I think that it might be the idler control valve. At low rpms (traffic light to traffic light) the car sputters and then kicks in. If I am on the highway it runs fine. What do you think that it might be
"I never realized how fast a slow car can be until I went to the track."
______________________________
1987 BMW e30 325is v1.5 Clone
*Ground Control suspension
*Koni 5-way adjustable shocks
*Eibach Springs 450/600
*Custom 4 point cage
*1993 Mazda RX-7 TT 4 piston calipers with floating rotors.
*Turner chip
*19# injectors
*Miller MAF and 19# Chip
*AEM dry flow filter with heatshield
1991 325is for sale (in parts)
1988 BMW e28 M5 (Sold
1997 BMW 528i
2006 Volvo S40
K&N Pannel Filter
Good guess, Now clean it and see what happens.
Walk a mile in my shoes and you are a mile away in someone else's shoes.
Goodridge*UUC sways* Black TME's and mounts( switched from Red)* x-brace*brembo rotors*Zimmerman rear*Pagid*Riken Raptors* Roja Formula 7's (Bronze)* Stromung*Powdercoated AA DSB* OMP strut bar*GC RSM's* M3 alum/leather knob*JTD underpanel *Traffic PRO (sold) *Black hella Ellipsoids w/celis rings * ACS Pedals*ACS handbrake*RE Octane SSK*Wheelskins Eurotones S/ Wheel Cover( tossed-replaced with new one)* Totally Covers Front seat velour covers with custom styling *Rieger roof spoiler-lost it on fwy Stock A/B*URI CP (ditched years ago)*540 HFM (sold) Stock HFM (BeckArnley)*FMS 24 lb inj*Alum rad and some other stuff*Konis w/adj rr's*Vogtland springs ** Passport 8500(sold)*Passpprt 7500 (sold V1-1.8 with POP) No detectors at all.
Coming...nada
BMWCCA-303681
I do not know where it is! Sorry. do you have a picture of it? do I just clean it with carb cleaner? would it be easier to get a new one?
*Turner chip
*19# injectors
1997 BMW 528i
2006 Volvo S40
K&N Pannel Filter
Not having owned a bimmer older than '95, I can't say for sure other than it will be where the TB is located.Probably attached to it.
Should have an electrical connector.
you might have to get beneath the intake manifold.
It signals the DME, so make sure the part your looking for has a connector.
Coming...nada
BMWCCA-303681
thanks I will do that tomorrow
*Turner chip
*19# injectors
1997 BMW 528i
2006 Volvo S40
K&N Pannel Filter
Having just repaired a similar problem, You might want to open every electrical connector in the engine and examine them for moisture. I had a large water buildup in the connector that the fuel injectors and both engine temp sensors run through. It is located under the intake manifold.
If this turns out to be the same issue for you, email me and I will help you to fix it. BTW the problem happened on my 1988 325. Hopefully yours wont have reached the stage that mine was at.
UPdate, after reading your description again, you probably have a different problem. If it does not turn out to be the ICV then you may either have a small vacuum leak or a problem with the AFM internally. The AFM is fixable too.
== Stable mates ==
-1996 M3 Lux, bright red (hellrot), Modena interior. Aus Freude Am Fahren!
-1988 325, Alpenweiss. The commuter.
BMW HOWTOs
