Thinking about jumping for a BBK for the front. A few requirements-
MUST fit under 17" wheels (spacers ok)
Price should be under $2k, around $1700 or $1800 better
Preferably red calipers (for cosmetics of course)
THEY STOP ON A DIME lol I guess that is a given
Been looking at the RE and the UUC...
Any experiences you would like to share? Any others I should consider?
Prospeedmotorsports.com
Eugene
97 M3/2 5spd - Hellrot - for sale!
Dinan Stage V/CAI/big TB/3.5"HFM/OBD I intake
Dinan strutbrace/ X-brace
Schrick cams
euro 6spd/3.64 rear diff, 320i mounts
AA gen III exhaust/track pipe/HIOP headers/02 simulators
RS SSK, UUC clutchstop, clutchpedal bushings
993TT front & 996 rear brakes, Hawk HPS/ SS lines/ ATE Super Blue
Kinesis K20's 18x8.5,9.5, OZ Superleggera 18x9
Eibach sways, H&R coilovers
URI UD pulleys
RedLine diff/tranny fluid
PowerFlex RTAB, TCKline rear control arms, PowerFlex front control arm bushings
98 M-Roadster boot, ECIS shield
fan clutch delete, 80 C thermostat and fan switch
Euro dual-pickup oil pan
finned RE rear diff cover
AC Schnitzer euro steering wheel
Don't forget these...
http://www.ecisbmw.com/product_files/brakes/brakes.htm
on sale to boot...
Sean Cain
"Filter Out the Competition"
prospeed is not selling brake kits no more
wtf? what happened?
Alan
2006 325i
2015 M3
The prices he was selling them at, he was not making a dime. He was trying to break into the market by undercutting everyone else...I guess it didn't work.wtf? what happened?
Sean Cain
I have a Stoptech BBK for sale with red calipers. Let me know if you are interested. You will need either 15-20 mm spacers to clear the stock wheels.
2007 GT3: GT Silver, PCCB, Sharkwerk'd
There are guys who are afraid of the rev limiter and there are guys who use it to save a shift
Very interesting that Prospeed has decided to get out of BBK all together. I have had my kit on order since early December and it sounds like I should have it in another week or so. I know there are people on this board that have been waiting longer than me. I just hope that Prospeed follows through with those of us that have paid for this kit and have yet to recieve it...
spoke w/mike at prospeed today
he said the kits will still be available however he is trying to
get his parts from other vendors
he asked that i post this
Wow, that's a pretty good deal on the ECIS BBK. Aren't the e46 Euro rotors something like $200 EACH? However, if you can get the specs needed to make the mounting bracket for the caliper (and had access to a CAD program and a machine shop), I'm sure you could piece together that kit for not too much money.
2007 335i Coupe - Space Grey/Coral Red
check out Rogue Engineering
do you even know what a plethora is?
To set the record straight, Prospeed is not getting out of the BBK biz because of low margins/profits. In fact, without going into the details, BBKs are EXTEMELY profitable.
I am getting out of the BBKs due to many other reasons, the primary one being, with the national release of the Prospeed GS610 brake fluid in April and all that is involved with that, I simply do not have the time to devote to the BBKs. I don't have the time to follow threads on the forums, etc.
I feel terrible about the constant delays in getting the pre-sold kits to my customers and I also don't want that to ever happen again. Frankly, if I had been one of those guys I would be mad as h_ll. My sincerest thanks to all of them as they all have been very understanding.
I am picking up the parts today and then they go to receive the finish. And then the last parts will go out to the guys that purchased the kits.
I will also have a substancal excess inventory of BBK parts (adapters, hats, hardware, SS lines) for sale. With the inventory, I will provide all the Porsche part numbers, Porsche part sources, wholesale prices and even the CAD drawing so the purchaser can easily produce more parts as necessary. Interested parties should contact me directly at michael@prospeedmotorsport.com or call me at 651.699.3129
This could be a great, highly profitable small biz for someone or a high margin addition to a BMW hobbiest/tuner/shop.
As to ECIS and the Rogue Engineering kits, the front kits are decent kits. Be aware they are the smaller calipers with a 40/36 mm pistons from the Boxster S/996. Note the consistently best performing kits (Movit, Brembo, Stoptech, Porsche) are those with the larger 44/36 mm pistons and larger rotors. Also please note, both the ECIS and the Rogue REAR kits are dangerous as they use the stock BMW rotor, which is only 20 mm thick.
The problem with this is the Boxster/996 rear caliper was designed for a 24 mm thick rotor. The BMW rotor these guys use is 20 mm thick. With this 4 mm difference, the probablilty you will hyper extend the pistons or worse, blow them out of the bore is quite high. I have been down this road with the Audi guys about 2 yrs ago. If the disc is worn 1 mm (.5mm each side) and the pad material is worn only 25% you are within 1 mm of the piston extending past the inner pressure seal and you will have pulled the dust boot out of its position and will get road crap into the bore.
I have nothing against these guys and certainly wish them well, (maybe one of them is interested in my inventory) but this is a accident waiting to happen. Please take note of this. And if you attempt to space the pad out to take up the difference, you begin to run the risk of the pad falling out of the caliper. The front kits are fine, but these rear kits are a very poor and dangerous design.
