Page 1 of 4 1234 LastLast
Results 1 to 25 of 94
Thread: Rear Ball Joints Replaced. Wow! What a difference!
    rcM3 is offline baaaaaaaaaaaaaaaaaaaah...
    Jul 2005
    Kansas City
    '98 M3/2, '09 Cooper S
    I hijacked a well-stocked garage monday and under the wing of a ball-joint wizard, managed to swap out all four ball joints in the rear. To be clear these are the pieces that press into the hubs on the outside ends of the rear lower control arms and the spring perch control arm.
    The need for the project arose when a loud popping noise began coming from the left rear when loading and unloading that corner.
    Utilizing a mutilated tool for domestic cars from O'Riely's, a couple random pieces of pipe from Home Depot, and a BIG hammer (I highly recommend picking up an appropriate tool if you want to do this, it will save HOURS) we popped all the old ones out and put the new ones in.
    When accessed and wiggled, the old ones could be moved without any effort. The new ones were rock solid. One of the old ones (I suspect this was the one causing the noise) was so worn that the eccentric bolt had fused to the interior of the joint and the metal sleeve had begun to mushroom from its housing.
    This must have been the weak point in my suspension for quite a while as it didn't even feel this solid when I bought it. (I now have 135,000 miles.) Nothing has made this huge of a difference since I replaced my old worn shocks and OEM springs with Koni SAs and Eibach Prokit springs. Full disclosure: I've also replaced my FCABs, RTABs, RSMs. Next on the docket: Sways with poly-U bushings!
    Moral of this story: If your unhappy with the stiffness of your high mileage e36 m3, there is hope in bushing replacement!
    Feb 2004
    Los Angeles | CA
    95 M3 Turbo, 07 650XChlg
    did you have to remove the diff?
    WTB: E36 ZKW Headlights, ACS Rear Diffuser,E36 M mudflaps front + rear
    Jul 2005
    Kansas City
    Quote Originally Posted by raoke View Post
    No. I just did the outer ones. You need to drop the diff to do the inner ones I think. The outer ones can be seen directly behind the dust shield on the top and bottom. I removed the brake and e-brake assembly and disconnected the RSM and dust shield to do it.
    Nov 2003
    Atlanta
    2005 M3
    I replaced mine just before the holidays as well as my RTAB and it was a massive difference. They are not to be overlooked when you think RTAB's are the culprit for lousy handling....
    2005 M3
    “Auto racing, bull fighting, and mountain climbing are the only real sports … all others are games.” - Ernest Hemingway
    Oct 2003
    <stewievoice>
    Indeed.
    </stewievoice>
    I'd planned on replacing the inner CA bushings and had dropped the rear subframe, but they were still solid compared to the outer ball joints and after the experience on the outers, I decided I'd get the right tool and do them all properly.
    BTW, dropping the diff and rear subframe is almost *easy* and makes it much easier to work on all of the bushings/bearings at once.
    Good work, Randy!
    -Steve
    Do you like large cats?
    Westford Mass
    98 M3 cabby, 68 LR 3A "pig"
    how do the new ones go in, are they press in? did you just smash them in rather then press them in?
    havent ever been able to find a diy on these outer bushings
    Dec 2003
    MD
    E39 M5, E36 M3, E34
    I JUST did mine too. And I agree. What a difference it is!
    Did you use 'upgraded' part # 33326775551 for all four positions? I did.
    Jul 2005
    Kansas City
    Quote Originally Posted by RagnarDanskjold View Post
    <stewievoice>
    Indeed.
    </stewievoice>
    Good work, Randy!
    Thanks Mr. Wizard.
    Quote Originally Posted by dev0i
    They are press-in parts. I tried to use a poorly fitting C-clamp press, but after tapping with a hammer to get it started and in position and noticing how well that worked beyond just starting it, the hammer became a main tool for getting it in the rest of the way. When pressing in or beating it with hammer, the pressure needs to be applied to the outer collar. The best fit was a random big socket.
    Quote Originally Posted by Dukes
    Affirmative. Good pictures btw!
    Mar 2006
    sask , canada
    94 b3 3.0 96 b8 4.0
    did u get a wheel alignment after u did this?
    Jul 2005
    Kansas City
    Quote Originally Posted by saint166 View Post
    I certainly plan to ASAP. We took care to put the eccentric bolt approximately in the position it started in, but I'm sure my alignment is all goofy.
