Page 3 of 11 FirstFirst 1234567891011 LastLast
Results 51 to 75 of 256
Thread: DIY: Complete ASC delete with no ABS light/fault!
  1. #51
    Atlanta GA
    97 S54,94 M-Technic,SE36
    hey so I am having an ABS light problem after doing this (about a month after)
    The codes thrown relate to the front right wheel speed sensor. I replaced the sensor, cleared the codes and it just comes right back on.
    I hear it may be the abs control module...
    The thing is, I deleted my traction control and put the 10ohm resistor as stated in the thead..
    Could that be the problem?
    I never knew how easy it was to lock the tires w/o abs on these cars and I already ruined a brand new pair of tires..
    I may hold 328iJunkie liable
  2. #52
    Chanhassen, MN
    1995 E36 325i
    I was wondering if it would work on a 325i?
    Did you just get a Volt-Ohm-Meter and check the resistance on the ASC unit and then add a resistor that matched the resistance?
    In response to the 318i, try it with banana plugs or by holding the resistor in place and see what happens.
    Another quick question, is the ASC light fault something the dealer has to reset or does it go out by itself once the problem is fixed?
  3. #53
    Oct 2005
    Lawrenceville, GA!
    Many Broken Ones
    -ABS or ASC faults dont need to be reset, they go off once you fix the problem.
    -You shouldnt need to do this on a 95 because you dont have ASC
    -Rob if the resistor or anything has come loose then yes this could be your problem but the dealer should have picked up a code for it i think.
    -I honestly have no experience with 318s but all it takes is to test the resistance across the ASC acutator and replace it with that same resistance resistor haha.
    -Clayman, Pull off the boot that protects that wire connector for the harness and see what 4 wires go into the connector. Then rip out your bently (or i will if need be) and itll tell you which wires are which at that connector.
    460whp/515wtq wifes MMW tuned 335i
  4. #54
    Chanhassen, MN
    1995 E36 325i
    My car definitely has ASC. I have a 325i if that matters.
  5. #55
    California
    96XJ, 042500HD, 13Focus
    Quote Originally Posted by buuhh99 View Post
    NO it does not.
    ASC was not offered in 95 on the e36.
    GREAT FIND!!!!
    94 318is
    95 M3
    93 325is Euro
    95 318ti clubsport
    97 M3
    88 535is
    98 328i vert
    99 M3
    Off the bmw crack at the moment
  6. #56
    Chanhassen, MN
    1995 E36 325i
    So what is my traction control called then.
  7. #57
    Jun 2004
    buffalo, NY
    1998 328i,
    ASC- automatic stability control up to
    DSC- dymanic stability control for 99 and newer models (00 and newer M3)
    nice find. have anyone figured out a way to delete the ASC position sensor so that dam ligh ti s not on all the time?
    SOLD my BMW it has been fun.
  8. #58
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    Quote Originally Posted by EdirtySicks View Post
    NO it does not.
    GREAT FIND!!!!
    Slight clarification:
    At least on the non-M, ASC was indeed offered on the '95 e36. Option code 214 (Automatic Stability Control+Traction).
  9. #59
    Oct 2005
    Lawrenceville, GA!
    Many Broken Ones
    ORLY?
    I didnt know that. I wonder if you could the get the LSD (winter package) and ASC..?...
  10. #60
    Mar 2003
    St. Joseph, Mo.
    i *think* it was even available on some '94 models, but I don't know for sure.....
    I have a mid to late production 325is (06/95) and it has ASC+T.
    My guess is that if you had ASC+T, you did not get the winter package, but just a guess....
    Anyway, great post on the fix for those that dump ASC, didn't mean to jack the thread! Just saw something I knew! hehe....
  11. #61
    Mar 2004
    Toronto, ON
    M3/28is
    Quote Originally Posted by 328iJunkie View Post
    Is it possible to do this without permanently damaging the boot??
  12. #62
    Oct 2005
    Lawrenceville, GA!
    Many Broken Ones
    It should be. It should just pull off...
  13. #63
    Mar 2004
    Toronto, ON
    M3/28is
    Haven't had the chance to go and try pulling the rubber boot yet, but for anyone who's interested, I've traced the two wires in the Bentley and they eventually lead to the ABS computer inside the glovebox.
    How it goes there (via the round plug, I hope?) still remains a mystery until I go to the shop..
  14. #64
    Rapid City, SD
    2008 M3 AW on Fox
    I removed my ASC system on my 96 M3 today. I then put on the stock non-ASC black rubber boot for $25 (13-54-1-703-588). Another boot will work in a pinch (13-54-1-738-757), but you will have to plug a second rubber hole (easy). Initially, 3 lights were on my dash. CEL, ASC and ABS. I hooked the MAF connector, because I forgot that......so after 4 starts, the CEL went away. I then did the 10 ohm resistor trick for $1.49. I thought the 10 ohm resistor would remove the ASC light, but the resistor removed the ABS light. The ASC light is still on. I'm considering the Black Tape on the Dash method, but I would rather not do that if someone knows? knows?
