Most have seen my other post, but for those who haven't.. I recently bought a '94 Hellrot/tan 540iA, and we all know hellrot 540i's can't be automatics, so I am swapping the 6 speed parts off my '95 540i/6 donor car.
120k 540iA
Big ticket item.. took me awhile to find this
Kind of intimidating.. this was suprisingly easy though. (I used Mr. Projects post for reference.)
This is the bolt that holds the pedal box to the steering column bracket. Huge pain in the ass! Taking it to work tomorrow for removal with an air chisel.
I've made this post for reference, as well as help from all of you out there that have done this. I know I am going to run into some problems here and there.
Also started modding, don't really know what kind of drop Im going to get with these. But Im planning on getting shorter front spring pads, konis and e32/e34 touring sway bars
'88 s54 e30, '00 m5
Very nice... I'll definitely be checking in...
The sheer bolt's actually pretty easy to get out. Easier with an air chisel, but also easy with a hand chisel and a hammer. Tap to cut it, then rotate through the cut.
Or just cut a slot on top so you can remove it with a screwdriver. I think I was able to get a cutoff wheel in there.
1986 BMW 735i Turbo, 5-speed
2010 Mazda5
1966 Corvair Sedan
I might end up doing that, but I was very unprepared today and have no cut-off wheels. I think that would be safer than the air chisel. I was very close to deciding to weld the clutch return spring tab onthe auto pedal box.. but this is so much easier.
'88 s54 e30, '00 m5
Yep, I was thinking the same thing and you're absolutely right. The way you're doing it is the right way....far easier and less risky.
2010 Mazda5
1966 Corvair Sedan
watching
E34 540i Manual
Eibakh Pro Kit | Blistein Shocks | EAT Chip | Racing Dynamics Front Stressbar | Racing Dynamics Swaybar Kit | 850cis Front Brake Kit | Zimmerman Cross-Drilled Brake Rotors All Arround | Hawk Street And Racing Brake Pads |Angel Eyes | 8000k HID Xenon Kit All Arround | Plasma Coils | JB Racing Lightweight Aluminum Flywheel
SOLD!! E38 740il
Searching for E39 M5 .......
nice
~AIM- liquidtiger720 ~ Josh M. ~www.jmscribble.com
Looks like fun!
128i
keep us updated on this project!
Yeah thats what I figured with the springs, but I'll work with it, as long as its as low as I want in the front I'll be ok.
Got the pedal boxes swapped today, again, not difficult at all. Cutting a groove in the sheer bolt on the column is definitely the way to go. I'm about to put the pedals and steering column back in the car tonight.
'88 s54 e30, '00 m5
do you still have the 4l engine from your donor?
Yeah its still in the car, alusil motor as well
'88 s54 e30, '00 m5
Didn't get to work on it too long tongiht, but I got the pedal box/column back in. It was a little frustrating, but not difficult. I started the pedal box nuts finger tight first, then threaded the 2 upper pedal box bolts before tightening the lower nuts. The pedal install is pretty straightforward, but it can also be a little tedious. I ran a bolt through the opposite side of the brake pedal to line everything up so I could insert the pedal bolt.
Here you can see how close the two pedal boxes are, notice the clutch return spring bracket on the bottom right of the left bracket.
I have 3 pedals! still waiting on my clutch cylinder and I have to pull the lines off the other car still. hopefully I will get this done before the weekend when I go on vacation
This is the shift-interlock cable. Definitely do not remove this one, or your key will stay in the ignition. You have to tie down end of the interlock cable, this was a little annoying, but I got it after a little bit of garage engineering.
'88 s54 e30, '00 m5
I am interested in your 4.0. How much do you want and can we set it up soon.
uhh... I would take $900 for it, but this car is a roller. Interior is stripped, no driveshaft, no transmission, auto pedals. All wiring is unmolested though
'88 s54 e30, '00 m5
It's nice to see ppl giving e34 TLC. I'm considering the Vogtland springs with konis sports also. Did you find any info about another 540i with this combo? Thanks.
Its going to be a couple weeks. I still need it around for a couple things. But yes, it will be complete with the ecu... nothing has been removed except most of the 6 speed stuff.
Not really, I'm thinking its going to be really low in the front though. I'll have to wait and see.
'88 s54 e30, '00 m5
I just had a thought. I want my cruise to work properly when I do mine. Jonathan, have you looked into how to wire in the clutch switch? I'm sure I can figure it out but I just wanted to mention that in case cruise control matters to you.
I've thought about it. I believe I read there is a way to do it, I'll see if I can't dig it up. Cruise control is pretty low on my list of priorities though. You started your project yet?
'88 s54 e30, '00 m5
[quote=Jcbe34;9081256]Its going to be a couple weeks. I still need it around for a couple things. But yes, it will be complete with the ecu... nothing has been removed except most of the 6 speed stuff.
Ok that is fine I guess I was hoping for sooner than later but let me know.
Dave
