Results 1 to 24 of 24
Thread: 01 E39 Keyless Entry Kaput?
    Ithaca, NY
    Both master keys can lock/unlock the car in the manual (in the door lock) mode only.
    -the lights flash once and the acoustical signal sounds off when locking
    -the alarm indicator lamp flashes when the vehicle is locked
    -the central locking system button on the console functions
    -the fuel filler door lock does not work
    -there was a blown fuse (#53, central locking system) that I replaced in the trunck fuse tray
    It seems unusual that both the master keys would stop transmitting at the same time. Any recomendations on how I identify/fix the problem? Thanks jman
    Mar 2005
    (Northern) California
    2018 530e iPerformance
    I had a similar problem. The CLS wasn't working, but I could manually lock/unlock doors, truck, etc. Don't know about the fuel filler cap.
    When I took my 2002 E39 into the dealer for CPO work, they first said it was a fuse (located in the truck that may be bad-you've already checked this). Did you check the fuses in the glove box? After they looked at the system, they found out that the keys somehow lost their "initialization" and had to be "re-initialized". Once done, I've had no more problems. I didn't have to do the re-initialization but do a search on this board and you may find the steps to do it.
    You ain't no daisy!!
    Ithaca, NY
    Thanks. I'll check the other fuses and search the forums for the key initiation process.
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    have you looked in your owners manual for the initalizing process? I know my e38 manual does.
    Oct 2008
    Orlando, Florida
    2001 BMW 530i
    I have a 2001 BMW e39. My remote keyless entry stopped working. It will not lock or open any doors or any remote function. Any suggestions on a remedy?
    Thank you.
    Nov 2007
    Chicago, IL
    2001 BMW 540 I
    There is a reinitialization procedure that I've seen here. You can find it if you look it up. It's something like; turn key to acc 1 position and turn it back to off within 5 seconds. Press the unlock button 3 times while holding the lock button in at the same time. Door locks will unlock and then lock. I know this isn't the procdure exactly so look it up. I had an issue with mine and swapped the battery and it worked great for a while. Now I'm having the same issue again. Couldn't get the reinitialization to work so not sure if it's that or the receiver in the car that may be the problem.
    (northeast) Indiana
    Quote Originally Posted by jeremy339 View Post
    Thank you.
    Try reprogramming the key...make sure you have ALL of your remote keys with you during the reinitializing procedure...if not...the one(s) not there will no longer lock/unlock & arm/disarm your car.
    If the procedure below does NOT work, the lock the car manually (stick key in driver's door lock)...then walk around to the fuel filler door and see if you can open it. If you can, then your fuel filler door actuator is acting up...and the fuse for the fuel filler door may even be blown (it's in the trunk). If the fuse is blown, and you replace it and the fuse blows again, then you need to replace the fuel filler door actuator. This is a relatively common discussed issue...and can find past threads that discusses this issue...just use common key words to search by on the e39 forum like "fuel filler door" or "fuel filler door actuator".
    Good luck.
    Santa Clarita
    1999 Anthracite 528ia
    would this work the same even if i have the horse shoe key?
    (northeast) Indiana
    Quote Originally Posted by E391989 View Post
    Close, but slightly different. The older style key (rubber head or "horse shoe") doesn't require that you manually lock/unlock the doors first...the instructions should be in your owners manual (unlike the new style keys)....and make sure that your batteries are up to snuff and not the culprit
    Again, you MUST follow EVERY instruction to the "T". Here's the instruction reposted "again":
    How to change the battery in the old style key...and how to tell if the battery is dying (since you have the low cluster...you won't get the REMOTE KEY BATTERY warning in the display):
    Santa Clarita
    Quote Originally Posted by Qsilver7 View Post
    Thank you very much, i appreciate the help, i gotta try this when i get a chance
    Lexington, KY
    1998 BMW 528i
    Mine doesn't work at all. Mine is the horse shoe shaped key, and I have tried the syncing procedure several times with no luck. I replaced the battery in it and the LED comes on but the car doesn't seem to respond to it. Yes, I'm using position 1.
    My best guess the capacitors are dried up, due to it being 13 years old. Though I don't know the values of the capacitors so replacing them is kind of out of the questions. My next attempt will be to buy a key of someone with a salvaged car and try to sync it.
    Jun 2006
    potomac falls, va
    bmw 325is bmw 328ic
    Thumbs up
    Thanks Qsilver7!
    My car had died outside a valet station when they left the hazards on for hours and the key in pos 1. When I came out we had to jump it and the keys became "unpaired".
    Your process worked like a charm and I was able to get them reinitialized in just a few minutes.
    Cheers,
    dontburntheday
    Oct 2003
    Springfield, MO
    2002 540i Manual
    Subscribe
    2002 540i Manual
    2018 340 X Drive —Sold—
    2000 Dinan 540 manual —Sold—
    1999 328 E46 sedan--RIP--
    2000 M Coupe--Sold--
    1997 328ic--Sold--
    1996 M3--Sold--
    2001 530i--Sold--
    2000 528i--Sold--
    Jun 2006
    nyc
    BMW 6spd 550i w Sport Pk
    Good luck.
    about that filler door. If the fuse or the actuator is faulty, will that keep the key from beeping/locking or rolling down the windows etc.??
    Nov 2011
    Belgium
    E39 525TDS Touring
    Quote Originally Posted by Xeniczone View Post
    Try position 2. I've had the same issue, tried the whole procedure multiple times without any succes. When i used Position 2, it all worked again.
