Results 1 to 25 of 28
Thread: Brake fluid ATE TYP 200 and Super Blue?
    Jun 2003
    Odessa, FL
    '87 Porsche 911, '90 BMW 325is, '01 Volvo V70 T5
    As long as I have been doing this track DE stuff, almost 10 years now, I have rotated between the ATE Super Blue and the TYP 200 because every supplier said they were the same.
    Then last week I was ordering some parts for the Volvo from Volvo supplier IPD and in their catalog they had the boiling point for the ATE TYP 200 at several hundred degrees lower than the Super Blue???? I asked the sales rep on the phone and he confirmed it. Then I saw in one of the Porsche supply catalogs the same old "both are the same, so rotate so you can see the change in color".
    Anybody have a can of both the Super Blue and the TYP 200 to see what they have for boiling points? Need to try to remember to check the garage when I get home, but not sure it I have both.
    Here is a link to the IPD website about the 2 ATE fluids:
    ATE TYP 200 & Super Blue
    John Sabatini
    '87 Porsche 911
    '90 BMW 325is
    '01 Volvo V70 T5
    Raleigh, NC
    none these days...
    they have the same boiling points, wet and dry...
    Jun 2003
    Odessa, FL
    Thanks, guess I need to send that picture to IPD. Or maybe not, since they are charging less for the TYP 200.
    John Sabatini
    '87 Porsche 911
    '90 BMW 325is
    '01 Volvo V70 T5
    Indianapolis
    scooter
    Quote Originally Posted by jsabatini View Post
    They are the same except for the color.....
    Dec 2004
    Huntsville, AL
    87 325is
    I've learned the hard way that ATE Super Blue will stain your reservoir, which makes level checks more difficult. Before I learned that a local shop stocks AP551 I'd switched to using only ATE Type 200. There's no reason to alternate between two colors of fluid if you measure the amount that you bleed from each wheel. 250cc from each rear and 150cc from each front is more than enough to flush each circuit on a BMW.
    Jim Levie, Huntsville, AL
    Jul 2003
    nova
    8 BMW's & a Ford p/u
    Quote Originally Posted by thejlevie View Post
    interesting...i have run super blue exclusively in numerous street and race bmw cars for years and have not seen it stain any reservoirs...
    Jun 2003
    Odessa, FL
    Same here. Originally I switced between the 2, but then I went to primarily the TYP 200 and would occasionally end up with the Super Blue when the TYP 200 was not available. That's why I was concerned when I heard about the lower boiling point of the TYP 200, I prefer the TYP 200 to the Super Blue.
    John Sabatini
    '87 Porsche 911
    '90 BMW 325is
    '01 Volvo V70 T5
    Nov 2005
    LA,CA
    01 M Roadster, 04 S4
    Thumbs up Can anyone tell me how many
    bottles it need when changing the brake line on a 01 M Roadster?
    Boston, MA, USA
    '99 M Coupe
    Quote Originally Posted by LAMRoadster View Post
    Assuming you are speaking of the flexible lines to the calipers, assuming you either cap the line or depress the brake pedal slightly to prevent the fluid from running out, you should need very little -- one can would be plenty. The caliper will still be full, so it is just refilling the line and getting the air out.
    I suggest you tap the caliper while bleeding to get the little bubbles out. You may need to re-bleed after you've driven some.
    Jun 2001
    Reston, VA
    88 M5 FOR SALE, E92 335i
    Technically blue brake fluid isn't DOT approved. I, personally, hate the stuff. You cannot see dirt or debris in the lines, and flushing all the blue color out is very tough. Yes, I know you're supposed to flush the brake systems every 2 years, which prevents excess build-up of water induced contaminants, but how many out of the millions of car owners ever do that? If you use the clear stuff, it is much easier for you or your repair shop to see whether there is a lot of "dirt" in the lines from seal deterioration. Also, old blue fluid looks like new blue fluid, while the yellow/clear stuff turns a very easy to see brown color.
    Modern BMWs and most other cars require a low viscosity fluid due to the traction control and ABS systems, and blue/typ 200 are not. I don't have a supplier that sells the ATE SL.6, so we've gone with Motul 5.1 and RBF 600.
    James Muskopf
    RRT Racing
    DC Metro's premier BMW service and racing facility
    Boston, MA, USA
    '99 M Coupe
    Quote Originally Posted by JamesM3M5 View Post
    Interesting point on the viscosity that I don't think is well known. According to my Bentley manual for the Z3, regular fluid is recommended for ABS/ASC and low viscosity for ABS/DSC. (I happen to have ASC.) I can't confirm official BMW information, though.
