Almost getting done with my inspection II service...
Curious as to how many different sensors are there that I can clean? I mean there is that MAF sensor... and I was wondering if I can take it out and clean it.
Q1. Can that sensor be cleaned and is it recommended or should i leave it alone?
Q2. Are thre any other sensors that I should clean/replace?
Q3. If yes... either of the questions above, anybody knows any DIY guides?
Thanks Fellas. You guys been great.
-X-X-X-X-X-X-X-X-X-X-X-XX-X-X-X-X-X-X-X-X-X-
Worst Prepurchase Inspection/Repair experience in Tampa:
Cars and Concepts Import Car Specialist
Dont place your trust in these buffoons.
Q1: I don't see why not. Get the CRC MAF cleaner. Runs for $6. It's essentially a cleaner for electronic parts.
Q2: If you have pre-2003 E46, you can clean the IAT sensor in the intake manifold. The rest of the sensors in the engine area are either HALL sensors or temp sensors. I would recommend cleaning the sensor connectors as well. The above cleaner can do that.
[SIZE="3"][SIZE=1][b] Technik Engineering ASA Stage 1.
Supercharged E46 M54B25.
2011 NASA TTC So Cal Champion!
