Just came across a rare set of wheels that I think would look sick on my car. Only, there is on possibly huge problem, the offset is ET12. They are 17x8 ET12. Basically I'm asking, is there any chance in hell that I can get these to fit without really F'n up my fenders? I'd be down for fender rolling and possibly a slight pull, but that is about it.
Now, someone please school me on this:
http://forums.bimmerforums.com/forum...ighlight=gotti
His wheels are 17x9 ET24, would 17x8 ET12 stick out more than his, or less. If I understand offsets correctly, which is still up in the air, then his rims stick out 3.55 inches from the hub. (Half of 9 is 4.5 'dead center' 24mm = .95inch, so 4.5 - .95 = 3.55) Doing that same math on 17x8 with ET12 comes out with 3.525 from the hub.
Is that even remotely accurate or doable? TIA
No offset experts out there?
ttt
et12 would take a lot of work to put on your M3.
do you have any pics of these wheels?
btw your math is a little off above,
here is a good little read for you on the offsets
https://www.rsracing.com/tech-wheel.html
You could do it by doing the following:
Run 225 width tires.
Run -3 camber front (swap '96+ strut hats) and -2.5 camber rear.
Roll and pull the fenders.
Run a stockish ride height.
Those wheels better be mad FLY and cazy rare to justify the above.
Garrett
Depends on your drop and the size of your tires, 17x8 et12 stick out about 1 more inch than any conventional 17x8 et 38
Thanks for all of your input fellas...
My ride height is stock, I figured that my math was off, here is a pic of the wheels in question.
2 piece BBS designed by pininfarina
are those pininfarina's (spelling)
I miss her, back in a BMW for the time being
Cute wheels.
More appropriate for a ti than an M3, IMHO.
Don't do it.
Garrett
http://1010tire.com/WheelOffsetCalculator.asp
This is a link to an offset calculator. Pretty self explanatory, Type in your original width and offset, and then your new width and offset, and it will calculate the difference in clearnence on both sides of the hub.
Cheers
yes, they designed them...the stamp is on the one spoke
they are FUGLY
