i think im about to get these injectors. the are Siemens Deka 750cc low impedance injectors.
just need to know if they wil physically fit into my manifold and fuel rail and also are Siemens injectors well known and a good quality compared to say Delphi and Precision?
yes they will fit, no they won't work with the stock ecu.
97 M3 - 8.94@164 - 8 sec street machine, all BMW driveline, factory ECU
02 M3 - 9.74@145 - Maximum PSI stage 2 turbo kit, stock motor, factory ECU
16 M3 - 9.3@151 - Built motor/twins
15 M3 - 9.2@162 - Built motor/single turbo/Ecutek
BMW SOB's turbo E30 - 8.72@158.39
follow our latest builds and upcoming events! - facebook.com/maximumpsi - instagram.com/maximumpsi
I'm using that same brand but high impedance. http://www.harrisspeedworks.com/shop/home.php?cat=331
I used those exact ones pictured in my rampage.
what do you guys think abut the Delphi/Rochester 75lb injectors..
the Delphi seme to have a better spray pattern over the Siemens Pintal tip
they are the same price as the Siemens
i cant decide on which to go with.
i would like to go with teh Siemen, but i talked to a friend that said they wouldnt work with the tec 3, so they returned them and got the Delphi pictured above and they worked perfectly.
ask concentric190, I remember he had issues and they only worked in the aftermarket fuel rail...