    08 Alpine on Fox Red - Bot 1.19.23 in Spearfish
    97 Byzanz on Black M3/4/A - Sold 7.14.21 to Behzad of Newark
    97 Byzanz on Magma M3/4/A - Sold 7.7.17Jerad in CO
    98 TiSilver on Black M3/4/A - Sold 7.19.17 Jono driving it
    96 Boston on Dove M3/2/5 - Sold 10.28.17 Benny and Suad
    98 Estoril on Dove M3/4/5 - Sold 9.23.13 Garrett driving it
    98 Arctic on Dove M3/4/5 - Sold - 4.2.13 - Ron driving it
    98 Estoril on Dove M3/2/5 - Sold 8.6.12 Thy driving it
    99 Estoril on Sand M3/2/5 - Sold 7.31.12 Eric driving it
    98 Arctic on Dove M3/2/5 - Sold 3.10.12 Kyle driving it
    96 Techno on Black M3/2/5-Sold 6.13.09 Ross totaled it
  15. #65
    Dec 2005
    USA
    '98 M3
    Quote Originally Posted by egebhardt View Post
    I removed my ASC system on my 96 M3 today. I then put on the stock non-ASC black rubber boot for $25 (13-54-1-703-588). Another boot will work in a pinch (13-54-1-738-757), but you will have to plug a second rubber hole (easy). Initially, 3 lights were on my dash. CEL, ASC and ABS. I hooked the MAF connector, because I forgot that......so after 4 starts, the CEL went away. I then did the 10 ohm resistor trick for $1.49. The resistor removed the ABS light. The ASC light is still on. I'm considering the Black Tape on the Dash method, but I would rather not do that if someone knows? knows?
    Well, the ASC light it still on since the ASC actuator is unplugged (the cylindrical motor w/steel line on it), so the best solution is to just remove the gauge cluster and remove the lightbulb for the ASC Warning Light.
    Mike... aka Track Junkie
    '98.5 M3 Coupe Titan Silver
  16. #66
    Atlanta GA
    Pull the bulb.
    I fixed my ABS by changing the resistor. I dont know why it crapped out on me
  17. #67
    Oct 2005
    Lawrenceville, GA!
    Many Broken Ones
    You might need to get a higher wattage resistor. If the wattage is too low then it will just burn it out.
  18. #68
    Atlanta GA
    Ill try that once this one goes..
    15ohm maybe?
  19. #69
    Oct 2005
    Lawrenceville, GA!
    Many Broken Ones
    nono watt not ohm.. you want a more power handling resistor. Still 10 ohms though.
  20. #70
    busterhax's Avatar
    busterhax is offline Y̝͎̘̍́ͣ̉͑̿̆Ō͎̼̺̬̒ͯ̃̇͗̂ U͈̖
    Jun 2006
    NYC
    e36
    my abs light would come on after driving around for a while. i think it still did that even before i did the asc delete. i just put the resistor in, ill see tomorrow if it helped or not. i doubt it will ;\
  21. #71
    Santa Monica, CA
    '98 M3 Coupe
    Putting a 1 Watt resistor across the wires won't cut it. If the car tries to engage that actuator for any reason the resistor will fry. You will need at least a 15 Watt resistor. Here are the calculations:
    I = V/R (I = 12/10 = 1.2A)
    P = I*V (P = 1.2*12 = 14.4 Watts)
    I recommend just leaving the actuator connected, ugly as it may be.
    Dinan Supercharger, M50 Manifold, SuperSprint Exhaust, UUC Pullies
    TC Kline S/A Suspension, X-Brace, E46 HIDs, Braille Lightweight Battery
  22. #72
    Mar 2004
    Wisconsin
    911 Turbo, BMW X3
    How many people are using this resistor method successfully? I just got my Samco boot and I'm about to swap it in, should I do this?
  23. #73
    busterhax's Avatar
    Jun 2006
    NYC
    e36
    im using it, it hasnt burnt out at all. my abs light still comes on after driving for a couple of minutes due to other unknown reasons =(. apparently there is another asc delete kit that will keep the actuator and throttle cable, but throttle body will be removed. no abs light, and will still brake the rear wheels..dunno where its at though. i think its like 20 bucks. my friend has it on his m coupe
  24. #74
    Mar 2004
    Wisconsin
    911 Turbo, BMW X3
    Quote Originally Posted by busterhax View Post
    Can you find information on this? Is it Eric's kit?
  25. #75
    Oct 2005
    Lawrenceville, GA!
    Many Broken Ones
    Im using it
