Thank you thank you for the easy step by step on replacing the resistor. I completed it in 25 minutes.
Thank you bcausseaux for the easy step by step process on replacing the blower resistor. It only took me 25 min to complete the whole thing and the blower is working just fine. Now my wife can stay warm with the heater and not just the heated seats, lol. Thank you again!
I replaced the resistor last month but the blower is still playing up.
I'm going to change the motor, but the dealer claims this is a dash-out job!
Surely to replace the motor itself, you can access it the same way I did for the resistor?
Mine is similar but different, my ac is now amazing. But my heat only works on 3 & 4. Back down to 2 its cold...
~Ken~ '99 M coupe THE "original" TT Stage 3 - HTA3586R; 701 whp 672 wtq @ 26.5 psi ; NeverSell - CoupeCartel
Thanks, this is great!!!
Even when parked, or only while driving?Originally Posted by mharrison
Great write up....
I have a problem and i'm not sure if it is related...
I have a blower sound from the foot well that is always blowing.
It's not terribly loud, but is always going.
Will cleaning or changing the resistor fix this???
There's a cooling fan for the DME (engine computer) that draws/returns air to the passenger footwell__this always runs. If the key is on, the DME cooling fan runs.
Are you hearing the noise in the driver's footwell too (assuming LHD...); can you feel where the airflow is coming from?
The answer you seek is in the wiring diagrams. The blower motor runs at the lowest speed any time
the fan switch is in position 1, or
the fan switch is in position 0 and
the A/C button is pushed in or
the recirc button is pushed in.
This is per the 2001 diagram, and I know because Di's resistor didn't make it to 200K miles.
/.randy
Thanks for this write up!
I just bought a '96 Z3 and this is the first fix I'm going to try by myself. Hopefully my fan switch will work again in the next day or two!
Anyone have insight on this because I am still confused about it. I will gather its potentially the same latch mechanism broken in some way.... When I go from 2 -> 3 I hear a slight click like something is latching open and then heat comes on. I'd love an idea....even though the cold weather is practically gone.
So I finally tried this out today. The wipers were definitely hard to get out. I just sprayed some wd40 on them and shook them loose. Not too bad, I guess. Apparently no one had been under the front trim of the car I bought for over 17 years. There was a lot of junk and leaves and dirt in there. Got a chance to clean it out. When the resistor came out, I was planning on heating it up with a soldering iron and/or dropping some solder on it to make the connection again, but the contacts literally just disintegrated in my hands! The thing was old and terribly rusted. Ordered the part off of eBay and should have blower working at every level by Thursday, hopefully!
Success! The new part came in and as soon as I plugged it in, it worked flawlessly! Thanks for the tip and this guide! I love this forum. .
Never got a chance to fix this on the old car... but it's definitely on the to-do list for this one.
I soldered all the connections on mine several years ago when it quit working and it is still aok.
You forum guys are great.
I am just going through my "new" 2001 3.0i and found that it had the full speed only fan problem, only comes on on highest fan setting. Some disappointment, followed by the realization that I'm probably not alone, followed by the discovery of this excellent photo-guided repair thread. Looking forward to fixing it now that I've seen the detailed instructions.
Thank you!
1999 Alpine White M Roadster
I have the same problem. Thought I would look here first and voila. Going right out to the garage and fix this thing. Found it, the problem with mine was the tiny contact on the overheat sensor mounted inside the resistor pack. A quick dose of emery cloth and voila, it worked. On the other hand my wipers were difficult to remove. I levered them off with an open ended wrench under the pivot point, and gave a sturdy knock with a hammer to the loosened nut. Thanks to this post to let me know where to look.
Here's a tip:
http://www.bimmerforums.com/forum/sh...2#post28831092
BMW MOA 696, BMW CCA 1405
Here is a tip for removing windshield wipers.
On the shaft that is holding the wiper arm - the shaft you took the 16mm nut off - put a 12mm open end wrench underneath the wiper arm. On the drivers side this works particularly well. Now put a tire iron or something similar between the 12mm wrench and the underside of the wiper arm, and either lever this or twist the tire iron with a wrench and it will pry the wiper arm off the shaft with no drama.
This works better on the driver side because the 12mm wrench is just wide enough to fit on the shaft below the wiper, but it bottoms against a thicker part of the shaft below that. The passenger side shaft is a little different but it still worked.
A quick thanks for this great 10 year old write-up.
My fan is working correctly on all speeds again after a quick clean-up of the contacts with some sand paper following these instructions.
cheers.
this was a great set of instructions. i just had some issues getting the damn wiper blades off. no matter what i did and sprayed, it just wouldn't budge. i ended up buying a windshield wiper puller off amazon (https://www.amazon.com/gp/product/B000L7JQE8) which did the trick for me. it kept slipping off so i ended up putting the nut back on before using the puller to anchor it.
If you have AC on then yes. But othervise it should not blow anything when standing still. On speed it will give you nice blow without fan running at all.
I rarely use AC and I rarely keep fan on at all. And I like good breeze on my face but it just pulls so much fresh air from outside on speed that usually I use fan only on rain.
Z3 & E36 RamAir systems, send private message for more information.
