Page 3 of 5 FirstFirst 12345 LastLast
Results 51 to 75 of 116
Thread: ac fan only works on 4 write up :)
  1. #51
    Nashville, TN, USA
    2009 535i Xdrive
    Yes, Thank you OP. I did this about a month ago. Lifesaver!
  2. #52
    melbourne, fl
    1999 Z3
    Thanks again for this site. Had the same issue happen yesterday and was scheduling an appt today to get it looked at. Now I will try this myself when I get home!
  3. #53
    Dec 2004
    Spring Lake NJ, USA
    '01 MCoupe '02 M3C/6
    Anyone have decent closeups of the working side of the resistor pack?
    On the E28 series cars - there was a relay like contact set on the resistor pack that connected power to all three resistors (full-speed, ie - 4 - is straight through, no resistor used.) This contact was held shut by being soldered together with "Woods Metal" (a low temperature solder.)
    If the airflow was completely shut off on an E28 (and it was possible) or the intake was blocked - the resistors would start to overheat due to no air flowing over them, and rather than have a fire - the Woods Metal would melt, disconnecting power to the 1-2-3 speed resistors.
    Fix for that one was simply to heat up the contacts with a soldering iron and press them back together. They'd stick together again if heated right, and the broken relay pack became a working relay back.
    From the description people are giving about a "telegraph key" sort of thing, I suspect this resistor pack uses the same safety feature - and if you lost 1-2-3 speeds but still had full-speed, it's the safety contacts that have opened.
    So need a picture.. or two..
    Don Eilenberger
    '01 M-Coupe, '03 525iaT, '07 R1200R
    '06 Porsche Cayenne S - Titanium Edition (Iceland silver/Titanium
  4. #54
    Jan 2006
    Dubai, UAE
    S50 M Roadster Jeeps
    Followed these instruction last week (Thanks!). Just pulled out the resistor pack and cleaned the contacts with WD40 and a small wire brush... There were no signs of melting at all and all speeds work again. The pack seems pretty simple-the resistors are just coils of wire in various sizes.
  5. #55
    CA
    228i convertible
    I bought the resistor, but mine started working again of its own accord. I therefore have one spare resistor. It's new in box. If anyone needs one pm me.
    Alpine White 2005 325i
  6. #56
    Sep 2009
    Murphy, NC
    '01 Z3 3.0i Roadster
    I have attached a jpeg of the blower switch/resistor pack wiring with a little extra labeling.
    As you can see, the voltage to the blower motor is dropped across all three resistors in switch position 1, two resistors in position 2 and one resistor in position 3. Also note that there is a thermal cutout in series with the resistors that ONLY interrupts power to the blower in the first three positions.
    If the blower motor only operates in position 4, the culprit is most likely the thermal cutout (OR the contacts for the pack in general), but it could be the last resistor before the cutout as well.
    The trick of reheating the contacts of the cutout with a soldering iron while holding them together should work, but I would caution against adding any solder just in case they selected a material with a specific melting point.
    It's a shame that they didn't use a bi-metal contact. Then it would pull away when it got too hot and reset itself after it cooled back down.
    Dennis
  7. #57
    Dec 2004
    Spring Lake NJ, USA
    Quote Originally Posted by dkindig View Post
    Yup - same design as the E28 one. Google "Woods Metal" - very commonly used for this sort of safety device, as well as the meltable plugs in sprinkler heads.
    Ah - found it. 158F melting point: http://en.wikipedia.org/wiki/Wood%27s_metal
    I actually have a bar of it somewhere..
    Dennis
    The bi-metalic contact would be nice for resetting, but I'm guessing they assume they don't want the resistors repeatedly overheating if the obstruction to the air flow isn't removed.
    The dumb part on BMW's part was - you could shut off all air-flow quite easily with the sliders on the E28 heater. MANY of these failed due to the design. At least on the Z3/M-series you can't cut off all the airflow without some serious intent (put it on face level then close ALL the face level vents is about the only way I see to do it.)
    Don Eilenberger
  8. #58
    melbourne, fl
    1999 Z3
    Quote Originally Posted by pendragon View Post
    Mine did the same thing....for abt a week and quit again. Thanks to the great pictures from the OP, I was able to do this yesterday in 30 minutes.
  9. #59
    Birmingham, AL
    99MCoupe, 06MRoadstr
    Heat up your arms
    Thanks bcausseaux! After reading your DIY, I did this job on our Coupe. The wiper arms were stuck tight. I didn’t want to go out for a puller so I tried my electric heat gun. I set it on low and pointed it straight down at the shaft while I jiggled the base of the arm. The arms popped off in about 30 seconds.
