So, guys...I guess after reinforcing pretty much everything else possible on the car this was the last thing that could possible go - and it went - big time.
Here are some pictures of the rear trailing arm mounts on the driver's side and the passenger side...
The pictures show that my driver's side is still fine and that it's perfectly normal while the passengers side is torn out completely.
My questions for you guys - who makes the reinforcement plates (that I have read about) for the mounts (tubes) and where can I buy them from? I'm gonna check on TMS and Bimmerworld (the usual sites) but I just figured I'd post here first incase there's someone who has had firsthand experience with this.
I'm thinking that I'm going to have to reweld it and then put the reinforcement plates over the patched area...
Anyway...here are the pictures of the carnage.
Driver's side...normal.
Passenger side - view of one of the inner mounts...
it happens, get a trusted shop/chassis builder to weld it back up
Haha...yep, the car is going in tomorrow to the shop that we trust with all of our cars - I <3 Debold!!! <3333...
Scott (owner) came by to my house personally tonight to check out the car...he said we'd have no problem getting it fixed.
I just wanna know who to go with for the reinforcement plates and I wanted to share with you guys what's going on.
my question is, what were you doing before this happend? And what has the car been through in the past?
- Nick: Pacific Region Vice-President for BMW CCA
San Diego BMW CCA Past President Join the BMW Car Club of America!!!
Well...I think the right question would be more like what haven't I done...?
To my knowledge - the car has been well taken care of by the previous owners - the last owner being Matt - who is a great guy...
I'm thinking that it has to do mostly with my driving style and I also had a small incident a month or two ago with a work truck - it basically came out of an intersection into my lane and I had to swerve and the rear end came out just a little bit and tagged the curb...enough to upset the camber.
My guess is that it's a combination of that and my driving habits...I'm just thankful it didn't fail on me mid-slide or at 160mph.
Here's what I mean by...err, "driving habits"...
http://video.google.com/videoplay?do...59116406&hl=en
Not only that but the car is going to be put through lots more auto-x and track days...soooo...this is kind of important to me.
ouch.
...any vids of your car driving, rather than just spinning around?
Just weld it up. Reinforcement plates not required. We had the spot welds break on an E36 racecar that was used hard and put away wet for about 4 years previously. It looks like the pocket that pulled out fo yours could easilty be straightened and put back in place, with a few stitch welds added at the perimeter.
PS - a few stitches on a tracked car or something used hard are a nice precaution. Not really required, but with some extreme stresses, it will keep the pocket from pulling out.
Yeah...I was just using that as an example.
Besides...it's a lot more tempting when you don't have to turn off ASC...
Haha...we were just messing around.
*finding*
Thankyou for the advice...do you think the reinforcement plates would be a good idea just because? I just don't want this happening again...
Good driving. TMS had and article for their RTAs that had to do with just adding a weld at the existing weld spot for the RTA plate. Something about the weld does not go all the through or something like that.
2003 540i/6 Sport Alpine White III-Front and rear OEM M5 bumpers with single cut out, M5 # 65 staggered wheels w/10 mm frt spacers, Hankook Ventus V12 EVO, M5 Ft / Rear brakes, SS lines with front Ft / Rear Euro rotors w/aluminum hats, CDV delete, M5 3:15 LSD, Ground Control Coilovers w/remote adjust for rears, M5 rear sway bar w/Beastpower mounts, white gages with stainless rings, M5 pedal covers, Dinan exhaust w/ 18 in Magnaflow resinator, Dinan CAI/High flow intake runners/Throttle Body/Mass Air Meter, Dinan Stage 5 software. Zionsville aluminum radiator w/fan delete, 2 speed electric fan, 545i shifter w/ZHP knob, Alcantara interior, Technical Graphite interior trim, LED lighting ///M
"One day the two great masters will be friends"
I would reinforce the area with additional material. The metal in that area is too thin. I was faced with the same failure but caught it before the inserts ripped completely out. The shop I took it to folded a piece of 18 gauge (i think) over the edge between the two leading and welded everything out including welds 360 degrees around the inserts.
As for what caused the failure in the first place? Hard driving on blown out bushings. I subcomb to random donuts from time to time ;-)
after watching the video, you are my god
BMW never intended the car to be used like that. The cars they use for DTM, or that PTG ran are vastly modified. Seam welded, and reinforced everywhere, and they still break.
I bet that the cars and the way people drive them on this board make up less than .1% of all BMW drivers. The cars are fine if used as intended. Go outside that envelope, and stuff happens...lol With any car.
Element Tuning - 2008/2009 NJMP Redline Time Attack/Formula X Champions [Street & Modified]
RightFootDown
FS: E36 OEM fogs | UUC Chromoly RLCA's
The E36 in particular was an exercise in corporate cost cutting.
FWIW, and to be fair, I've heard that the TUV does specify that a certain percentage of recycled material be used in the production of each new car. Why BMW would use subpar materials in an area as critical as a suspension mount, well - that's the scary part.
