- What else could it be?
About a week ago, everytime I started my car (while cold) it would make a horrible grinding sound. I just replaced the starter yesterday & it still does it.
Any thoughts?
Trace down where exactly the grinding noise is coming from and report back.
I have seen flywheel shields get bent by a blow from a rock or whatever and scrape against the spining flywheel. I also seen engine bolts that came loose shifting the tranny, allowing the flywheel to scrape too.
Did you put a new starter in, or a used one? The flywheel teeth could be messed up not allowing the bendix to retract.
For the life of me, I can't pinpoint where it's coming from.
As for the starter...w Bosch.
Actually I got my neighbor to listen (my hearing is poor). And he said it sounded like the alternator.
Does that seem right?
- You may not post replies
- You may not edit your posts
Forum Rules