    E39 525 Tds Touring '98 Orient-blue on sandbeige.
    221000 miles. SOLD
    Audi A6 3.0 tdi, black with amaretto interior, sport seats, sline, quattro, automatic, ...
    (northeast) Indiana
    Quote Originally Posted by Big Chaze View Post
    Yes it can if trying to initiate lock/unlock & arm/disarm using & remote roll-down of windows using the buttons on the key. If the fuse (usually the one in the trunk) is blown...or if the fuel filler door actuator is faulty...it means that the central locking system FZV is not working properly. The RF signal is transmitted to the receiver in the C-pillar...which then sends a signal to the GM which then sends the info to the appropriate modules. But a blown fuse and/or a faulty fuel flap lock actuator can disrupt this communication.
    Since the keyless entry (FBZV) works/communicates with the FZV system...when it is faulty...it stops the FBZV system from working.
    If the fuse is blown and you replace it...or disconnect the fuel filler door actuator (if it's faulty)...then you can usually get the keyless (FBZV) system to work again. Unplugging the fuel filler door actuator (if its faulty) doesn't FIX the problem...but it does stop it from sending a fault to the central locking system. Much like disconnecting a faulty hood sensor etc.
    Jun 2006
    nyc
    Holy crap...off to my car to check...will post back. Where are these fuses located?
    (northeast) Indiana
    A usual culprit is the fuse in the trunk for the central locking system. Look for the fuse nbr & its location on the fuse index/diagram on the back of the battery compartment door. The fuses themselves are located above the battery.
    Again, if the fuse is blown & you replace...but it blows again...then the culprit is usually the fuel filler door actuator. You can pull the electrical harness from it until you can get a replacement (some replace & some don't)..but it's your choice if fuel theft would be an issue for you.
    Jun 2006
    nyc
    Replaced the fuse and it blew again...wheres the actuator?
    I found it...is it the rec black box with a green cable attached to it? I disconnected it and still nothing. Im gonna try to reinitialize the key again
    mega fail...I suck. I tried every which way to initialize this damn key.
    I put a higher amp fuse and still nothing. The actuator does lock the filler door and no more blown fuses...but no keyless entry.
    (northeast) Indiana
    The green cable?...make sure that's not the manual release for the fuel filler flap door. And if the fuse blew again, make sure you replace it...pulling the electrical connector to the actuator without replacing the fuse won't work. Once you have a good fuse (and unplug the actuator)...then reprogram the keys.
    You want to pull the electrical connector to the component in the pic below. The pic below is from an e38...but the e39 uses the same component. I have a Touring so I'm not sure if the e39 sedan has the same backing plate as the one in the e38.
    (in the pic below of an e38's fuel door actuator...it is dismounted from the cross member and flipped around so that you can see it...so it means everything is on the opposite side when it is mounted to the car...you can see the electrical harness attached to the lower left in the pic...that's what you need to look for)
    Oct 2003
    Springfield, MO
    2002 540i Manual
    Can you just leave the full door actuator unplugged and get the doors/trunk to lock and unlock normally and say forget the fix?
    2002 540i Manual
    1997 328ic--Sold--
    1996 M3--Sold--
    2001 530i--Sold--
    2000 528i--Sold--
    Jamaica
    2002 BMW 530i
    Qsilver which 5 series do you get that message with about the remote key battery?
    Jun 2006
    nyc
    QSilver is goddddddddddddd!!!!!
    It worked!! I decided to give it one last shot and by god it worked.
    I think i may have been doing something wrong all along.
    Heres what I did:
    Took car outta garage (reception,? maybee...)
    Locked car manually then unlocked (hadnt been doing that step)
    Turned key to pos 1
    removed key after about 2 seconds
    held down button 2
    pressed button 3 times and bam.
    Must note....I plugged the actuator back in and installed a higher rated fuse before attempting to initialize again.
    Thanks Q for your time and patience with us...
    (northeast) Indiana
    ...It worked!! I decided to give it one last shot and by god it worked...Thanks Q for your time and patience with us...
    Great...glad you got it sorted out.
    Quote Originally Posted by RhoanW View Post
    The REMOTE KEY BATTERY warning is one of the PRIORITY 2 warnings of the HIGH instrument cluster (the one with the 20-digit alpha/numeric display).
    Again, you may or may not get that warning on your HIGH cluster...it depends on how low the voltage is on the battery. Since the new style keys get charged when they are in the ignition...they are more likely to never see this warning from the key that get's used daily (or almost daily). Perhaps if one has a spare new style key...and it get's put into use when the key's battery voltage is low...it could possibly illuminate the PRIORITY 2 warning if the buttons are pressed before the key gets a chance to get recharged while in the ignition:
    (info for NEW STYLE (diamond shaped) key only)
    The car's with the old style remote keys are more likely to see this warning because their design (with the red LED) allows them to communicate the health of it's battery...unlike the new style key which you have to guess if the battery is charged or not. There are 3 tell tale signs for low battery voltage...and you may get 1, 2, or all 3 of the warnings for a low battery:
    1. REMOTE KEY BATTERY may appear in the instrument cluster display (if you have the HIGH instr cluster)
    2. red LED may fail to illuminate, or lights up weakly
    3. doors may lock...BUT...not UNLOCK when using the remote
