Page 1 of 5 12345 LastLast
Results 1 to 25 of 125
Thread: Attn: newbies,here are your OIL FACTS
    carlisle,pa
    99 bmw323conv
    maybe this will help stop all the; new OIL posts for awhile:new BMW's require synthetic. As far as weight, only certain production dates of M3's and M5's require the use of Castrol TWS 10w-60.
    2) The Factory BMW Synth 5w-30 is a version of Castrol TXT Softect sold overseas. A few important things about the BMW oil a) it is a Group III hydrocracked oil which cannot be called synthetic in Europe, b) it is a heavy 30 weight (30 weight can run from 9.3-12.5cst@100c, the BMW oil is about 12.2cst), c) it is a ACEA A3 oil which means that it is approved for longer change intervals and has a HTHS (High Tempurature High Shear) measured at 150c of greater than 3.5.
    3) In the US, the only Group IV PAO Synthetics that are available are 1) Mobil 1, 2) Amsoil (but not the Xl-7500), 3) Royal Purple, and 4) German Castrol 0w-30 (it has the red label and says on the back, "Made in Germany). Redline is a Group V PolyEster based oil. All other Castrol, Quaker State, Pennzoil, Valvoline "synthetics" are a Group III hydrocracked oil. It is debated how much better Group IV base oils are than group III, but generally they are considered better.
    4) When looking for oil for any BMW that does not require Castrol TWS 10w-60, you want to purchase an oil that has either/both of the following ratings, a) ACEA A3, or b) BMW LL-98 or LL-01.
    5) Note that Mobil 1 0w-30, 5w-30, and 10w-30 are NOT ACEA A3 or BMW LL approved oils. This is because they all are thin 30 weight oils (approximately 9.8-10 CST@ 100c) and have HTHS of approximately 3.1. Mobil 1 0w-40 and 15w-50 are A3 rated and the Ow-40 is BMW LL-01 approved. For 99% of climates and users 0w-40 or 5w-40 is the appropriate grade. There are some 0w-30 and 5w-30 oils (like the BMW 5w-30) that are forumlated on the heavier end of the 30 weight scale and are accordingly rated A3. These oils will work well also. LOOK FOR THAT ACEA A3 rating. If the oil doesn't have it, pass on it.
    6) Some people seem confused about how oil thickness is measured. The first number (0W, 5w, 10w, 15w, etc) is a measurement of how thick the oil is at tempuratures of -35c- -20c (depends on the grade). The lower this first number the thinner the oil is at LOW tempuratures. The second number (30, 40, 50) refers to oil thickness at 100c (operating tempurature). 30 weight can be from 9.3-12.5 cst, 40 weight from 12.6-16.2 cst, 50 weight from 16.3-22cst (approximate). So you can have two oils, one called a 5w-30 (i.e. bmw oil) another 0w-40 (Mobil 1) that are very similar thicknesses at operating tempurature. Compare this to Mobil 1 Xw-30 which is close to a 20 weight oil at 100c. For more information here is a link with exact numbers
    7) BMW's recommended interval of 12,000-15,000 miles is to long. Used oil analysis has shown the BMW oil is generally depleted at 10,000 miles. Running it longer results in excess wear. It is highly recommended that you change your oil once between each BMW recommended interval (approx 7000-7500 miles). If you want to run your oil the BMW recommended interval, I would suggest that you use Mobil 1 0w-40 or Amsoil 5w-40 and change the oil filter at 7500 miles. I would encourage a full oil change at 7500 if you want your engine to last.
    8) If you want to spend a few hours learning about oil, go to bobistheoilguy.com
    Cary
    but its like a different language.... so which one do you suggest if you were going to change your oil?
    Unless you have an M3, in the following order:
    1) Mobil 1 0w-40,
    2) Mobil 1 0w-40, and
    3) Mobil 1 0w-40
    If you can't find the 0w-40, the Mobil 1 SUV 5w-40 is a great oil. Can't find either of these, then go to your dealer and get the BMW 5w-30.
    The Mobil 1 0w-40 is a great oil, widely available (Walmart, Checker, Kragen, Autozone), and moderately priced. It is factory fill in Mercedes AMG, Porsche, and Austin Martin.
    Cary
    stashed in garage: 70TorinoGT/CJ 300hp conv
    68 Olds 442 conv 455ci.385hp
    68 GTO conv 400RA 1 366hp
    68 Coronet RT 440sixpack 430hp
    DD 01 Sierra step side 270hp Vortec
    Jan 2006
    Naples, FL
    1995 BMW 318is
    Sticky Please!
    just keep this one at the top and call it a day!
    "Before you can think outside the box, you have to know whats in it"
    -Matthew
    M42 Club Member #126
    Oct 2003
    Northern Virginia
    No more
    What about m3's?
    2005 330ci (sold)
    1998 328i (sold)
    1997 M3 (sold)
    1989 325ix (sold)
    Jan 2006
    Naples, FL
    1995 BMW 318is
    Quote Originally Posted by Jontran8 View Post
    What about m3's?
    no offence, we love your cars, but there is an M3 section.
