Page 4 of 20 FirstFirst 1234567891011121314 ... LastLast
Results 76 to 100 of 480
Thread: Spal electric fan wiring DIY
  1. #76
    Colorado
    are a waste of money
    Quote Originally Posted by pment View Post
    Low is 91°C & high is 99°C.
    91 deg C is 195.8 deg F
    99 deg C is 210.2 deg F
    Also if you want to run your aux fan after the car is off you can just turn the electrical back on. If the temps are high enough it will run until they go below the temp sensor rating. This is also assuming you don't have a light weight battery as it could drain it too much.
  2. #77
    Jun 2004
    NNJ
    04 330xi, 98 M3/4/5
    Three questions:
    1. Does anyone have a DIY (or just know the best way) to wire the fan to a manual switch down by the dash light dimmer switch or something?
    2. Does anyone know offhand what the max depth a fan can be and still fit?
    3. Is the "mounting kit" that Bimmerworld sells sufficient to mount these fans properly? I see many of you have other rigs.
    [2004 330xi/6] Orient/Natural :: 117-142k :: ZSP :: ZPP :: ZCW
    [1998 M3/4/5] Cosmos/Black :: 113-125k :: TCKline D/A (500/600) :: GC Plates :: RD Sways :: GC Rear Arms :: ZHP Rack :: 3.64 Diffsonline :: PF FCAB :: BW RTAB :: AKG Subframe :: TMS Pulleys :: AA & Borla :: XBrace :: TRM C2s :: BW lines :: DTC60 :: Safety Equipment
    Past:
    [1995 M3] Avus/Dove :: 141-242k :: S52 OBDI :: M50 manifold :: 3.5 HFM :: Turner Chip :: XBrace :: SS Lines :: Turner RTABS :: Vogtland CS :: Bilstein Sport :: Z3 rack
    [1999 M3] Cosmos/Black :: 65-87k :: TCKline S/A (400/500) :: Turner plates :: UUC Front Sway :: PF RTABs :: AA Intake :: Borla :: XBrace :: TRM C2s :: CL RC6E :: Safety Equipment
    [1993 325is] Brilliant/Black :: 135-139k :: Bilstein sports :: Eibach sways and springs :: Dinan camber plates and chip :: Borla :: LSD
    [1983 320i] Safari/Brownish :: 219-242k :: homebrew CAI :: some rust :: multicolor body panels
  3. #78
    Oct 2005
    Virginia Beach, VA
    99 M3, 01 F350
    Quote Originally Posted by Brent 930 View Post
    not sure how you could turn the electric back on, and have the fan still turn off, and not drain the battery?? the electric would still be powered...????
    my aux fan after a hard 30 minute track session, turns off before I even get back to the paddock at a slow crawl through the hot grid, and back into the paddock area..... and I have mine set for 80C kick point with 90 degree ambient temps... not sure how the fan would be running for more than a couple minutes TOPS at idle to cool everything down and turn off...
    "Torque is like cowbell... you can never have too much." - Michael Cervi
  4. #79
    Louisville, KY
    T67 M3
    Question:
    I will be upgrading my rad to the new Carr Industry aluminum unit. It's a bit thicker than stock So my question is would running a pusher fan (on front of rad) be as efficient as running a puller? I don't have the aux fan, it broke awhile ago and I just took it off. There is no AC condenser in the way, but there will be an FMIC where the condenser was. I just don't know which would be better a push or a pull. My guess is there won't be room for a puller with the CARR aluminum rad.
    Sorry if this thread is old, I just found it.
    Quote Originally Posted by MikeLenoch5 View Post
    Growing up, I thought Mercedes were superior to BMWs, because that's all my parents had and I didn't know that the E30 existed. Now I know the truth.
    Previous vehicles: (87' 528E 5spd) (Two 89' 750IL's)
    (E36 318is) (E34 535i) (E34 M5) (E36 M3) (Two 87' E30 vert) (E30 Touring)
  5. #80
    Magnolia, TX
    97 328is
    Has Carr told you when they will have the aluminum expansion tank available? They told me they were trying for this summer, but there was a delay. They were going to have a radiator, the aluminum expansion tank, and an electric fan as a set.
  6. #81
    Colorado
    Quote Originally Posted by 99MPower View Post
    Because it's temperature controlled, which you already know. Try it and see.
    It will only run for a few minutes before shutting down.
  7. #82
    Louisville, KY
    T67 M3
    the radiator will go on sale within a month, everything else has been delayed irrc. They have 3 of the rads in and are testing one on an FI car, one on a Track car, and the third on a track/street car. Once they are done with testing they will start selling. I didn't know if the fan in the eventual kit is going to be push or pull. It may be pull since most people still have their aux.
  8. #83
    Ventura, CA
    95 M3, 83 MBZ 300D
  9. #84
    Oct 2005
    Virginia Beach, VA
    99 M3, 01 F350
    Quote Originally Posted by Proctor750 View Post
    carr has been selling that alum radiator for a while now. I've installed two of them in my friends car's... they are STOCK size and a puller fan will work fine with it. no issues, as I reinstalled the stock fan shroud, and stock fan clutch back in one of my friends car, and the other we installed a spal puller....
