Hi all,
desperate first post:
flat tire on my 2004 330cic, passenger rear. i have it jacked up and the wheel studs out, but cannot remove the wheel to save my life. any suggestions? i had previuosly engaged the parking brake to hold the vehicle in place, but have released it and still unable to remove my flat.
thanks!
jj
it was rusted on, whacked the hell out of it for about 15 minutes and got it.
First chance you get pull each wheel and throughly clean the centering ring on the hub. Apply a smear of anti-sieze all around the centering ring before remounting the wheel. I use a scratch wheel in a 3-1/2" angle grinder but a wire brush or sandpaper will work.
Jim Levie, Huntsville, AL
+1!!
If you don't change over to snow tires each season, you should take the wheels off at least once a year to perform above procedure.
