Just curious to get a price check for:
* Replacement motor cost
* Replacement motor plus necessary preventative repair (i.e. TCGs)
I have a line on an '02 M5 with about 180k on the odo, but with an engine that's got ~140k miles on it (runs REALLY well).
Thoughts?
--Peter
'03 540i-6
153k mi; bought April ‘07 w/38k mi
Silv/Blk, CWP, UUC SSK w/DSSR, M5 diff, JBR LW FW, SPEC Stage 2 clutch, Zionsville w/2-stage fan, coolant hoses, M60 intake manifold, motor-out overhaul (powder-coated VCs, TCGs, valley pan, coolant mani, head gaskets, heads refurb, all other gaskets, seals), Beisan vanos, PS pump & hoses, AC comp, fuel pump & filter, washer hoses, 88-degree thermo, DUDMD tune, Vibrant Racing muffler, Zeck CDV, Brembo solid-disc rotors w/ Textron pads & UUC SS brake lines, Dinan springs w/Koni Yellow shocks/struts, M5 front & rear sway bars, H&R 10mm spacers & studs front & rear, Pilot Sport A/S 3s, headlight adj repair, polished headlight lenses, 6k Umnitza Xenon & AE bulbs, new OEM M-Sport bumpers, gauge rings, permanent seat-twist repair to front seats, ZHP shift knob, M5 headliner kit (reinforced A-pillar clips), Schmiedmann pedals, MID & cluster pixel repair, Bavsound Stage 1 speaker upgrade & dedicated amp w/DSP subwoofers, retrofitted cupholder
I would pay no more than an arm for one and a leg for the other.
Engine prices are always all over the map. Even miles aside, is it an engine out of a wreck that still runs and you can hear it and a tidy BMW Indy shop is going to pull it out for you in a tidy way, which will be probably a bit more expensive but low risk? Or is it like if I called my local big junkyard and asked for a motor in which case it would be taken out of some mystery dead car with the words "runs" written in paint pen on the side by Raoul and Esteban with a combination of bolt cutters and oxy-torch and a forklift, probably in the rain and set down in the mud for a few hours while they take a lunch break. And theoretically you get a 'guarantee' but that really just means Raoul and Esteban go out and do the same thing with another "who the hell knows what that engine is like" car. That said...
Typically $1-1.5k for M62TU's maybe in the 100k mis? Maybe get one for less from a private seller, definitely get one for less with more miles on it.
S62's are more in the $5k range, plus or minus mileage factor.
TCG? Do it yourself, or pay somebody? Gonna be anywhere $1-2k typically, depending on how much 'and also' stuff you do and how much of the actual TCG parts you replace and who's labor, etc.
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
