other Upgrades:
///M 3 spoke Steering wheel,
New CD43 Headunit,
da ///M Front Strut Brace,
Racing Dynamics Sport springs (-30mm),
Koni S/A dampers
Remus stainless steel twin 2.5" exhaust with DTM tips,
Custom Selby swaybars 27/20mm,
BBS RS II 17x8 2piece alloys,
Z3M shifter.
Matt @ Australia
Chassis: 6/96 US-spec M3
Build Date/Swap Date:Started 7/06 finished 12/06
Motor: S50B32 (3.2)
Source: Bimmerworld, Scouted/ salvaged in Sweden
Tranmission: Stock 5spd.
Diff Ratio: Stock 3.23 (looking to get 3.73)
Any other Upgrades/Mods: Eisenmann Sport exhaust, Supersprint Mid-section
Chassis: 4/94 euro M3 coupe
Build Date/Swap Date: 4/94
Motor: S50B30 (3.0)
Source: BBQ sauce
Differential Ratio: 3.64
Any Other Upgrades/Modifcations?: carbon plenum, Alpha N, alloy UUC stg 2 flywheel, M3R coilovers, ACS short shift, fan delete, S54 crank pulley, resonator replaced with X pipe, custom home made cat back, high flow metal cats (2.5" from headers back)
cheers, Alan
1/4 mile-12.92 @ 108.64mph-NA 3.0L m3 daily driver
Chassis: 1/93 build Euro-spec M3
Color Code: Avus Blau Metallic
Motor: S50B30 (3.0 -286hp)
Differential Ratio: 3:15 LSD
Performance:
- Eisennman Race Euro Catback
- Bilstein Sports Shocks and H&R Sports Springs
- Alpha N Chips (arrived but uninstalled)
- Carbon Fiber Plenum (arrived but uninstalled)
- Direct Port Nitrous System (arrived but uninstalled)
- Prosport Gauges (oil pressure, vots, water temp)
- B&M SSK
Looks:
- 96-99 Nose Panel and Grilles
- ///M Lighted Shift Knob
- CF gauge cluster pannel
- CF Glove compartment molding
- Depo Headlights with Angel Eyes
- 6000 K Hids
- Clear fog lights
- Clear Corners
- Clear Tails
Chassis: 9/95 build US-spec M3
Build Date/Swap Date: pending, estimated swap date by 7/07
Motor: S50B30 (3.0)
Source: Bimmerforums member, originally was a AA import motor
Differential Ratio: 3:15LSD
Euro GT runners
custom intake (Dinan style)
evosport pulleys (on order, but contemplating just getting the E46 M3 crank pulley???)
fan delete (SPAL electric fan)
Super Sprint euro headers
Super Sprint euro midpipe with twin resonators
Super Sprint euro straight tip exhaust
custom AA chips (Vanos & DME)
It might have GT cams, but I have to confirm that with the previous owner
Chassis: 97 US M3 Sedan
Color Code: Technoviolet
Motor: S50B32 (3.2)
Source: German - Factory bench engine - 0 miles
Differential Ratio: 3:64 LSD
Factory BMW Group N engine management
H&R Coilovers
Full euro brakes
Factory X-brace
RD Sport Euro Exhaust
Factory Modena Interior
Factory euro headlights
Euro small 3-Spoke steering wheel
Chassis: 11/93 build eurospec/Canadian M3 #19 of 45
Build Date/Swap Date: from the factory
Motor: S50B30 (3.0)
Source: BMW
Differential Ratio: 3:15 LSD, 3.38 LSD
Any Other Upgrades/Modifcations?: Bone stock motor; Supersprint euro catback exhaust
Chassis: 03/94 build US-spec M3
Build Date/Swap Date: perpetually "in progress"
Motor: S50B32 (3.2)
Source: Active Autowerke
Differential Ratio: 3.73 LSD
Any Other Upgrades/Modifcations?: Too much to list
Chassis: E36 coupe
Build Date/Swap Date: 1997
Motor: S50B32 (3.2)
Source: Local
Differential Ratio: 3.23:1
Any Other Upgrades/Modifcations?: where do i start.
Upgraded intake filter, redesigned exhaust with x-merge & new back box, reflashed DME 7900rpm & delimited, light flywheel (11lb), button clutch plate with upgraded pressure plate, Eibach springs, Koni yellow shocks, adjustable camber plates, convertable spec X-brace under car, Bridgestone RE55s R compound tyres, ACS short shifter.
Plans : 18" CSL wheels, or undecided wether to go down the path of either AlphaN tuneing/carbon intake plenum, or low pressure supercharger.
