Results 1 to 10 of 10
Thread: 330d (turbo diesel).. aftermarket exhaust systems?
    May 2001
    Pforzheim, Germany
    im no Turbo Diesel expert... but is it possible
    to get some kind of nice sound from a aftermarket
    exhaust for the turbo diesel engines?
    i have a 330d...
    Aberdeen Scotland
    E46 330d SE touring
    Was hoping you would have got a reply by now as im intersested in changing the exhaust on my 330d. If a nice noise isnt possible to obtain is there a good sports cat that can be fitted to help the breathing?? Sorry to hijack your thread.
    Mar 2005
    Milwaukee
    '99 M coupe
    There are several folks on the Jetta TDI board that remove their mufflers and replace with a straight pipe. Seems they are a bit louder but not obnoxiously so--of course that's with a 1.9L turbodiesel 4. Even with chips and injectors....
    Cleveland, Ohio
    '07 Z4MC, '12 128i
    i wish the 330d came to the US
    2015 ProSolo STX Class Champion
    toronto
    2004 330i ZHP
    Quote Originally Posted by M0nK3y View Post
    i don't. less powerful, heavier, less 'excitment'. no thanks.
    Jan 2006
    Stockholm, Sweden
    -18 F31 Msport 320da 4x4
    Quote Originally Posted by bojacks View Post
    Compared to WHAT??
    2005 330D specs:
    Weight fully fueled with average driver: 1575KG/3516LBS (a 330i weighs about that doesnīt it?)
    3,0l Turbo commonrail direct inject straight 6
    Power hp: 204
    Torque: 410NM (303FT/lbs)
    (ECU flash gives you 250 hp and 550NM (405 ft/lbs).. at a cost ~1000$ US
    Oh.. and a fuelconsumption of ~35 MPG
    And say you want an E90.. BMW has a 335 diesel on the market..
    The new twin turbo 335D will give you 286hp and 590Nm (429 ft/lbs) STOCK.
    Flash THAT car and your talking 340 hp and 660 NM (488 ft/lbs)
    Top speed of 177 mph. And a consumption ~31 MPG
    NOW say you donīt want one!
    Diesel are easy to tune, have LOADS of power and give great gas milage. The only think lacking is that the engines have a pretty narrow power band. They reach max torque at around 1700-2200 RPM and max power is seldom above 4000RPM. That usually leads to pretty tall gears. Weight IS heavier, but not THAT much.
    //amullo
    F31 320da xdrive msport
    Broadview, Ohio
    16 IS350
    holy crap a thread from 01
    hahaha
    MODS:
    - clears all around
    - 6000k HID's
    - debadge
    - 40% tint
    - upgraded bushings
    - cross drilled rotors
    - mp3 RCA jack
    (found about about the
    last three from 3ZHPGUY)
    nathancarter is offline Stretch Haters Club #1 BMW CCA Member
    Tampa, FL
    2002 330i 131k
    You also can't really compare engine horsepower numbers between a diesel engine and a gasoline engine, because horsepower is mathematically computed using RPM, and diesel engines generally rotate much more slowly than equivalent gas engines.
    I suppose you could compare rear-wheel horsepower, using the rotational speed of the tire.
    I'd sell a kidney to get my hands on a 330D...
    Jan 2006
    Stockholm, Sweden
    Iīd sell one to get my hands on a tuned 335d..
    But i guess Iīm stuck with my little piddly 2.0 for now. Good thing i beat the CRAP out of my brothers A4 2.4i Auto from 40-100 mph!
    //amullo
    Guate
    M3 2005, 328i 2000, X5 2006
    Quote Originally Posted by amullo View Post
    Compared to WHAT??
    2005 330D specs:
    Power hp: 204
    //amullo
    word!! i love bmw diesel!!!!!! i do have a X5 3.0d and its a great performance, but i dont like the idea of a new exaust.