    -Matthew
    carlisle,pa
    99 bmw323conv
    some info for M-3
    think Castrol TWS 10w-60 is made in Germany, this means it is group IV??
    Thanks for the great info!
    Is the Mobil 1 0w-40 good for the occasional autocross or track day, especially in the warmer summer months?
    yeah so basically, use the m1 0w-40 like me
    So is BMWs own recommendation of Castrol Synthetic oil rubbish?
    In reference to the Above Comments:
    1) The TWS 10w-60 is a very specific oil and likely a Group IV/V blend. The reason that BMW specifically recommends and imports it is there is no equivilant oil in the US. In Europe, Shell & a few others make an equivilant 10w-60.
    2) For Autocrossing and Lapping on Hot Days. For autocrossing, the 0w-40 is fine as you do not see high sustained oil temps. For lapping days, you may want to consider 15w-50 as you will high sustained oil temps.
    3) The BMW 5w-30 Synthetic. This is a good oil at a fair price ($4.00). Mobil 1 0w-40 is a better oil, especially for longer change intervals. The problem is the combo of the BMW oil and 15,000 mile oil changes is not a good one.
    4) A note concerning Mobil 1 5w-40 SUV oil. I know that somebody is going to go to buy this and say "hey it doesn't say ACEA A3 on the back." They are correct. The 5w-40 oil repackaged Mobil Delvac 1, a Synthetic Heavy Duty Engine oil originally designed for trucks and fleet vehicles. This oil is slightly heavier than the 0w-40 and has an HTHS of 4.1. It meets ACEA E3,4 & 5 which are diesal requirements but still require an HTHS of greater than 3.5.
    I have been crusing through this site and noticed there is a lot of misinformation and confusion about oil. Here are a few things you should know about oil for BMW's:
    1)As far as weight, only certain production dates of M3's and M5's require the use of Castrol TWS 10w-60.
    Oct 2003
    Northern Virginia
    No more
    Quote Originally Posted by Jetblack95 View Post
    Thanks for the love. But last I checked e36 m3 is still an e36, no?
    2005 330ci (sold)
    1998 328i (sold)
    1997 M3 (sold)
    1989 325ix (sold)
    Jan 2006
    River Ridge, LA
    2016 340i
    That is all very good information. Based upon these reccomendations, you can also buy WalMarts House Brand Full Synthetic oil (5 Qts for $12.50) in the 5-30 or 10-30 weights. They both are ACEA A3, have Viscosity ratings at 100c of 10.3, HTHS of 2.92 and 3.12. Pour Points, viscosity indexes, etc., are all comparable. They meet ILSAC GF-3, API SL/CF, and Viper and Corvette specs also.
    Use this stuff, save some money, treat your car to 7500 mile oil changes, and you will drive a long time without engine problems.
    Very slippery also.
    Planet Brooklyn
    e30
    I use:
    10w40 synthetic blend in my OBD1 e36 6cylinder 6.9 quarts w/o oil filter
    No problems at all in fact, I have to change the oil today
    Jan 2006
    Delaware
    97 328is, 2016 F150
    very good information. and useful.
    I use royal purple and change the oil every 3000-5000miles.
    -Jason
    --I shoot a Nikon D300. I track a 1997 BMW E36. I wrench with Matco.
    I Boost a 2015 F150 Ecoboost --
    --I don’t Fail; I succeed at finding what doesn’t work--
    --Horsepower is how fast you hit the wall and torque is how far you take the wall with you--
    --If you can leave rubber from the apex to the braking zone, you have enough power--
    --1997 BMW 328is--2016 F150 CCLB Ecoboost
    --2004 F250 CCSB FX4 Diesel (sold)--2006 Acura TL (Sold)--2010 Acura MDX (Sold)--2019 STI (Sold)
    carlisle,pa
    99 bmw323conv
    changing your oil is a good thing. I read some people like to make a marathon out of it with questions like can I wait until 15000 miles, 20000 miles? think about this ...your OIL filter can only take out dirt,grit, blackened oil from blowby in something like 11 microns.....that means for you people that think you are getting your "MONEYS WORTH" out of your expensive oil are actually running this oil with some grit that measure 10 microns or less...can you say worn out connecting rod bearings?....OIL is CHEAP....its your choice
    Canada
    E36
    Quote Originally Posted by 97silver328is View Post
    You sir, made a good choice.
    Royal Purple is awesome, I run that in the 540i. In my 318i I'm not quite as picky but I wouldn't drop to Mobil1 territory anymore, Lubromoly now.
    Jan 2006
    Naples, FL
    1995 BMW 318is
    Quote Originally Posted by slim17265 View Post
    call me stupid but this post really didn't make sence to me. mainly the part that the filter will only get stuff thats 11 microns and larger, yet the grit we have is 10 microns? did i read that right?
    -Matthew
    Aug 2001
    Lincoln, NE
    '05 997 C2, '15 JKU
    IIRC the US-available Castrol Syntec 5-30 IS an ACEA3 oil, and I and others have used it well in the M50 motors...
    in fact, I was VERY happy during what was effectively a 1500 miles track weekend with a fresh change of castrol in a friends 95 M3...
    the best part??? the BMW 5-30 is cheaper than castrol... so just get the BMW stuff.
