Results 1 to 5 of 5
Thread: Do I need to replace the brake wear sensor?
    Feb 2001
    Rio Rancho, NM
    I'm replacing my front pads/rotors (which warped prematurely) but the pads on the car are still like 80% thickness. Do I still need to replace the wear sensor?
    Anyone?
    SOLD - 1995 M3 -- Dakar Yellow, RMS Stage 1 Supercharger, AA Exhaust, Bilsteins, Fikse wheels, UUC strut bar, etc.
    Feb 2001
    Maryland
    As long as the sensor didn't trip the obc, you are fine. No need to replace!
    Feb 2001
    Southern Cal
    If the brake pad sensor didn't go off then you can carefully pry out the old one and reuse it. If the sensor did go off then you will not be able to reuse it.
    01 LSB M3, E36 M3
    Feb 2001
    Rio Rancho, NM
    No, the sensor did not go off. Cool, looks like I can just use the existing one. Thanks!
    May 2001
    37N 22' 122W 03'
    FWIW, it trips a light in the dash, not the OBC.