  10. #85
    Ventura, CA
    95 M3, 83 MBZ 300D
    Carr + SPAL =
  11. #86
    Oct 2005
    Virginia Beach, VA
    99 M3, 01 F350
    wish i had pics of my zionsville with alum shroud, spal electric fan, and alum overflow tank out of the car right now
    i have a bunch of it in the car, and worth every penny... looks gorgeous .... and it works really well too... LOL
  12. #87
    Colorado
    Quote Originally Posted by sirius600 View Post
    Carr + SPAL =
    Nice setup, anyone is way better off with a stock all aluminum radiator with a good puller fan than a big radiator without a fan.
    You also will pull enough air through the condensor at idle for the AC if you still have it.
    I plan on upgrading to an all aluminum radiator next year and will see if the aux fan in the stock location is good enough. If not, then SPAL fan here I come.
  13. #88
    Louisville, KY
    T67 M3
    Negative, They no longer sell the rads you speak of. They were by Ireland engineering and after a few issues they decided to up the ante and go with a much better design in the 400-500 range. This new radiator won't be out for another month. I'm on the waiting list.
    Also, concerning the radiators, we are our changing our radiator manufacturer and will be carrying a new all alloy unit incorporating a all alloy reservoir, bleed screw, and cap. The radiators will be available by the end of June, and the reservoirs near the end of August. Our old radiator manufacturer(the same as Ireland Engineering) has made some upgrades as of late that have cured a lot of the leak issues, but we have decided to take the quality up a notch and sell a all around better radiator in the $400-500 range.
    Thanks,
    Brian
    Bfowler@Carrindustries.com
    http://forum.e36-tech.com/viewtopic....=1897&start=30
  14. #89
    San Diego, CA
    S54 and S62
    Guys I have a little question.
    The orange wire that goes to ignition.
    Where did you all wire it to ?
    I read about pin 16/secondary air pump, but what about OBD1 cars ?
    By the way here's a pic of my install, before putting the shroud back on.
    Szed did the brackets !
    Current:
    Alpine White E46 325i Touring S54 6MT
    Titanium Silver E39 540i Touring M-Sport S62 6MT
    Past:
    Alpine White E46 330i ZHP Sedan S54 6MT
    Interlagos Blue E85 Z4 M Roadster 6MT
    Le Mans Blue E92 M3 6MT
    Japan Red E46 325i Touring S54 6MT
    Estoril Blue Individual E46 M3 Coupe 6MT
    Cosmos Black E36 M3 Coupe S54 6MT
    Alpine White E92 M3 6MT
    Alpine White E90 M3 6MT
    Laguna Seca Blue E46 M3 Coupe 6MT
    Jet Black E36 325is S52 5MT
    Lagoon Green E36 325is 5MT
  15. #90
    Northern Virginia
    1998 ///M3
    Zionsville FTW.
    Anything else is just meh Though you will need to do this
  16. #91
    San Diego, CA
    S54 and S62
    Quote Originally Posted by Kaiv View Post
    Anyone ?
    Current:
    Past:
  17. #92
    minneapolis
    tite
    anyone try those ebay slim fans? there cheap, its just a fan i dont see why its not as good as any other
  18. #93
    NJ
    none
    I'd like to add something to this thread if it hasn't been mentioned already.
    There are (2) Green/White wires in the diagnostic port. You want to use the THICKER of the two. I tapped into the smaller one and it obviously didn't work.
  19. #94
    NJ
    none
    Anyone ?
    The obd1 cars also have a white/green wire in the diagnostic port. Use the THICKER of the two.
  20. #95
    NJ
    none
    Quote Originally Posted by Reverend73 View Post
    Zionsville FTW.
    Damn, that looks pimp.
    But I'm not sure if I like the shrouding covering the whole backside of the radiator like that. Don't you think it would be more effective if air could move through the whole unit?
    edit- on second thought, it prob is even more effective??
  21. #96
    San Diego, CA
    S54 and S62
    Quote Originally Posted by binh View Post
    Thank you kind sir !
    Current:
    Past:
  22. #97
    Cordova, TN
    92 318is (Euro M3 drivetrain), 97 civic
    I think my fan switch is bad so the previous owner had my aux fan hooked up to a switch, that I just turn on in traffic/autox. I am replacing the clutch fan with an electric fan from a ford taurus and was wondering: if the fan switch is good why can't I just hook the aux fan straight to the low-speed-wire, and the taurus fan straight up to the high-speed-wire from the switch? a/c was removed from the car
  23. #98
    Aug 2008
    Long Island, NY
    E36 328i
    BUMP, is it safe to run just the spal on the high switch? My aux fan makes my car vibrate and makes noise, I rather have it off. But it needs power for the spal to come on!
  24. #99
    Colorado
    Quote Originally Posted by ZeitGeist View Post
    Doesn't matter, 12v is 12v. Not the same as the aux fan which has a low and high motor.
  25. #100
    Aug 2008
    pittsburgh pa.
    98 m3 4dr
    I deleted my clutch fan a long time ago and recently had my aux die while in traffic. When I made it home I ordered a spal pusher, took the front bumper off the car, stripped all the a/c along with the worthless aux fan and cut the aux fan plug off the wiring harness. When the spal came I mounted it on the rad and soldered both positive wires from the car to the positive for the fan and neg to neg. It's been doing great for the past month, no issues.
