Hey everyone, new here. Girlfriend is picking up a Z3 and it has a dented driver side lower rocker panel. Its that panel that goes under the door from the rear of the front wheel to the front or the rear wheel.
Is this part replaceable or is it welded into the car itself? Is it simply a part that can bolt right off like a fender?
I tried posting a pic but since I am new I do not think it will let me.
Thanks and looking forward to being part of the BMW community.
I checked my Bentley manual and I believe it is a welded in part of the body. I also looked at my wife's 01 Z3 and it looked to be welded in. I'd not lay any money on it but I'm pretty sure a body shop would have to do the work rather a do it yourself job.
Welcome, yes the part can be unbolted and removed without much fanfare IIRC.
Part numbers here if it needs to be replaced:
http://realoem.com/bmw/showparts.do?...35&hg=41&fg=10
Depending on the damage a good body shop may be cheaper.
2002 Alpine White w/ Black 368 (<OO \(||][||)/ OO>)
Power: Custom Exhaust w/ High Flow cats, CSL headers, built, low-compression Supercharged and aftercooled S-54, ViPEC standalone ECU, Vortech V2 Si trim
Driveline: Euro 6 speed, 3.64 diff w/ 40% Lockup, Rogue Octane SSK, UUC Red TME kit, UUC Stage 3 LTW Flywheel/M5 Clutch, SS Shift Knob
Suspension & Brakes: TC Kline True Match Coilovers 500f/500r w/ adjustable camber plates, Racing Dynamics sways, Custom front sway endlinks, ATE fluid, UUC/Willwood BBK 6 piston f - 4 piston r , Slotted E46M3 Rotors, Stainless Lines, Strong Strut, IE Subframe & adjustable rear trailing arm bushings
ICE & Misc: Projector Z's w/DDE & 5k HID, 19'' Gold HRE C20's, Custom Aux pwr outlet, footwell lighting, ACS Splitters, Areo Sideskirts, Custom gauge pods, Z8 Start, Pioneer AVIC Z3, Clarus Components, 10" RE Sub in a Mister-X Enclosure, Alpine PDX 4X150 + 1X600 Amps
Coming soon: and a visit to Randy Forbes
If it is a 1998 1.9l, I have extra rockers I can sell for 50% of whatever list price is.
Just let me know
1991 e30 318is Slicktop - Gone
1996 LS1 Z3 - Gone
99 e46 323i - Gone
2003 e46 xiT - Hers
2014 F-250 CC- Mostly stock
1996 LS1 Z3 - Gone
99 e46 323i - Gone
2003 e46 xiT - Hers
A 99 M with the rockers removed for a total body respray:
all panels can be removed easily...
except in the case of the coupe...the roof panels cant be removed
I sent your girl an email but just wanted to give you a heads up that the rocker shipped earlier this week via UPS ground and should arrive on Friday. Things were super hectic around x-mas and I wasn't able to get it out before hand.
Just so you know you got a killer deal on this thing, between packaging materials and the actual shipment my costs were $63 and change...so you got this rocker for about $6....when I thought I was selling it for $40 + shipping doh!
1996 LS1 Z3 - Gone
99 e46 323i - Gone
2003 e46 xiT - Hers
