Results 1 to 6 of 6
Thread: speedometer issues
    Apr 2006
    rialto,ca,usa
    e30 325is, , e30 325es
    speedometer issues
    speedometer is remaing down and wont read speed..
    it occasionaly pops back up but when i hit a bump it falls right back down.
    i pulled it out and the batteries on the si board still hold the charge.
    Im lost i dont know what else it could be ...
    Feb 2004
    Rochester MN
    1988 m3 2.3
    If you hit a bump and it works again, it could be the wires for the speed signal sender on the back of the diff. Look at the back of the diff and there should be a rubber boot on the sender, pull it back and see if the wires are loose on it.
    Apr 2006
    Plant City, Florida
    08 650i 08 128i 02 325ci
    The speed sensor in the diff. went bad. A $30 part and takes only 5 minutes to change. A very common problem.
    Apr 2006
    rialto,ca,usa
    did it like a few months ago...
    Jun 2006
    nashville,TN
    325is
    It's The Wiring I Swear It Is Just Shack The Wires The Next Time It Does It And If So Replace Them Or Just Crash It And Buy An E36
    Apr 2006
    rialto,ca,usa
    welll i already crashed it .. and already fixed it,,
    had to weld in a new core support..=( and new hood fenders radiator fan ac condenser and all that other bs.. im attached to the car.. its my first car.. mind u im 17 ..haha so i put in the money..but i dk what else it could be ..