    NY
    skateboard
    Quote Originally Posted by Dukes View Post
    Where can i order these? Also what did you pay?
    ― George Orwell
    Jul 2005
    New York
    03 330i; 04 330i
    Did you use 'upgraded' part # [FONT=Verdana][SIZE=2][COLOR=black]33326775551 for all four positions? I did.
    Great post; thanks.
    Roguls
    New York
    Oct 2003
    Quote Originally Posted by Roguls View Post
    Great post; thanks.
    No kidding! Those two pics explain it perfectly.
    -Steve
    Dec 2003
    MD
    E39 M5, E36 M3, E34
    Quote Originally Posted by GG///M3 View Post
    The pic is a link to the store buddy.
    Jul 2005
    Kansas City
    I got mine from BMA for ~40 ea. Turner obviously sells them too for a pretty good price.
    Sammamish, WA
    95 Hellrot M3/02 MY Z06
    That is a BMW part though, Correct? (I can get BMW parts at cost from Neighbor)
    Looks like a good project for my 132K '95.....
    John
    '95 Hellrot M3 w/Dove
    AA Euro HFM Stage II (w/21# Injectors & Software) W/Gen III Exhaust - URI Crank Pully - FDM w/3 Row M Coupe Rad - 3.23 LSD - Vogtland Club Spec/Koni SA - UUC Red w/Enforcers - TMS Shims/Rear Camber Bars w/QA1 inners/Sways - VMC F/TMS R End Links - X-Brace - Perf Ultimate/SS Brake Lines - GC Tower Mounts/RTAB Shims - ZKW's w/5000K Hid - Fog Delete - Alpine 9847/Pioneer TS-C130R Kevlar Components/Pioneer PRS-X340/Stealth Box's/Wired Zune 120GB - OE LTW CF Sills/Glove Box Plate - Staggered Black M-Spoke II's w/235/40 (front), 255/40 (Rear) Nitto NT05's - Rolled Fenders!
    ***Got a '95 M3? (actually pretty common on all years! Even happened to Racer Seth Thomas! ) Check Your LSD! http://forums.bimmerforums.com/forum...d.php?t=390209
    Jul 2005
    Kansas City
    Quote Originally Posted by JETninja View Post
    Correct. Its a BMW part. Its made by Lemforder (sp?).
    Mar 2004
    Springfield, MO
    95 M3/11 WRX/07 525i
    Good stuff, my car could really use the same treatment. I'll drive up there this weekend and you can put everything in now that you know how to do it
    NY
    skateboard
    Does the 95m3 have this same part?
    ― George Orwell
    Jul 2005
    Kansas City
    Quote Originally Posted by Capital View Post
    I don't know about all that.... but I bet if you have the correctly sized press tool it wouldn't be that hard except for the reassembly of the e-brake.
    Turner's website explains it here: http://www.turnermotorsport.com/html...ID=33326775551
    The 95 M3 and other e36s have a different, less effective part in the lower location.
    Jul 2003
    Carol Stream, IL
    97 M3 TTStgII
    Did you use 'upgraded' part #33326775551 for all four positions? I did.
    I've got 4 of these sitting around and am finally making time to do this. I bought them from 2 different sources. However, even though they look identical, 2 are 33326775551 and 2 are 33321140345. My local dealer says there is absolutely no difference.
    Are you sure the ...551 is an upgrade to ...345? If so, where did this info come from, and how have they been upgraded?
    Realoem parts 2-3:
    http://www.realoem.com/bmw/showparts...04&hg=33&fg=30
    Thanks much.
    Dec 2003
    MD
    E39 M5, E36 M3, E34
    Quote Originally Posted by acastillo View Post
    Realoem parts 2-3:
    Thanks much.
    33326775551 is entirely optional. An is only rumored to be an upgrade.
    But I posted the link to the website that explains it above.
    Just click on the picture.
    Jul 2003
    Carol Stream, IL
    97 M3 TTStgII
    Thanks. I did before, but it only mentioned it to be an upgrade for non M's and the 95 M3 which use a more rubber ball joint in the lower position. I have both the 33326775551 and 33321140345 in front of me, and I can't seem to discern any difference
    Nov 2002
    So.California
    1995 M3
    Quote Originally Posted by rcM3 View Post
    The pics don't show evidence of ebrake assembly removal.
    The disc is still mounted.
    What did you mean, exactly?
    Dec 2005
    San Diego, CA
    1995 M3
    How did you get the old bushings out?