HTH folks understand what is going on here. And that you will all be customers of the brake fluid when it comes out!!
Michael G. Wachholz
Prospeed, Inc.
303.953.4107
Makers of Prospeed RS683 Xtreme Performance Brake Fluid™
The ONLY racing/high performance brake fluid developed and produced in the USA
http://www.RS683.com
Michael,
Maybe I should have written my post differently. I was not knocking your product, just stating what I thought happened. I was suprised to hear that you were dropping the line. There are alot different BBK's out and the market foir BMW's which makes things tight. That was what I was referencing.
On to your comments....
We have always stated the size of the calipers and our BBK performs very well. The large 44/36 mm pistons are good, but have cleareance problems (wheel) and we feel are overkill for the E36/E46 cars. We put together an affordable BBK that performs very well at the track and on the street. The rotors and pads are off the shelf and can be replaced at any time. Not the same for most of the larger BBK's.As to ECIS and the Rogue Engineering kits, the front kits are decent kits. Be aware they are the smaller calipers with a 40/36 mm pistons from the Boxster S/996. Note the consistently best performing kits (Movit, Brembo, Stoptech, Porsche) are those with the larger 44/36 mm pistons and larger rotors.
We feel that the performance difference between our kit and the larger versions (Movit) is not worth the extra $$$. Anyone who has used our kit is very happy with the performance. Nothing but positive comments and happy customers.
I have to disagree with you Michael. You went down this road with Audi's, but have you seen the failure with BMW's. I doubt it.The problem with this is the Boxster/996 rear caliper was designed for a 24 mm thick rotor. The BMW rotor these guys use is 20 mm thick. With this 4 mm difference, the probablilty you will hyper extend the pistons or worse, blow them out of the bore is quite high. I have been down this road with the Audi guys about 2 yrs ago. If the disc is worn 1 mm (.5mm each side) and the pad material is worn only 25% you are within 1 mm of the piston extending past the inner pressure seal and you will have pulled the dust boot out of its position and will get road crap into the bore.
First of, the pad can NEVER fall out because it has the stablizing pin runnining trough the top of it connected on both sides of the caliper. Even with the harsh testing we did, there was zero problems with the front or rear caliper/pad.
I wish you would not print misinformation just because you were unhappy with my post (as you have done with Steve D).
Secondly, we EXTENSIVELY tested out front and rear BBK's at Summit Point Race Track before we even released them. At this time we have several club racers and many track junkies using our BBK WITHOUT a single problem (front or rear). Again, NO problems.
Pads range in sizes and can actually take up the "gap" you are talking about, so the supposed 4mm"problem" is more like 2mm which will not cause a problem with the caliper. Again, THE PAD WILL NOT EVER FALL OUT of our Big Brake Kit, front or rear because of the caliper pin that is designed to hold it in place (front and rear).And if you attempt to space the pad out to take up the difference, you begin to run the risk of the pad falling out of the caliper. The front kits are fine, but these rear kits are a very poor and dangerous design.
Also, Turner Motorsport sells a kit very similar to ours, do you think TMS is going to sell a dangerous product with all their racing background. I don't think so...
I don't wish to make a war out of this thread, but I must defend my product when there is this type of misinformation posted. I wish you luck with the Brake fluid and if I ever need larger calipers I will give you a call.
Sean Cain
Didn't mean to start a flame war...
Whoa....
Anyway, Sean, did you get my email reply to you a week or so ago? I need to talk to you about getting some unrelated inventory FROM you.
Please look through your emails or get back to me.
Jim,
Yes, I did...I thought Kenny talked to you...sorry.
The last two weeks have been HELL...
I will send you the pricing today.
Again, sorry for not getting back to you.
Sean Cain
Been looking at the UUC...
Bear in mind that new products are emerging all the time...
NOT with that company any more.
Rob, are those Wilwoods?
Eugene
Schrick cams
URI UD pulleys
Nope. These are fully-sealed, streetable/trackable made-in-USA units fabricated for UUC under license by one of the largest domestic manufacturers.Originally posted by eclou
All details to be released shortly.
Rob:Originally posted by Rob Levinson
Is this kit the one you currently offer or is the current one going to be updated ?
This is not the VSB kit currently offered, and is called UBBK in order to avoid nomenclature confusion.Originally posted by aceves
Rob:
When will it be available, I'm gonna have my tax return burning a hole in my pocket pretty soon
i purchased a front porsche bbk today from prospeed
however that uuc looks sweet
is that caliper silver or chrome?
and will you have a rear kit available for a 318?
Uh-oh, the "when" question!Originally posted by aceves
When will it be available, I'm gonna gave my tax return burning a hole in my pocket pretty soon
We are stockpiling inventory so there will be no wait or backorder when it is "officially" announced and on the web site. At this point, the M3 fitment is probably (note "probably" as opposed to "guaranteed"!) no more than a couple of weeks away.
Pricing has not yet been set, but introductory pricing will almost allow you to get the front and rear kits for around the same price as some of the pricier German-made products.
