Yes, of course!!!
Kind of, but I'm still confused.....
No traction control, are you crazy???
Once my tax return comes back from the Fed, I plan on ordering this
~Phil
Madeiraviolett Bf.C club member #001
1996 BMW 328is Madeiraviolett/Dove Grey: 5 Spd, Sport, Cold Weather & Premium Sound pkgs.
3.5" ECIS/ITG intake -> Samco ASC Delete Boot -> DINAN TB -> M50 Manifold -> S52 Cams | Bav Auto Red-top ignition coils tuned w/ AA software, Dynomax Cats & Stromung exhaust UUC Pulleys & Clutch stop, FDM=Zionsville radiator, Mishimoto Tank, SAMCO hoses, Fidanza LTW flywheel & M3 clutch, UUC Evo3 SSK, 3.23 LSD, Koni/Eibach Adjustable Damper suspension, PUR RSM's & RTABs, CF Strut brace, UUC Swaybarbarians, Motorsport X-Brace, 17x8 Beyern Mesh wheels Hella CELIS projectors + 5k TRS HID's, Fog delete=Brake cooling duct, LTW wing, ///M Bumper & R. Diffuser
CCA Member #382557
Do you really need that?
I cannot read the writing on the TB. Can you provide a link to it?
It's the Riot Racing BBTB. It is 4mm larger than OEM and has a lighter butterfly for quicker response. The Dinan is only 2mm larger than stock and costs more. On M3 cars this makes 8whp. Since I am in M territory, I expect similar results.
An independent shop saw 4whp on a S50 car.
~Phil
CCA Member #382557
^^^ nice! how much is it?
Powertrain: Big Bore 87mm S50| Boost Logic Gen 2 Mani | BorgWarner S366 | CP 8.5:1 pistons | Eagle Rods | O-Ringed block | Tial 50mm | Precision 46mm | LINK G4 standalone | ZF| F1 stage 3 clutch/15lb ltwfw| UUC Black TM/E| Vorshlag MM's | 3.23LSD w/AKG race bushings| AKG race subframe bushings| 'Bear Motorsports' Re-enforced subframe | Walbro 525lp fp| VPD pulleys| 4'' DP into 3.5 straight pipe"||
Handling: FK konigsports| '95 M3 strut mounts| Rogue Engineering RSM's| UUC RTAB's| 20mm front spacers| 2915lbs Full interior
Aesthetics: M3 bumpers| 18''x 8.5/9.5 BBS LMs| ZKW's| 50w 6000k HID| Smoked Corners| 50% wndshld/5% all around| M3 sedan seats F&R| Black headliner| Black/Grey suede door panels| ZHP knob| M3 steering Wheel|
That can't be cheap ...
ex-1995 Cosmos M3 Coupé - deck spoiler / koni struts + shocks / x-brace / clears / unstaggered contours / yokohama avs es100 / alu thermostat housing / emp water pump / porterfield r4-s pads / gc rtab shims / bavauto ss brake lines / fdm / ie rsm plates / kicker sub + box + amp / sylvania silverstar lows / lamin-x / loc-tite'd opn / lots of refurbishing
Retired - mason strut brace / jl stealthboxes / tms chip + hfm / s&b filter + outerwears / ecis heatshield / alpine 9835 + aux
E36 ///M DIY & Tech - Door Handles / Underpanel / Coolant Hoses / Gear Ratios / 3.5" Intake / Lower Chain Tensioner / Threaded Starter / IAT Sensor / 24# Injectors
OK I know alot of you guys know way more about these cars than I do since most of my performance motorwork knowledge is in vtwin cycles. But has anyone found a good balance between super high flow high rev motor work and producing low end power?
At some point you dont provide enough velocity for low end power and sacrifice low end power for high end power, imo these engines produce awesome high end power and why not try to smooth out the power band and get even gains instead of just opening up the intake and exhaust.
Not that getting rid of the TB for the ACS is a bad idea at all. Two mechanical stages is definitaly one too many. I think from 92 to 95 acs was an option BTW, as my 94 had it.
Yeah turbo it.
CCA Member #382557
CCA Member #382557
The advantage to buying this boot through Bimmerworold, is that they include two(2) bungs to plug the holes. I used one(1) since the ICV needs to connect to the boot. Trust me, it is a bit pricey, but well worth the investment. You get everything you need, plus top notch quality and durability since it's SAMCO.
~Phil
CCA Member #382557
I guess if people have good success with it, then it must be good.
Just seems like $150 for a boot with 2 bungs is a bit pricey when you could easily fab up something similar for far less.
'92 325i, '93 Mazda MX6 - Boosted @ 6psi, '90 Jeep 4x4 <-- Geesh, everything I own is OLD!
You do make a good point, but again, please reference post 64
~Phil
CCA Member #382557
We are working on a big TB - only really needed with cams in an M3 engine. More info in a month or two...
hey james.......is there a discount for BFC members cuz i wanted to buy a samco boot from you guys......and will it need any adapter coming from the TB
M52 |S52 Cams|Gc Coilovers|M50 Manifold|3.5 Hfm|E36 Rack Swap. . . . . . . . . More To Come
Well hopefully us "heavily modded" M52 guys can take advantage of it. Honestly, I would but it just to say "I have a BBTB" lol If it was in that $200 the WCR TB, I'd stay with Bimmerworld. I have already made purchases from them and like the level of service I get with them. James, more info please!
~Phil
CCA Member #382557
I guess this is my first post, but have been lurking here for a long time. This forum rules! I have been looking at this mod for a while, I see you can get a plain old OEM type boot for ~20 from the same site. Also, I seem to remember finding somewhere on the net, that you could use a boot from a z3 (don't quote me). I went looking for the link but could not find it. I really like the blue Samco one, but I could put the extra $ toward the BBTB. Great discussion tho!
CCA Member #382557
Sorry - that wasn't meant as a dangling teaser. I post in a few forums and saw that you were talking about the 3.5" HFM, so I was thinking M3. I am sure there are some 2.8 guys that could use it, but it would need to have something big like the Sunbelt cams. Most of these engines don't really benefit from the 3.5" HFM either until you are to the 250+ crank mark. The only time it is really needed is when you flow enough air to run out of metering capability in the stock 3" piece.
I would be happy to do the math on our TB when we get it wrapped, but it isn't a couple of mm bigger - it is a lot bigger. And to make power, you do need to maintain velocity (smaller opening).
