Just as the title states, why is there no twin-screw charger for the S54? I remember a long time ago ESS was going to come out with a kit and said the S54 LOVED the TS and made serious torque.
Can any of the tuners chime in as to what's holding everyone back?
-Zach
2006 E46 ///M3 6-spd Coupe | Interlagos Blue on Gray | ZCP Competition Package
“I felt as though I was driving in a tunnel. The whole circuit became a tunnel... I had reached such a high level of concentration that it was as if the car and I had become one. Together we were at the maximum. I was giving the car everything - and vice versa.”
-Ayrton Senna...may he rest in peace
I know that the S54 runs really high compression and Karl from AA said the DME is a bit trickier to tune.
~Phil
Madeiraviolett Bf.C club member #001
1996 BMW 328is Madeiraviolett/Dove Grey: 5 Spd, Sport, Cold Weather & Premium Sound pkgs.
3.5" ECIS/ITG intake -> Samco ASC Delete Boot -> DINAN TB -> M50 Manifold -> S52 Cams | Bav Auto Red-top ignition coils tuned w/ AA software, Dynomax Cats & Stromung exhaust UUC Pulleys & Clutch stop, FDM=Zionsville radiator, Mishimoto Tank, SAMCO hoses, Fidanza LTW flywheel & M3 clutch, UUC Evo3 SSK, 3.23 LSD, Koni/Eibach Adjustable Damper suspension, PUR RSM's & RTABs, CF Strut brace, UUC Swaybarbarians, Motorsport X-Brace, 17x8 Beyern Mesh wheels Hella CELIS projectors + 5k TRS HID's, Fog delete=Brake cooling duct, LTW wing, ///M Bumper & R. Diffuser
CCA Member #382557
I can't imagine the twin-screw being all that different than the centrifugal ones on the market today. Just need a different tune right? I found a post from ESS saying they were having issues with controlling the throttle bodies on their TS S54.
Yeah ITBs would make the TS design a little more interesting. Other than that there is no reason except R&D $
Why no delete the ITB set-up. I know this would be intensive, but would it be as intensive as making them work?
Probably a stupid question since I am definitly not the first person to think of this, I imagine.
"We are the music makers...and we are the dreamers of dreams."
If they already have CF S54 kits out than making a TS would be no different as far as tuning. Only thing I can think of is having the boost come in so low in the RPM's may present a problem given the engines already high compression ratio. Maybe I'm totally off though. Or maybe it is the space constraints of the engine bay.
I have oil in my blood; that is my dedication level to cars.
From wahty i was told, you would have to remove the ITBs for it to work.... which is one of the great features of this motor.
-M3J0N
So it's been ten years since this topic was last spoken about. What are the answers today in the twilight of the 2017? Is there an answer? Is there a TS system for the S54 today? Why not? Or where to find more information or systems.
1987 M6
1998 Dinan SC M Roadster
2002 M Coupe
I had talked at length with Josh McMurray (aka Eurosport) about this, and he wanted to approach it the same way he did the S-52, with a proprietary manifold. At the time__probably September/October 2005__he just needed someone to give them a car to use (he also needed more money coming in, but that wasn't so widely known then).
Having recently installed what was possibly the second twinscrew of his to go onto an M Coupe's engine (the same car I was able to buy in 2014) and for a period of about a year, I'd get fairly frequent calls from him, nearly always 1-1.5 hours in length. Since he'd already done the S-52, a lot of the talk was centered on the S-54; the ITBs were already thrown out, as far as the design goes, but either he didn't divulge, or I don't remember what the rest of the hardware layout was.
The S-54 intake port face is at a different angle than the S-52, so it wasn't as simple as reworking that casting, and IIRC he also wanted to increase the surface area of the Laminova intercooling cores by adding a 4th or increasing their length (?).
With a static compression ratio of 11.5:1, boost would've either been limited, and/or methanol cooled, and would've required some sensitive and fast responding controls.
I don't know what he had in mind for the software, but nearby Jim Conforti was still handling that end for him, so they would've come up with something.
The twinscrew package for the S-52 did prove one (1) thing, and that was if Eurosport was going to survive, they needed to sell more of them and for a lot more money than they did (there were other factors that also contributed to their demise, not least of which was ESS buying Opcon and halting the sale of compressors to both ES & AA...).
It has been a while; I can't recall the last time S-54 and twinscrew was used in the same sentence
For posterity's sake, behold the Eurosport Twinscrew manifold! This particular example has been stripped of its tenacious original powder coating, and then treated to a thermal barrier and thermal dispersant polymer coating; isn't it gorgeous?!?!
The V8 may allow better packaging of a twinscrew, but ITBs and positive displacement are possible -- Harrop is doing it with the S65. Development costs may be the issue. I think AA stopped selling its S52 kit because costs were high and they weren't selling well. If you spend $100k on development and production and make $2k per kit you have to sell 50 kits to break even and that gives nothing for your time or risk.
