Results 1 to 25 of 33
Thread: Brake Pad Upgrade - 7th HPDE
    fake suburban environment
    e30m52 325iT E30 E70X5
    So I have done the auto-x thing and "graduated" to track days. This July will be my 7th HPDE in the M3. I have always ran Euro Floating Rotors and blanks with OEM pads(which I actually really like and have YET to let me down). I am pretty quick around the track and definitely use a whole set of brakes at the event.
    What is the next step up? I tried one time EBC RedStuff and they were horrible. Worse than the OEM pads. I want to be able to just get a bit more bite coming into 10a at Road Atlanta
    Axxiss Ultimate? Run OEM again till I can splurge for a really extreme pad? I don't want to spend 250-300 dollars on pads. Ultimates "seem" to be better than stock.
    My driving style is "point and shoot" which I know is not the best and I attempt to brake as late as I feel is safe. OEMs have been great so far. Just looking for the next step for a bit more bite
    Nov 2003
    USA
    M3
    I'm surprised you lasted that long on OEM pads without any overheating. I guess it depends on the tracks that you run, I managed to obliterate my rotors with OEM pads at VIR during my 2nd HPDE. I've since used Turner Cool Willies with good results. They are excellent on the track as well as safe on the street to get you to/from the event.
    Richmond, VA
    Hawk HP+ are easy to find and relatively cheap, and can get you to the track and home again without swapping pads in the paddock. I use them when I dont have a trailer ride and they work great.
    Nov 2002
    Washington, DC
    E30 E36 E46 E90
    OEM pads are the best normal pad for track use. Axxis Ultimates, for example, like to disintegrate. Get a real track pad or stay OEM. And really, just get a real track pad like the PFC97 (PFC01 for R-tires). After you collect your eyeballs off the windshield, you'll be asking yourself "why the hell didn't I do buy these the first time around?"
    2011 M3 Sedan
    2006 GMC Sierra 2500HD LBZ
    1999 323i GTS2
    1995 M3 - S50B32/S6S420G/3.91
    1990 325is
    1989 M3 - S54B32/GS6-37BZ
    Hers: 1996 Porsche 911 Turbo
    Hers: 1989 325iX
    Nov 2002
    Washington, DC
    E30 E36 E46 E90
    Quote Originally Posted by JClark View Post
    The HP+ has amazing bite, but poor heat tolerance. I have never yet tried a pad that can't be used in a BMW on the street.
    2011 M3 Sedan
    1999 323i GTS2
    1990 325is
    Hers: 1989 325iX
    So then No on the Ultimates?
    OEM pads have been great so far. I killed a set at Road Atlanta last year but they never faded or had any issues.
    HP+ then seems to be good?
    What is this PFC97? Where do I get it? Price Range?
    Nov 2002
    MD
    996, S13, E46 E36, C4
    I had a great experience with Axxis Ultimates. My experience is with them on a 92 Prelude with NSX calipers though.
    I had them for 4 years, 10+ track days, some autoX, and daily driving. Lasted me about 35K miles too!! Only had brake fade once.
    I am not that fast on the track, nor am I that slow. I definitely wouldn't consider myself hard on the brakes at DEs. I did push them a few times and didn't have any problems.
    I was very happy with them for a dual purpose pad.
    Last year I switched to Hawk HP+s because I couldn't get Ultimates in time for an upcoming track event. They felt very similar to my Ultimates but the brake dust was very bad. It stained my wheels after 1 DE weekend.
    I am looking again for Ultimates for another car I have. That's how much I liked them for a daily driver/ occasional track car.
    Nov 2002
    Washington, DC
    E30 E36 E46 E90
    Quote Originally Posted by M3Alpine99 View Post
    I have been strongly advised NOT to use the HP+ on track. It's better than stock, but does NOT deal with overheating well. Worse yet, they transition from strong braking to nearly no braking with nearly no warning.
    It's also the noisiest pad in existence. (I used them on my street/autox car for a while - best cold bite of ANY pad out there.) These things will SHRIEK every time you apply the brakes gently, and anti-squeal goop only gets them from deafening to uncomfortably loud.
    2011 M3 Sedan
    1999 323i GTS2
    1990 325is
    Hers: 1989 325iX
    Quote Originally Posted by nick325xit 5spd View Post
    Interesting. I am running Road Atlanta. I don't see how this could be possible. I had no fade on my stock pads at all the HP+ will be worse? I am not one to overheat brakes and the track setup at Road Atlanta allows for substantial cool down time. Think I will have different results?
    These will be track only. I have OEM pads with Euro Rotors and blanks for the street.
    Quote Originally Posted by Andy View Post
    Very Interesting... Totally different from the former review.
    Anyone run HP+ on e36 M3 at a drivers school?
    Nov 2002
    Washington, DC
    E30 E36 E46 E90
    HP+ pads are nearly as expensive as track pads. If they're track only, you'd be out of your mind using them.
    And yes, I do think you'd have problems with them - when you can brake a lot harder, you will brake a lot harder.
    2011 M3 Sedan
    1999 323i GTS2
    1990 325is
    Hers: 1989 325iX
    Dec 2003
    Peachtree City
    2012 Tacoma
    Sounds like it's time to upgrade to Hawk HT14 fronts and HT10 rears. This would be a track only setup...you wouldn't want these pads on the street.
