I am looking at getting a set of drag slicks, and I am wondering if a 15"
rim will fit the e36 M3 or do I have to go with 16" or 17"
so if anyone knows please share your info
there are way more tire choices for the 15" rims and it would be great if they will fit
TIA
2015 E84 X1 35i ///M +JB4
__________________________________________________ __________________________________________________ _____________________________
RIP --- 98 ///M3 Mods:- Eurosport TS - (EVO)Euro 6-speed
no. I actually don't think a 16" will fit, either.
The front brakes are too big.
-jeff conner
dreaming of an ///M3 Wagon........
I give you the gratuitous wheel lift shot, with some lovely flowers as a backdrop...
I am more interrested in the backs for Drag slicks....
anyone?
I know 15s fit on normal E36s, not sure about M3s
For Sale: 18-button OBC and X1071 wire connector,, black coupe mirrors, and fog light brackets
Yes 15" rims fit under an E36 M3. Take a look here http://forums.bimmerforums.com/forum...d.php?t=723025
.-=[ Kenny ]=-. See the BFc Drag Racing Standings List for BMW street cars. Watch my drag racing movies on YouTube. Some info on
BMW turbo street car Drag Racing 101
you need to grind some material off the calipers to fit 15" wheels, but they do fit, I run them on my M3
cheers, Alan
1/4 mile-12.92 @ 108.64mph-NA 3.0L m3 daily driver
does anyone have any photos or a DIY on the caliper grind where you have to grind them and how much for the 15" rims to fit? thanks guys!
95' M3 95' 325IS
Patrick James
Current:
E38 2001 750iL - Current DD.
E36 1995 M3 Coupe - Ls1/t56 - FIXED...now with a Ford 8.8 IRS Rearend
E36 1998 323is Coupe - Back-up DD.
R53: 2005 MCS W/ GP and JCW bits. - Wifes Project Car
Past:
E36 1999 Dinan M3 Coupe AW/Sand Beige - In BMW Heaven.
15X8 w/5.5back space will fit in back with a 26X8.5 slick. Fender lips have to be rolled tightly but they will fit, no problem. A 9 with 6.5 bs might fit too but I never got a hold of one to try it.
Also, I ran Weld Pro Stars. Back as mentioned above and 15X3.5 1.75 bs fronts and had to do no grinding on anything at all. Bolt and go except for the need for hub-centric rings to center the wheel properly.
World record holder for a m52 stock bottom end.
9.41@153 c4 auto 28" et streets, e34 3.64 gearset 900+hp
E36 chassis irs world record holder 8.49@162
Th400, e85, 7685, m50 intake 26.6 lbs of boost
I was not able to put on 15's I would have had to grind a half inch minimum off my front calipers I was trying to mount 15" bottle caps
95' M3 95' 325IS
Patrick James
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
1996 332IS
Built 3.2
1996 332IS
Built 3.2