    Jun 2003
    Odessa, FL
    Just confirmed it today myself. The chart from dmwhite matches the cans I have. Need to call IPD and order some more TYP 200 at the cheaper price.
    John Sabatini
    '87 Porsche 911
    '90 BMW 325is
    '01 Volvo V70 T5
    Mar 2004
    Fort Worth TX
    Wreck Miata,Dirty Thirty
    +1, only because it's blue though.
    May 2017
    San Francisco
    2011 328i
    ATE Super Blue won't stain your brake system
    Not true. What happened was when you flush the brake, the DSC system won't be flushed out unless you use specialized tool to recycle the anti-lock brakes. So after even flushing your brakes, whenever you activated the anti-lock brake, the old fluid will get into your reservoir. Since you have Super Blue in the system, it will show as blue in the fresh filled fluid. There is no way around it. Unless you go to the dealer and pay royally to have your fluid replaced throughout the entire brake system, there is noway to completely flush the old fluid out.
    Nov 2005
    MA
    Cayman S, Golf GSW, E30
    Not only is this thread 11 years old, but you can't even buy super blue anymore.
    Bergenfield, NJ
    '99 M3 '10 X5 35d '02 M3
    Quote Originally Posted by henryting88 View Post
    You can cycle the ABS by shorting the fuse.
    https://www.bimmerforums.com/forum/s...w-to-Cycle-ABS
    Mar 2004
    USA
    96 328is 6.0L
    Quote Originally Posted by BlackHawkRacing View Post
    Shorting the fuse will only end with blown fuse. What you meant to say is jumping the relay.
    May 2017
    San Francisco
    2011 328i
    Not true. Super Blue will not stain your brake system What happened was when you flush the brake, the DSC system won't be flushed out unless you use specialized tool to recycle the anti-lock brakes. So after even flushing your brakes, whenever you activated the anti-lock brake, the old fluid will get into your reservoir. Since you had Super Blue in the system, it will show as blue in the fresh filled fluid. There is no way around it. Unless you go to the dealer and pay royally to have your fluid replaced throughout the entire brake
    May 2017
    San Francisco
    2011 328i
    Sujper Blue will NOT stain your brake system.
    ATE Super Blue will NOT stain your brake components. What happen is that when you flush your brakes, the brake fluid in your anti-lock brake cannot/won't be flushed. Since the old fluid (in this case ATE Blue) retains in the antilock brake enclosure, once you activated the antilock brake, old fluid within the system will be dumped and mixed into your fresh brake fluid. Hence the fluid gets a bluish tint. That is the old fluid that got recycled into the system. There is no way around it other than having the dealer flush your entire brake system with their instrument that will recycle the solenoid within the antilock brakes.
    Oct 2003
    Seattle
    99 M3
    You can buy Super Blue in the US. It now comes with a disclaimer that states it is only to be used off roads.
    My experience says it does stain components, as my reservoir is tinted blue.
    Mar 2004
    USA
    96 328is 6.0L
    Quote Originally Posted by bluptgm3 View Post
    As far as I remember it aleays said not for highway use... Do you have a link to who sells the blue?
    Fair's Avatar
    Fair is offline Senior Member Supporting Vendor
    Oct 2003
    Dallas, Texas
    E36 M3, E36 LS1, E30 318
    Wait... ATE is still a thing? Do track folks still use cheap brake fluid? Have we not learned where it is safe to skimp and where it is not?
    Terry Fair @ Vorshlag Motorsports
    Mar 2004
    USA
    96 328is 6.0L
    Quote Originally Posted by Fair View Post
    ATE is still a thing and there is nothing wrong with this brake fluid. It is used by thousnads and works just fine on the street and on the track.
    Maybe it could be news to some, but things don't always have to be expensive and overpriced to be good.
    Northeast PA
    3 - E30 M3s, '04 Ford F350, '06 Audi A3
    Quote Originally Posted by bimerok View Post
    +1
    I used it for over a decade with never one issue on race cars and street cars.
    I couldn't find fault in it despite the high end brake fluid snobbery around the forums.
    jimmy p.
    88 E30 M3 Zinnoberot - street
    88 E30 M3 Lachsilber - SCCA SPU
    87 E30 M3 Prodrive British Touring Car 2.0 Litre
    04 Ford F350 - V10
    06 Audi A3 Brilliant Red / 2.0 / DSG
    Apr 2002
    Broomfield, Colorado
    +1 for ATE fluid. Used it for a very long time with great results.
    Terry - when did you test back to back with ATE - and what was 'better'?
    I find it to never boil, and not be as hydrophilic as the high dollar stuff.
    2002 BMW M Roaster.
    1998 BMW 328is SCCA E Production road racer.
