She's in rough shape, but with some work she could work.
- Passenger side mounting tab broken (can be fixed)
- Paint damage
- Nicks and scrapes
- Fog light mounting points intact
- Temp Sensor included
It's made of tough, black, flexible plastic (ABS??). It's an OEM part and not aftermarket.
Item is located in Woodbury CT.
Shipping will be whatever the company you choose charges to get it to you.
I'm looking for $50 picked up OBO!
Thanks!
I'm not down on my E30 front spoilers yet... is this early model (running board bumpers) or late (plastic bumpers)? Where is the plastic tab broken?
This is from an early (1987) 325ic with the metal bumpers. The tab that is broken is actually a mounting bolt-stud on the passenger side that holds the side of the spoiler to the car. You can easily re-work this tab by JB-Welding another stud in there or fabricating your own way to make it fit. hope this helps!
Bump and a lower price....$30 picked up.
I'd love to pick it up. Would you do an even 20 this weekend? The broken tab seems pretty structural. I'm not sure if JB Weld, or even a fiberglass patch would hold it... is it just one of several tabs?
I'll do $30. The tab is one of 2 on each side. You can easily just re-work it to make it fit. In any case, you can come check it out and make up your mind then.
will it fit on 86 325es? sold?
