Results 1 to 7 of 7
Thread: Heater Blower Switch
    Wakefield, England
    2.8 Z3
    Heater Blower Switch Fuse
    Hello,
    Wondered if anyone could help.
    I'm looking for the Fuse for the Heater Blower switch on a 98 Z3. The fuse box says its under the stearing wheel, but I cannot find it at all. I've had a look on RealOem, but no joy there either.
    Can anyone help, ive only got one speed and thats gale force!!
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Not the fuse, it's a resistor pack located in the air duct. Do a search here, as there was a write-up recently on replacing it.
    If it was the fuse, do you think you'd have gale force?
    Dec 2002
    Darien, CT
    00' M Roadster, 07' Mazd
    2000 M Roadster
    Estoril Blue, Black Top, Grey & Black Interior
    Mr. M Car reinforced rear subframe, VAC Oil Pan Baffle, Achilles Oil Pump Shaft Kit & Reinforced Oil Pick-Up Tube, Conforti Shark Injector, H&R/Bilstein, Swapped strut hats, IE subframe bushings, H&R Front/Rear Sway Bars, BW engine mounts, BW camber shims, CL Strong Strut, GC End Links, GC RSM, UUC short shift, UUC TME, UUC Clutch Arm Bushing, UUC Clutch/Brake line, Aluminum T-stat housing, S54 radiator and oil cooler, Stewart water pump, lower temp T-stat/fan switch, Aluminum Pedals, Z3 Solutions Trunk Organizer, Leather Z oil distribution block, LeatrherZ armrest, LeatherZ illuminated ZHP shift knob, Clear Bumper Lights, BMW 6 disc, Axxis Deluxe Plus, Doug Whalen seat bushings, Soundgate SDSBMW
    Plano, TX
    Z3 Coupe
    I wrote that write up. If you have any questions let me know. It is really a pretty easy job
    Dec 2004
    NoVA
    Boring Commuter
    Quote Originally Posted by bcausseaux View Post
    Hmmm.... gotta try the thumb on the wiper trick next time. It was a major PITA removing the wiper arm.
    Anyone know what adhesives they used for the weather stripping & wiper console?
    SW Florida
    Quote Originally Posted by dave330i View Post
    For all those similar applications, I use a 3M strip caulk. It's black, super sticky and comes in a box of 12" strips (various cross sections= 3/16", 1/4" and maybe 5/16"). You can get it from Eastwood or a local autobody paint/supplies outlet.
    CA
    228i convertible
    I bought the resistor, but mine started working again of its own accord. I therefore have one spare resistor. It's new in box. If anyone needs one pm me.
    Alpine White 2005 325i