    If you're eating up a set over a weekend you should consider cooling ducts too. Road Atlanta really isn't tough on brakes but you might expands your horizons to Barber or Roebling Road.
    Is divorce in the air? Get the list and follow it!
    http://forum.dadsdivorce.com/viewtopic.php?t=13374
    Dec 2005
    Chicago, IL
    CTA
    time to buy race pads... PF01, HT10 or 14, DTC70 or 60, Cobalt XR2 all are good just pick whatever floats your boat. i put ht10's all around on a stock car because they were cheapest "good" pad
    Jan 2003
    San Luis Obispo, CA
    18 M3, 15 x5, 67Mustang
    Quote Originally Posted by krisko View Post
    We are running specials on Hawk pads for bimmerforums members, 15% off of list price and free shipping. Let me know if we can help you out. We have the HT14 and HT10 combo in stock.
    DC
    323iT
    I had Ultimates on my 540 and the first time I had them out on the track they glazed over. They were also noisy on the street. Others have had success with them, but I'm not a fan.
    I put a set of Carbotech XP10 pads on the front of my M3 and was very happy with them at the track, though I can't say if they were better or worse than any of the other racing pads out there since these are the only race pads I've used. I did drive to and from the track with them and they were fine on the street. Very noisy but no problem with lack of bite, even when cold.
    Interesting. What is the next step up then?
    Why the ht14 and ht10 combo?
    Yah I know on the coolling ducts. 2nd Road Atlanta Event. I starting driving in Chicago Road America, Mid Ohio, Buttinwillow
    Question. Will I kill a whole set of race pads and my new blanks in 1 event?
    Nov 2002
    Washington, DC
    E30 E36 E46 E90
    If you're not getting fade, they should last longer. PFC97s, in particular, seem to last a LONG time. The HT10s are a cheap intermediate step, though. (And he recommends HT14s in the front because it's often nice to have some front bias added.)
    2011 M3 Sedan
    1999 323i GTS2
    1990 325is
    Hers: 1989 325iX
    Jersey City
    '96 M3
    I switched out my OEM for the Ultimates for AutoX. They held up great for 15 hard runs, much better than my old stock ones did.
    They did/do squeal when I'm coming to a stop light with light brake pressure, but not all the time, maybe 25% of the time, not sure what triggers it, but after 2 AutoX's they seem to have calmed down a bit more. I like them,
    BBS | Bridgestone | Conforti | PBR | Storm | Supersprint | TCKline | UUC | Whalen | ZKW
    Jan 2003
    Orlando, FL
    All forced inducted...
    My only complaint with Ultimates on the M3 were pad deposits on the rotor. I didn't have any problems with fade on the track or noise on the street.
    I also ran HP+ on the Cobra. They worked OK but tore up the rotors pretty quickly. I never felt very confident in them though. I just switched to Carbotech XP10 and love them.
    Quote Originally Posted by BlackM3Sedan View Post
    I have heard the deposit thing 3 or 4 times now. Thank you for the review.
    Not worried about tearing up the rotor
    Quote Originally Posted by CT88 View Post
    Noise is no issue I don't run Auto-x anymore. I will get "black flagged" off the start for noise pollution
    Thank you sir. Weighing my options now. Whatever I choose I will come back and offer review
    Dec 2002
    Southern California
    don't ask
    If you are looking for a decent pad you can use for both street and track, try the Carbotech panther+ pads. They might be a little noisy on the street, but they dont fall off dramatically on the track either. Getting one set of pads to do both is hard, I'd personally recommend getting 2 different sets and swapping back and forth if you use the car on the street a lot.
    -Peter
    Current toy: none
    Past cars: 88 M3, 99 M3 x2, 04 M3, 91 NSX, 06 S2000, 01 911TT, 06 Exige, 00 NSX, 04 GT3
    Quote Originally Posted by GotBHP? View Post
    Well it is no longer driven on the street very often anymore. I want to try a small upgrade first and then next year upgrade to the 2 sets with dedicated wheels/tires etc.
    Just this year I got some style 44s with dedicated track tires I am slowly moving up.
    Thanks for the help guys.
    May 2001
    Easley, SC
    2017 530i M-sport
    I used Porterfield R4-S pads for a couple of years before moving to a true track pad. They're OK on the track and great on the street and don't have caustic dust. Once I switched to a track pad, I switched between their R4-S pads and R4 pads.
    Now I use Hawks.... no street driving.
    Jay
    From wannabe to has been in a few short years..... the older I get, the faster I was
    Dec 2005
    Chicago, IL
    CTA
    FYI Panther+ leaves some kind of crazy dust that if not immediately cleaned bonds to the wheels and then rusts. Pads themselves are OK not great but not bad either.
    Cary, NC, USA
    93 325is
    Try a set of Pagid Sport compound pads. I've really liked them. They hold up well with 2 drivers (novice and Instructor run groups) at VIR. Don't have to change for street use either.
    Dec 2002
    Southern California
    don't ask
    Quote Originally Posted by m4f1a View Post
    Have you ever had them? They hevent left any kind of stains on 4 different sets of wheels I've used...
    -Peter
    Current toy: none
