1 - I've tested injectors - no leaks.
2 - I just replaced the fuel pump - as far as i know that thing is tip top (suspicious i may have killed it by running it when i had the return pinched)
3 - Maybe its the fuel pressure reg i need to get a new one.
4 - Is there anything else internally in the fuel feed system that would cause the loss in pressure? I have no external leaks
uh yes i'm a little worried. I was troubleshooting a fule pressure problem when i left the hose clamp on the return line and i ran the pump to build up pressure again. The pump made a weird "what the hell are you doing to me" noise. I wasn't able to hold fule pressure with the brand new pump installed anyway but i'm still suspicious that i may have killed it.
Anyway, i guess my real problem is my pressure. I still haven't installed a new pressure regulator and i hear that may fix the problem. My pressure holds and operates at 43-44 psi and then when i shut off the pump it drops after 5min and keeps dropping until it's at 15-20psi (if you leave it long enough). This was causing a vapor lock and consequently my car wouldn't start when engine was hot.
usually that is a fpr problem. there is a wierd set up that bmw uses it has somtype of bypass on it.(its a small box next to the tipicle looking fpr)
I have the compete set up I will sell to you for shipping+paypal fees if you want it, it worked fine on the car. but I am running an adjustable one.
will der Schnurrbart Behandlung?
www.leistungmotorwerkes.com
It sounds like a check valve problem. I assume that's what the 3/2 directional valve is. That would let the fuel return to the tank, so the pressure would fall.
Steve
2001 530i/5 S+P CDV delete/Akebono ceramic pads/M5 SSK/RedLine MTL/M5 rear sway bar
BMWCCA Member #337964