BMW’s
90 E34 M5
84 E24 M635csi standalone ecu with coil on plug
94 E34 540i/6 SC 5-17psi Flex fuel/standalone ecu
97 Z3 2.8
97 E36 M3 euro SC still u/c
OTHERS
11 Audi S5 APR stg2
19 Volkswagen Amarok V6
Chassis: E36 Coupe - Mugello Rot Red
Build Date/Swap Date: 6/94
Motor: S50B30 (3.0)
Source: BMW Brisbane, Australia
Differential Ratio: Standard
CSL Carbon Airbox
Alpha-N tune
PWR 55mm Radiator
Full SS Exhaust with UUC System-U muffler
UUC stage2 Flywheel + M5 CLutch
UUC SS Clutch Line
UUC black Trans Mounts
Powerflex FCAB
UUC RTAB
Powerflex Sway Bushs
more on the way and Dyno comming soon
Chassis: 8/94 build US Spec 95 M3
Build Date/Swap Date: Complete rebuild - Jan 2007 - Payet Motorsports, Duluth, GA
Motor: Evo S50B32 (3.2)
Source: Holland ( I think )
Transmission: New 6 speed tranny
Differential Ratio: Blanton built 3.64
Any Other Upgrades/Modifcations:
Fluidyne Oil Cooler, Fluidyne Radiator, Aim Data Acquisition, JB Racing Flywheel and Bimmerworld 6 puck clutch kit, Porsche 993TT Front brakes, Porsche 996 Rear brakes, Supersprint X Pipe and Cat back Race exhaust, KW Variant 3 Coilovers w/Eibach sways, CF Hood, MaShaw PTG wing, Evo 2's,etc.
Chassis: JC35XXX (Canadian Edition, # 1 Of 45)
Build Date/Swap Date: November 1993
Colour: Daytona Violet (Special Option Colour Not Available In 1994)
Interior: Black Motorsport Cloth & Amaretta With Matched Violet Leather Accents
Motor: S50B30 (3.0)
Source: Munich, Germany
Transmission: 5 Speed
Differential Ratio: 3.15 L.S.D.
Current Upgrades/Modifications: Factory Freak, Blueprinted
Planned Upgrades/Modifications: Regular Maintenance
Chassis: 6/93 build EURO-spec M3
Build Date/Swap Date: done by...factory
Motor: S50B30
Color: Avus Blue / Mulberry
Chassis Mileage: ~80,000 KM
Engine Mileage: ~80,000 KM
Source: Private Car Dealer in Cincinatti. Been looking for several years...
Differential Ratio: 3:38LSD
Bilstein PSS9s
TMS Sway Bars (Front & Rear)
TMS LTW Flywheel
Superchips Chip
PRM Intake
this list will be growing soon.
I added - Color, and Mileage...something I'm interested to know about everyone's car also...
Chassis: E30 M3
Color: Diamondshwartz (black)
Mileage: 174000km
Build Date/Swap Date: swapped during summer 2006
Motor: S50B32 (3.2)
Source: Imported from Germany (a Z3M)
Differential Ratio: 3.25:1
Any Other Upgrades/Modifcations?: Superchips chip, DECAT,evo2 rear lower spoiler, evo3 front bumper, bbs 16" rims, currently gathering parts for a turbo setup install
Chassis: 10/96 build
Build Date/Swap Date: factory
Motor: S50B32
Color: Arctic Silver / Black
Chassis Mileage: 115000 M
Engine Mileage: As above
Source: Bmw Dealer - Snows. Looked as 15+ before choosing this one
Differential Ratio: Std. LSD
Any Other Upgrades/Modifcations?: yes
I sold this car to a track junkie who will drive it like it was meant to be driven on a track. Looking into newer E92s, etc. It was tons of fun while it lasted, but I'll still be working on the car for the new owner. Look or LISTEN for it at your favorite Mid-Atlantic area racetrack. I put a really loud custom exhaust on it.
Chassis: 1995 E36
Color Avus
Mileage 146,000mi
Build Date/Swap Date: 7/2005
Motor: S50B32
Source: Germany
Differential Ratio: 3.46
Any Other Upgrades/Modifcations?: 30/90 asymmetric lockup diff by KMS, H&R 2.5" springs, Ohlins external canister race dampers (36 HMRC and LMJ)
James Muskopf
RRT Racing
DC Metro's premier BMW service and racing facility
Chassis: 7/94 build E36
Color: Cosmos Black
Mileage: 67,000 KMS (40,200 MILES)
Build Date/Swap Date: 7/94 Build
Motor: S50B30 (3.0)
Source: Japan Market Import
Differential Ratio: I'm really not sure, but it is stock from factory
Any Other Upgrades/Modifcations: Upgraded LTW Rims from factory, H&R and Bilstein suspension, 3000K HID Fog, and 6000K low beam HID, ECU custom tune (255.6 WHP on completely stock engine)
Last edited by Exacc; 06-13-2007 at 10:46 PM. Reason: Updated Modification List :)
1995 BMW E36 EURO ///M3 3.0L
2001 MITSUBUSHI EVOLUTION VII RS2
2004 BMW E46 325i SMG
HONDA S2000 - TRACK CAR - Sold
Chassis:
Build Date: 1995
Motor: 3.0
Source: Factory
Any Other Upgrades/Modifcations?: Turbo,e46 M3 wheels,Hamman black front grill
http://forums.bimmerforums.com/forum...d.php?t=743415
1995 Avus Blue Euro ///M3 - Garret GT35 - Giant intercooler - Schrick cams - 10.000k xenon eyes - 619whp dyno tested - R.I.P M6! 1996 740i 20" wheels and E30 318is with M3 upgraded engine.SICK!!http://forums.bimmerforums.com/forum...d.php?t=743415
Chassis: E36 coupe
Mileage: 50000 kms
Build Date: 11/97
Motor: S50B32 (3.2)
Source: OEM
Any Other Upgrades/Modifcations?: Gruppe M reproduction intake, B&B TriFlo catback without cats and x pipe in place of resonators.
I know there is another guy from Manila, Philippines that is on this board and have EURO M3 too...hope he posts his info too!