    The other minor issue I had was with the sealer that’s between the plastic panel and the windshield. Mine was in bad shape so I cleaned it up and applied 3M Strip Caulk. Problem is the next time it’s taken apart, the 3M stuff will be a mess to deal with. I need a better idea.
  10. #60
    Feb 2010
    SoCal
    Z3, M5
    Excellent write up! Of course my fan resistor goes bad right after I read it... and was a nice and easy fix!
    Thanks!!
    -Joe p.
  11. #61
    Sep 2009
    Seattle WA
    1998 M Roadster
    DIY Fix
    Amazingly, as I was attempting this fix and went to the dealer to purchase a new resister pack, the parts guy suggested to clean the contacts with a little sand paper and then contact cleaner (the part where the "telegraph thingy is", and not to purchase a new one. Low and behold, it worked great!
  12. #62
    far away
    Shoes
    Quote Originally Posted by oscilloscope View Post
    If your ac switch is turned off, but your recirculation of air button is depressed the blower will still blow air out of the vents. Turn off the recirc switch, and the blower should stop.
    i have the same problem lol!
    mine still runs regardless of recirc position. nobody has a fix yet?
  13. #63
    Feb 2010
    SoCal
    Z3, M5
    Quote Originally Posted by Waterguy View Post
    Nice... I tried using contact cleaner alone.. didn't sand the contacts, and it still didn't work. I figured a 13 yr run was good enough to replace.
    At least it didn't cost an arm or leg...
    I love easy fixes...
  14. #64
    Tampa, FL
    '08 E90 M3
    Ugh...I just had this issue. Tore it apart, cleaned it, put the resistor pack back in there, checked it, YAY! it works. Buttoned it all back up and took it out for date night. DAMN. It was only working on 4 again.
    Guess I'll have to buy a new one. At least I got my practice taking the 20 clips out.
    Part#- 64116912633
    Craig Brickner
    Click to Join: BMWCCA # 366493
    BMW CCA/PBOC/Chin Motorsports DE Instructor
    2008 M3 Sedan Jerez/Black
  15. #65
    Plano, TX
    Z3 Coupe
    I can't believe this write up still gets hit four years after I wrote it.
    I don't know, but I think this deserves a
  16. #66
    Columbia, SC
    1998 Z3 1.9
    Thanks for this!
  17. #67
    Dec 2004
    Spring Lake NJ, USA
    What's surprising is the number of people who just don't understand that the "contacts" are actually a fuseable link. Cleaning and sanding them is very nice, but it's not what will make it work reliably. Heating it up (soldering iron) and pressing them together is what WILL - since the contacts will once again be bonded with the Woods Metal that was used originally.
    Don Eilenberger
  18. #68
    Washington DC
    00 M Coupe
    Thanks for the detail write up...its been ten years of ownership and sooner or later this is gonna happen to me...
  19. #69
    Columbia, SC
    1998 Z3 1.9
    I know this is an old thread but it's never too late to say "Thanks"!
  20. #70
    CA
    228i convertible
    I still have a spare resistor. It's new in box. If anyone needs one pm me.
  21. #71
    Jul 2011
    Fullerton, CA
    Z3 coupe, 15 golf tdi
    I need a resistor for my Z3m. Don't know if this is how you PM.
  22. #72
    Jul 2011
    Fullerton, CA
    I replaced the resistor on mine following the instructions, works great now. Tried cleaning the old one but it did not help. The wiper blades were a pain but I got them off after a few tries. Thanks for the write up.
  23. #73
    Sep 2009
    Frog County
    E36/8 3.0 T.blau
    It's already been said but apparently nobody reads this part :
    YOU HAVE TO RESOLDER THE FUSE IN ORDER TO GET YOUR RESISTOR PACK TO WORK AGAIN !!!
  24. #74
    Cincinnati, OH
    02 Mroady,2007 Z4 coupe
    I resoldered the connections to the resistors. They are only crimped on and with my ohm meter I could see what the problem was by measuring. I resoldered all off the connectors and all is well now.
  25. #75
    Nov 2011
    Albuquerque, NM
    1998 M3 roadster
    Hi folks,
    I'm trying to troubleshoot why my blower fuse (30amp #20) on 1998 M Roadster keeps blowing out. I replaced the fan switch ($80) and tested the blower motor with inline 20amp fuse and it works fine. However, when only the blower is operating (no AC or recircle on), the fuse blows as I'm switching from 3 to2 or 2 to 1. It happens after about 1 min of operation. I'm not sure these threads are relevant, but maybe someone knows my problem?
    Thanks,
    Leon
