An engine is capable of producing horsepower does not mean that it is. The boost fixed boost pressure only means that the capability is there. Actual output power is still controled via the throttleplate position regulating airflow to the cylinders. Yes it is possible to have a DD that is not floored to max routinely last and require a small rebuild however, if you are pushing that much power for an exrended period of time there will be more damage. This what is meant by full power hours. I can run full power for x hours or partial power for y(partial)=xhours.
If your not leading your following.
i'd like to see you give it a shot. my dad dropped a stock s2000 in a streamliner and went 260. granted it was a lot lighter and more aerodynamic than an e34, but hey, i got my hopes high for you.
The only real way to know is to try, then taking the engine apart (if it's not allready done). But with a pull that long, this is a lot of heat to get rid of.
I aint saying that it is not possible but just that it need to be a serious engine. On a short pull the mass of the head and block can absorb most of the heat (when it makes his way to the radiator the car is probably allready decelarating). On longer pulls, the mass of the block and especially the head, can't absorb all the heat generated, shure aluminium have a good heat transfer but not a good heat retention and a low melting point. After a 45 sec pull, your motor may look like a pressure cooker. So to acheive this I would not use the inline 6 (and it's the one I prefer to drive) At least a V8 and if ever possible a V12, why ?? Just to spread the heat, just compare a L6 and a V12, and say you need 900 HP, well every heads have to handle 450 hp yelding better chances of staying together, add a huge flow of coolant trough the whole block oil sprayers under the pistons and on the valvetrain is definitely putting more chances on your side.
Best crank/rods/pistons that money can buy maybe it can be done without nuking the engine. Choosing the best engine for an application is the best insurance that somone attempting this can have, even if it's possible to do it with an inline 4 !! Yeah why not a huge turbo, nitrous, 4 spare blocks, a guy can handle it. It shure is cheaper to try this from a V engine, that is my personal opinion.
Fun thread by the way
My Honda VTR1000F motorcycle build-----Leakdown tester-------M60 oil pump bolts------1000hp-----Jeep care
I wonder if that 1200 hp M5 has ever top a top speed run?
Take some wait out of there, and then TT it
You guys know Larry? He's got the red 1998 Mazda RX7 with a Corvette engine and trans running a little nitrous. He's pretty active in the ECTA (East Coast Timing Association), and has a Green Hat with a 204 pass, and his brother ran 202. He's ran it at Bonneville, and the car he had before that was a 1979 Volvo 242 that ran 173, also with a SBC. They've the Waddell Brothers Shade Tree Racing. I keep telling him to stick a Ford in it if he ever wants to be fast...
He's evil, I work with him, and he gives me ideas.
I don't think there's anywhere in Norway that's long enough for a 200mph run.
for aero, toss on an Alpina front bumper. they've had that bitch up to 180+mph, and that was back in 1989.
the 6 speed transmission from a euro e34 m5 will match up to the m30 powered 535. if you could get 6th gear to go really long and fabricate a twin turbo setup, it's probly possible. we should do a bf.c 200mph challenge.
Check out the top car on this page. It's only 198mph but that's pretty close.
http://www.need4speed.ws/essence3a.html
they way i see it is, an e34 could easily do 200mph if it were built up enough.. im mean look at the e60 m5... 500hp, and the e60 is fucking huge! Imagine what is possible with 1000 hp and a lighter e34.
Here it is the answer. http://cgi.ebay.com/ebaymotors/BMW-A...ayphotohosting
you ar right, in a way , but you need TORQUE to turn those tall gears, adn especially to accelerate the car up to top speed before the start of the measured mile.
I hereby request a dyno vid of said engine pulling top gear at full boost at redline(or within 500 rpms of it) for approximately 2-3 minutes continuously.
thank you.
On a personal note:
I wouldn't want to run 200mph in an e34 honestly, though i have friends who can do it in their supras etc... 170 on a stock 97 TSi AWD was quite scary enough for me to puke my guts out.
It seems that many 500-600 hp cars with decent aerodynamics can acheive this, for us, I think that a good 700-800 hp should do the trick
Every BMW I've owned has had a, ah, optimistic speedometer. I'm also not buying somebody driving (or a passanger) taking a pic of the speedo at that speed. On the first pic, you can't see the economy gauge needle, on the second one below it, it's like halfway.
For now, I'm gonna concentrate on running a timed 150mph and go from there.
1 minute @ 200mph is 3.33 miles. That's 3.33 miles to walk picking up bits of the engine then!!!
How fast does Redfive go with 335rwhp?
I think about 500 - 600 hp with a 525tds differential will put an E34 to 200 mph
You guys are talking about adding 6 gear boxes etc. There is no reason to have a 6 speed - the final gears are not that much lower ratio than with a 5 speed. Hell, a 2 speed with a 0.90:1 2nd gear and a 2.50:1 rear end would do just fine if its a true salt flat car.
Im being facetious... but until someone proved to me that it would endure at 1000 hp for SEVERAL continuous multi minute runs (as opposed to a dyno sweep or 1/4 mile only) I wouldn't bet on it being suitable.
You don't need 1000 hp anyway... how ya gonna put it to the ground? Especially when running the narrowest tires possible?
Actually, it's a huge problem. And the surface of the salt flats is something the racers try very hard to protect, so that's one of the reasons why you see big diesel 'pushers' getting the race cars up to speed. Traction problems at low speeds make for easy wheelspin, which is a big no-no on the flats. (ok, sometimes it's the gearing of the race cars)
1986 BMW 735i Turbo, 5-speed
2010 Mazda5
1966 Corvair Sedan