    I run Castrol GTX dinosaur oil in the M42... 10-40 in the winter, 20-50 in the summer.
    this space reserved for pissing off liberals...
    ronthebabboonslayer: "helmet guy's post is far from polluting"
    carlisle,pa
    99 bmw323conv
    maybe it will make more sense if you can visualize a filter orfice of 11 microns in diameter everything smaller than 11 microns go through to wear out your bearings.
    Cincinnati
    93 325is, 86 318i, 92 626, 88 B2200, 93 VW Passat
    I am on 10w 30/40 Castrol Syntec Blend every 5K. Am considering going to the German Castrol 5W 30 every 7.5k though.
    Mystic, CT
    97 328 IS
    I absolutely love German Castrol (the green stuff). I run it in all my motors that I've built for honda's over the years. I'm just starting to get into the BMW stuff. I'd like to run the GC in my E36 non-M3. Is this a good oil to run? I'm not concerned with costs at all. I run this oil in my built Honda race motors and change it every 400-500 miles...so as you can see, cost isn't an issue.
    BTW....REAL German Castrol only comes in 0w-30, not 5w-30 (for the post above me). The kind you want to shop for is green in color and you have to read the code on the bottom of the bottle to get the real stuff. You can find out which codes to look for on bobistheoilguy.com. Absolutely the best oil site ever....I found that place years ago, and have sworn against GC since then.
    Jan 2006
    Naples, FL
    1995 BMW 318is
    so then it isn't so much the oil that we need to worry about but the filter. any recomendations in that area?
    -Matthew
    Dec 2005
    Valencia, California, USA
    BMW 318is
    so what should i use for my 318? 0w 40 mobil 1 is good?
    Corona
    1992 325i
    e36 is just a chassie name...the engine (s50 or s52) is different and bigger then then normal 3 series (m50 or the m52) engine...
    and i do use castrol...but not sure what weight...my dad gets it so yea...but when i start getting the oil myself i'll know what to get...I dont think he gets me the greatest because my car is so old and he hogs the mobile oil all to him self and his WRX...so yea...lol
    Let the Tweaking BEGIN!
    Jul 2004
    sOCal
    95 325i
    Quote Originally Posted by bambamIS View Post
    Which is it, love it or sworn against it?
    1995 325i Schwarz II, Dove Grey, Sport Package
    H&R Sport Springs/Koni SA's
    X-Brace
    3.2L M3 shock tower reinforcement plates
    M-Roadster rsm reinforcement plates
    M5 replica rims wrapped in BFGoodrich g-Force Sport 235/40 ZR18
    Cosmos CAI
    Zionsville Autosport all aluminum radiator (just say no to plastic)
    FS: 4 E36 16x7 sport rims in chrome wrapped with Yok AVS ES100 225/50ZR16
    mmm Guinness
    Nashville, TN
    1997 328i
    I'm not disputting anything you said as I think it's great informative experience.
    I thought I just chime in with my experience/etc.
    I use Mobil 1 15-40. I go around 10K between changes with a new filter around 5K and see no oil degradation. I know this because i have sent samples off to Blackstone labs and they show that the oil is still well within "normal wear" of viscosity, metal percentage, weight, etc. and even said I could probably go another 2-3K but I like the ease and round # of changing every 10K.
    I feel very confident in going 10K between oil changes WITH an oil filter though too around 5K. This of course is all personal peference as I know some people change at 3k religiously even when the have synthetic. To each thier own.
    car just turned 110K and runs very, very strong. Actually an oil change is planned for this weekend.
    "A fast car does not make a fast driver"
    Venezuela
    BMW 318is, 1993, 5 speed
    I am using Mobil 1 5W50 in my 318is (M42). In the past I used Mobil 1 15W50and Castrol Synthetic.
    My car doesn't seem to like Mobil 1 5W50. I am experiencing some oil consumption with it (3/4 quart after 3500 miles), which I didn't have with other oils and, from time to time, I have this annoying lifter noise when I start the car in the morning, especially if oil is starting to get low. My car has only 35000 miles, no leaks and perfect conditions. I have hot weather all year where I am.
    Why is this happening?
    Mystic, CT
    97 328 IS
    Quote Originally Posted by guinness325i View Post
    WTF? That's wierd....well whatever I wrote I DID mean that I swear by GC, meaning I love it and would make babies with it if I could.
    Miami, Fl
    93 bmw 325is, 06 airforces
    oil change
    wow...maybe i should chill with the paranoia....i change my oil every month. My 325is - every 16th
    318is - 25th ( well i dont drive it anymore so i havnt done it in a month)
    May 2005
    Chicago USA
    09 Yamaha R6s & 95 325iC
    ^^that's nuts... i change change filter every 2000-2500 and oil every 4000-5000 mobil 1 0w-40 in winter, pentosynth or M1 5w-40 the rest of the year
    -Ivan
